At present this value is hard-coded in the function that generates a
square wave. Since sample rates vary between different hardware, it makes
more sense to have this as a parameter.
Update the function and its users.
This function currently outputs twice as much data as it should and
overwrites its buffer as a result. Fix it.
Some RTC chips have child drivers, e.g. to provide access to their
non-volatile RAM. Scan for these when binding.
Update the device tree, sandbox i2c driver and tests to use the new
emulation parent to hold emulators.
Sandbox i2c works using emulation drivers which are currently children of
the i2c device:
rtc_0: rtc@43 {
reg = <0x43>;
compatible = "sandbox-rtc";
emul {
compatible = "sandbox,i2c-rtc";
In this case the emulation device is attached to i2c bus on address 0x43
and provides the Real-Time-Clock (RTC) functionality.
However this is not ideal, since every device on an I2C bus has a child
device. This is only really the case for sandbox, but we want to avoid
special-case code for sandbox.
A better approach seems to be to add a separate node on the bus, an
'emulation parent'. This can be given a bogus address (such as 0xff) and
hides all the emulators away. Then we can use a phandle to point from the
device to the correct emualtor, and only on sandbox. The code to find an
emulator does not interfere with normal i2c operation.
Add a new UCLASS_I2C_EMUL_PARENT uclass which allows finding an emulator
given a bus, and finding a bus given an emulator. This will be used in a
follow-on patch.
This is currently at the top in the space for internal use. But this
uclass is used outside driver model and test code. Move it into the
correct alpha order.
Add two functions which can find a child device by uclass or by name.
The first is useful with Multi-Function-Devices (MFDs) to find one of a
particular type. The second is useful when only the name is known.
This function may be useful to code outside of the code driver-model
implementation. Export it and add a test.
At present tests are quite slow to run, over a minute on my machine. This
presents a considerable barrier to bisecting for failures.
The slowest tests are the filesystem ones and the buildman --fetch-arch
test. Add a new 'qcheck' target that skips these tests. This reduces test
time down to about 40 second, still too long, but bearable.
There is a newline missing from quite a few printf() strings in these pmic
files. Fix them.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
It is sometimes useful to see what memory is being allocated early during
boot. Add logging to support this, using a new LOGC_ALLOC category.
- Add MediaTek support
This patch adds an entry for MediaTek.
Signed-off-by: Ryder Lee <ryder.lee@mediatek.com>
Add a few notes on how to try out the MediaTek support so far.
Tested-by: Frank Wunderlich <frank-w@public-files.de>
This patch adds MT7623 host controller driver for accessing SD/MMC.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
Tested-by: Matthias Brugger <matthias.bgg@gmail.com>
This patch adds a DDR3 driver for MT7629 SoC.
Signed-off-by: Wu Zou <wu.zou@mediatek.com>
Many SoCs from MediaTek have a high-speed uart. This UART is compatible
with the ns16550 in legacy mode. It has extra registers for high-speed
mode which can reach a maximum baudrate at 921600.
However this UART will no longer be compatible if it's in high-speed mode.
Some BootROM of MediaTek's SoCs will change the UART into high-speed mode
and the U-Boot must use this driver to initialize the UART.
Tested-by: Ryder Lee <ryder.lee@mediatek.com>
This adds power domain (scpsys) support for MT7623 SoC.
This adds a power domain driver for the Mediatek SCPSYS unit.
The System Control Processor System (SCPSYS) has several power
management related tasks in the system. The tasks include thermal
measurement, dynamic voltage frequency scaling (DVFS), interrupt
filter and lowlevel sleep control. The System Power Manager (SPM)
inside the SCPSYS is for the MTCMOS power domain control.
For now this driver only adds power domain support.
This patch adds pinctrl support for MT7623 SoC. And most of the
structures are used to hold the hardware configuration for each
pin.
This patch adds pinctrl support for MT7629 SoC. The IO core found on
the SoC has the registers for pinctrl, pinconf and gpio mixed up in
the same register range. Hence the driver also implements the gpio
functionality through UCLASS_GPIO.
This also creates a common file as there might be other chips that use
the same binding and driver, then being a little more abstract could
help in the long run.
This patch adds a common driver for the Mediatek SoC integrated
watchdog.
This patch adds clock source and clock event for the timer found
on the Mediatek SoCs.
This patch adds a driver for MT7623 clock blocks.
This patch adds clock modules for MediaTek SoCs:
- Shared part: a common driver which contains the general operations
for plls, muxes, dividers and gates so that we can reuse it in future.
- Specific SoC part: the group of structures used to hold the hardware
configuration for each SoC.
We take MT7629 as an example to demonstrate how to implement driver if
any other MediaTek chips would like to use it.
This adds a general board file based on MT7623 SoCs from MediaTek.
As this u-boot is loaded by MTK proprietary preloader, there is no
low level initializtion codes.
This adds a general board file based on MT7629 SoCs from MediaTek.
Apart from the generic parts (cpu) we add some low level init codes
and initialize the early clocks.
This adds device tree for MT7623 development board - Bananapi R2
Detailed hardware information for BPI-R2 which could be found on
http://wiki.banana-pi.org/Banana_Pi_BPI-R2.
This patch adds MT7629 device tree and the includes it needs.
This patch adds support for MTK boot image generation.
- Introduce CONFIG_SPL_DM_USB
- chiliboard updates
- misc TI platform updates
DM_SERIAL is selected by TARGET_CHILIBOARD, so there is no reason to
keep code that will not be built. Remove it.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
This patch mostly enables DM drivers in board defconfig and all their
dependencies. Additionally we remove ethernet platform data, as all
details are in device-tree now.
Add that node path in u-boot overlay dtsi file for now to keep
am335x-chiliboard.dts in sync with Linux.
Import chiliSOM and chiliboard dts files from Linux v4.19. They will
be used after transition to driver model and device-tree based boot.
This option is defined by a few boards but doesn't guard any code.
Remove it from the boards and config_whitelist.txt.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
This allow for convenient use of QEMU machine to test loading of UBI
filesystem. There are a couple of changes made together of this which
are required:
1) The malloc must be at least 512 KiB to allow the use of UBI
filesystem. We are going to enable it in a next patch.
2) MTD_DEVICE must be enabled, otherwise we get missing symbols
during the build
Following configs were change:
- vexpress_aemv8a_dram_defconfig
- vexpress_aemv8a_juno_defconfig
- vexpress_aemv8a_semi_defconfig
- vexpress_ca15_tc2_defconfig
- vexpress_ca5x2_defconfig
- vexpress_ca9x4_defconfig
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Liviu Dudau <liviu.dudau@arm.com>
When the spi_flash_probe_bus_cs() was previously called, it was
called using 0's for two values where CONFIG_ENV_SPI_MAX_HZ and
CONFIG_ENV_SPI_MODE are now used. When changed this
caused the environment to fail the CRC check and the default
was used. This patch defines both of these values back 0.
Fixes: 25a17652c9c2 ("fix: env: Fix the SPI flash device setup
for DM mode")
Some erratum workarounds call into C code before the stack
is setup, this can lead to values pushed onto the stack
being lost, firewall exceptions, and other undefined behavior.
Setup a temporary stack to allow these functions to work
correctly.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Andreas Dannenberg <dannenberg@ti.com>
Reviewed-by: Nishanth Menon <nm@ti.com>
stdlib.h is the header for malloc since at least c89/c90.
Previously this would fail to build on OpenBSD and fallback to the wrong
header:
In file included from u-boot/tools/file2include.c:21:
u-boot/include/malloc.h:875:5: error: function-like macro
'CONFIG_IS_ENABLED' is not defined
Signed-off-by: Jonathan Gray <jsg@jsg.id.au>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Recent removal of obsolete partition led to shifting of starting address
of "reserved" partition (which reflects U-Boot environment). Fix its
start address to keep it in sync with ENV_OFFSET and DFU environment.
This patch also provides fixed start address for "reserved" partition,
so that we can track when it's shifted next time.
While at it, move it before "misc" partition to keep all Android
partitions together.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Acked-By: Praneeth Bajjuri <praneeth@ti.com>
Based on the MCU R5 efuse settings, R5F cores in MCU domain
either work in split mode or in lock step mode.
If efuse settings are in lockstep mode: ROM release R5 cores
and SPL continues to run on the R5 core is lockstep mode.
If efuse settings are in split mode: ROM releases both the R5
cores simultaneously and allow SPL to run on both the cores.
In this case it is bootloader's responsibility to detect core
1 and park it. Else both the core will be running bootloader
independently which might result in an unexpected behaviour.
with this patch the selected Entry in bootmenu can be set by
environment-var bootmenu_default=<number>
Signed-off-by: Frank Wunderlich <frank-w@public-files.de>
This fixes link issues when building the SPL without USB driver model
but with USB storage support. CONFIG_BLK can be enabled and disabled
independently for SPL and non-SPL builds. We leverage that existing
functionality here.
Signed-off-by: Sven Schwermer <sven@svenschwermer.de>
This allows to disable the USB driver model in SPL because it checks
the CONFIG_SPL_DM_USB variable for SPL builds. Nothing changes for
regular non-SPL builds.
Common USB code is built whenever USB is enabled (in non-SPL builds).
The USB uclass is built whenever (SPL_)DM_USB is enabled. Both need to
be independent from CMD_USB.
