2005-05-05Increase CFG_MONITOR_LEN for Rattler board to match actual code size.wdenk
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-05-04Fix problem with symbolic links in JFFS2 code.wdenk
2005-05-04Use linker ASSERT statement to prevent undetected overlapping ofwdenk
sections on PPChameleon board; other boards might use this, too.
2005-05-03README: add explanation about patch policywdenk
net/net.c: fix indentation
2005-05-03* Patch by Stefan Roese, 03 May 2005:stroese
Update for P3G4 Fix problems in cmd_universe.c * Patch by Matthias Fuchs, 03 May 2005: Added missing variable declaration in cmd_nand.c Modified CFG_PCI_PTM1MS in configs/PLU405.h to map 128MB ram
2005-05-03* Patch by Matthias Fuchs, 03 May 2005:stroese
2005-04-22Fix INKA4x0: use CS1 as gpio_wkup_6 outputwdenk
2005-04-21Fix bug in the SDRAM initialization code for canmb, IceCube andwdenk
PM520 boards. Fix PHY address for canmb board.
2005-04-20get rid of obsolete CFG_AT91C_BRGR_DIVISOR definitionwdenk
2005-04-20Cleanup serial console baudrate calculation on AT91RM9200wdenk
2005-04-20Auto-size RAM on canmb board.wdenk
Cleanup.
2005-04-20* Patch by Matthias Fuchs, 18 Apr 2005:stroese
Make PCI target address spaces on PMC405 and CPCI405 boards configurable via environment variables
2005-04-13Add support for canmb boardLABEL_2005_04_14_0115wdenk
2005-04-13* Patch by Stefan Roese, 13 Apr 2005:stroese
Update for esd apc405
2005-04-13Update for esd apc405stroese
2005-04-13* Fixes for TQM8560 board:wdenk
- fix clock rates - remove debug messages - fix flash sector protection * Patch by Steven Scholz, 07 Apr 2005: Fix warning in cpu/arm920t/at91rm9200/i2c.c
2005-04-07Cleanupwdenk
2005-04-07* Patch by Steven Scholz, 07 Apr 2005:wdenk
Add i2c_reg_write() and i2c_reg_write() for at91rm9200 I2C * Patch by Steven Scholz, 07 Apr 2005: Fix compiler warning in altera.c * Patch by Ladislav Michl, 06 Apr 2005: Fix voiceblue configuration.
2005-04-07* Patch by Stefan Roese, 06 Apr 2005:stroese
Updates for OCOTEA board: - Changed U-Boot size from 512kByte to 256kByte - Fixed flash driver to support boot from soldered user flash - Added README for switch from PIBS firmware to U-Boot
2005-04-07Add PPC440GX Revision Cstroese
2005-04-07* Patch by Travis Sawyer, 05 Apr 2005:stroese
- Change timer frequency for ppc 440 from 10 ms to 1 ms. Problem found by Andrew Wozniak.
2005-04-06Patch by Steven Scholz, 06 Apr 2005:wdenk
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200 - moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
2005-04-06* Patches by Robert Whaley, 29 Nov 2004:wdenk
- update the pxa-regs.h file for PXA27x chips - add PXA27x based ADSVIX board - add support for MMC on PXA27x processors * Patch by Andrew E. Mileski, 28 Nov 2004: Fix PPC4xx SPD SDRAM detection bug * Patch by Hiroshi Ito, 26 Nov 2004: Fix logic of "test -z" and "test -n" commands
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
2005-04-05Patches by Steven Scholz, 05 Apr 2005:wdenk
- Use i.MX watchdog timer for reset_cpu() - Move reset_cpu() out of cpu/arm920t/start.S into the SoC specific subdirectories cpu/arm920t/imx/ and cpu/arm920t/s3c24x0/ (now in interupts.c)
2005-04-05Add support for MPC8220 based "sorcery" board.LABEL_2005_04_05_2345wdenk
2005-04-05Add support for TQM8560 boardLABEL_2005_04_05_1830wdenk
2005-04-04* Add FEC support for TQM8540 board.wdenk
Interfaces are named as follows: "ENET1" - TSEC2, "ENET2" - FEC * Patch by Martin Krause, 04 Apr 2005: Update default configuration for CMC_PU2 board.
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-04Use the same name (lowlevel_init) for all (ARM) boardswdenk
2005-04-04Patch by Steven Scholz, 04 Apr 2005:wdenk
Make sure that MDIO clock does not exceed 2.5 MHz on AT91
2005-04-04Fix timer code for ARM systems: make sure that udelay() does notwdenk
reset timers so it's save to use udelay() in timeout code.
2005-04-03* Patch by Mathias Küster, 23 Nov 2004:wdenk
add udelay support for the mcf5282 cpu * Patch by Tolunay Orkun, 16 November 2004: fix incorrect onboard Xilinx CPLD base address
2005-04-03Patch by Jerry Van Baren, 08 Nov 2004:wdenk
- Add low-boot option for MPC8260ADS board (if lowboot is selected, the jumper for the HRCW source should select flash. If lowboot is not selected, the jumper for the HRCW source should select the BCSR. - change default load base address to 0x00400000
2005-04-03* Patch by Yuli Barcohen, 08 Nov 2004:wdenk
Add support for Analogue & Micro Rattler boards. Tested on Rattler8248. * Patch by Andre Renaud, 08 Nov 2004: Fix watchdog support in common/lcd.c * Patch by Marc Leeman, 05 Nov 2003: Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU bug only affects the XPC8245 processors
2005-04-03Patches by Josef Wagner, 29 Oct 2004:wdenk
- Add support for MicroSys CPU87 board - Add support for MicroSys PM854 board
2005-04-03* Patch by Scott McNutt, 01 Nov 2004:wdenk
Add missing NIOS/NIOS2 support for "iminfo" command * Patch by Detlev Zundel, 29 Oct 2004: Add missing NIOS/NIOS2 support for "mkimage" tool.
2005-04-03Patch by David Adair, 27 Oct 2004:wdenk
Add missing 440GX SDRAM Controller reset
2005-04-03Patch by Steven Scholz, 25 Oct 2004:wdenk
Declare reset_cpu() in include/common.h instead locally
2005-04-03* Patch by Yusdi Santoso, 22 Oct 2004:wdenk
- Add support for HIDDEN_DRAGON board - fix endianess problem in driver/rtl1839.c * Patch by Allen Curtis, 21 Oct 2004: support multiple serial ports
2005-04-03* Patch by Richard Klingler, 03 Apr 2005:wdenk
Add call to eth_halt() in net/net.c when called functions fail after eth_init() has been called. * Patch by Sam Song, 3 April 2005: - Update README.Netconsole - Update README
2005-04-03Patch by Steven Scholz, 03 Apr 2005:wdenk
- create SoC specific directories include/asm-arm/arch-imx and include/asm-arm/arch-s3c24x0
2005-04-03Minor cleanupwdenk
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2005-04-01Patch by Martin Krause, 01 Apr 2005:wdenk
Add automatic HW detection for CMC_PU2 and CMC_BASIC
Fix flash erase timeout on CMC_PU2
2005-04-01Patch by Steven Scholz, 13 March 2005:wdenk
fix cache enabling for AT91RM9200
