DM_SPI and other driver model migration deadlines
are expired for this board.
Remove it.
Patch-cc: Xiaobo Xie <xiaobo.xie@nxp.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Remove it.
Patch-cc: Ruchika Gupta <ruchika.gupta@nxp.com>
Remove it.
Patch-cc: Poonam Aggrwal <poonam.aggrwal@nxp.com>
Remove it.
Remove it.
Patch-cc: Timur Tabi <timur@tabi.org>
Remove it.
Patch-cc: Priyanka Jain <priyanka.jain@nxp.com>
Remove it.
Patch-cc: Po Liu <po.liu@nxp.com>
Remove it.
Patch-cc: Naveen Burmi <naveen.burmi@nxp.com>
Remove it.
Remove it.
Patch-cc: Ashish Kumar <ashish.kumar@nxp.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- fix boot with OP-TEE for stm32mp15 boards
Add OP-TEE firmware node in stm32mp15 U-Boot DTSI. This node is
needed since commit [1] that changed U-Boot/stm32mp15 to detect
OP-TEE availability by probing the resource instead of relying on
U-Boot configuration. The software sequence implemented by [1] is
fine but U-Boot DTS/DTSI files were not updated accordingly since,
hence OP-TEE presence is never detected by U-Boot, preventing Linux
kernel from using OP-TEE resources.
For consistency and to synchronize stm32mp15 DTSI files (excluding
U-Boot specific DTSI files) with the Linux kernel ones, this change
also moves the OP-TEE reserved memory nodes from board generic DTSI
files to U-Boot specific board DTSI files.
Link: [1] commit 43df0a159df6 ("stm32mp1: dynamically detect op-tee presence")
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Fix the sequence in stm32mp1 fdt.c that disables OP-TEE resources
defined in FDT when U-boot detects OP-TEE firmware is not present.
Before this change, helper function stm32_fdt_disable_optee()
set property status to "disabled" for the OP-TEE reserved memory
nodes but this has no impact since Linux kernel does not consider
the status property for reserved-memory subnodes. This change
make U-Boot to attempt to delete the node instead.
Fixes: 4a1b975dac02 ("board: stm32mp1: reserve memory for OP-TEE in device tree")
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-07-rc5
Use correct printf code in efi_image_parse().
Add random number generation to HTML documentation.
The fix in commit b7adcdd073c0 has the side-effect that the regulator
will be disabled when requesting the relevant gpio in
regulator_common_ofdata_to_platdata() and enabled in
regulator_pre_probe() when the regulator was already enabled.
This leads to a short interruption in the 3.3V power to the PCIe
slot on the firefly-rk3399 which makes an ADATA SX8000NP NVMe SSD
unhappy.
Fix this by setting the GPIOD_IS_OUT_ACTIVE flag again when the
'regulator-boot-on' property is set, but check for this property
explicitly instead of relying on the "boot_on" member of
the uclass platdata.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
- Assorted bug fixes
Update the comment for SYS_RELOC_GD_ENV_ADDR as gd->env_addr is updated
in board_r.c::initr_reloc_global_data() under the compilation flags
CONFIG_SYS_RELOC_GD_ENV_ADDR
Several configutation options require additional memory before relocation:
* CONSOLE_RECORD
* LOG
* RSA
The current default of 0x400 is too small to encompass them all. Increase
the value of SYS_MALLOC_F_LEN to 0x2000 for ARCH_QEMU.
This reverts commit 0486497e2b5f4d36fa968a1a60fea358cbf70b65.
The strtoul has well-defined semantics. It is defined by the C standard and
POSIX. To quote the relevant section of the man pages,
> If base is zero or 16, the string may then include a "0x" prefix, and the
> number will be read in base 16; otherwise, a zero base is taken as 10
> (decimal) unless the next character is '0', in which case it is taken as
> 8 (octal).
Keeping these semantics is important for several reasons. First, it is very
surprising for standard library functions to behave differently than usual.
Every other implementation of strtoul has different semantics than the
implementation in U-Boot at the moment. Second, it can result in very
surprising results from small changes. For example, changing the string
"1f" to "20" causes the parsed value to *decrease*. Forcing use of the "0x"
prefix to specify hexidecimal numbers is a feature, not a bug. Lastly, this
is slightly less performant, since the entire number is parsed twice.
This fixes the str_simple_strtoul test failing with
test/str_ut.c:29, run_strtoul(): expect_val == val: Expected 0x44b (1099), got 0x1099ab (1087915)
test/str_ut.c:46, str_simple_strtoul(): 0 == run_strtoul(uts, str2, 0, 1099, 4): Expected 0x0 (0), got 0x1 (1)
Signed-off-by: Sean Anderson <seanga2@gmail.com>
CC: Michal Simek <michal.simek@xilinx.com>
CC: Shiril Tichkule <shirilt@xilinx.com>
s/booot/boot/g
The first ase is booot instead of boot and second u-booot instead of
u-boot.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Fix the loop that parses FDT for a reserved memory node named "optee".
Before this change, if at least one subnode was found in the
reserved-memory node, the function endlessly looped since instruction
continue returned back in the loop without updating variable subnode.
This change fixes the issue by using a for loop.
Fixes: 6ccb05eae01b ("image: fdt: copy possible optee nodes to a loaded devicetree")
- fsl_esdhc sdr104 and hs200 fix and error path fix
- fsl_esdhc workaround 3.3v io issue
- ca_dw_mmc cleanup
- presidio-asic emmc DT update.
Unsupported voltage on voltage switch is not an error, do not
print error message in such a case. This happens e.g. if the
eMMC is already in 1V8 mode or when testing 1V2 mode operation
on systems which only do 3V3/1V8 switching.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Peng Fan <peng.fan@nxp.com>
The 3V3/1V8 switching could never have worked on any of the iMXes
ever since 51313b49f2 ("mmc: fsl_esdhc: support SDR104 and HS200"),
because that commit uses priv->vqmmc_dev when switching voltages on
mode switch, while local vqmmc_dev in probe to store the regulator
pointer. Those are two different variables with the same name. So
the priv->vqmmc_dev was always NULL and thus voltage switch between
modes never really suceeded.
Fix this by assigning priv->vqmmc_dev with value of the vqmmc_dev
in probe.
Fixes: 51313b49f2 ("mmc: fsl_esdhc: support SDR104 and HS200")
Change DT compatibility name to match change in driver's name.
Remove unused io_ds and fifo_mode fields from DT.
Signed-off-by: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Tom Rini <trini@konsulko.com>
- Rename DT compatible name
- Remove uneccessary if-statement to support 8-bit buswidth
- Remove redundant error msg
- Use symbolic constants in switch statement
Signed-off-by: Arthur Li <arthur.li@cortina-access.com>
When eSDHC operates at 3.3v, damage can accumulate in an internal
level shifter at a higher than expected rate. The faster the interface
runs, the more damage accumulates. This issue now is found on LX2160A
eSDHC1 for only SD card.
The hardware workaround is recommended to use an on-board level shifter
that is 1.8v on SoC side and 3.3v on SD card side.
For boards without hardware workaround, this option could be enabled,
ensuring 1.8v IO voltage and disabling eSDHC if no card.
This option assumes no hotplug, and u-boot has to make all the way to
to linux to use 1.8v UHS-I speed mode if has card.
If you do not want the workaround for better user experience, of course
you can choose to not select it running eSDHC in unsafe mode.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
No need to poll register for card inserted status.
For size_t we have to use %zu for printing not %lu.
Fixes: 4540dabdcaca ("efi_loader: image_loader: support image
authentication")
Add random number generation APIs to the HTML documentation.
Fix style issues.
- eth/r8152: update the firmware
- cyclone5 bugfix
Commit e71b6f6622d6 ("i2c: designware_i2c: Rewrite timing calculation")
change the hcnt and lcnt timing calculation. New timing calculation is
based on calculation from Designware i2c databook.
After this new timing calculation, hcnt will have negative value
with i2c-scl-falling-time-ns 5000 that set in socfpga_cyclone5_socdk.dts.
This patch overwrite i2c-scl-falling-time-ns to 300ns (default SCL fall
time used in Designware i2c driver) for Uboot.
Before the fix:
=> i2c dev 0
Setting bus to 0
Failure changing bus number (-22)
After the fix:
=> i2c dev 0
Setting bus to 0
=> i2c probe
Valid chip addresses: 17 51 55 5B 5C 5E 66 68 70
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
Update the firmware to improve compatibility for none-intel USB
host controller. The more information is as following.
The device has auto-installed driver feature - via switch CD-ROM/NIC
mode. But in some corner cases, it would switch to CD-ROM unexpected.
This issue results in Lan Function Disabled.
While USB PHY transits to P3 from P0 due to the absent of transmitter
control, it would issues undefined signal to its link partner.
Some Down Stream Port misidentify the undefined signal as wakeup
signal. So the link state will not keep in suspend even the system
is idle.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
- Drop davinci, mxs spi nondm code
- Zap nondm soft_spi
- Switch few board to DM_SPI
- Drop omap3_pandora, pcm051 boards
Enable DM_SPI for am355x sl50 board.
Build is fine, but not tested.
Cc: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Reviewed-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Enable DM_SPI for igep00x0 board.
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
OF_CONTROL, DM_SPI and other driver model migration deadlines
Remove it.
Acked-by: Lars Poeschel <poeschel@lemonage.de>
Remove it.
Acked-by: Grazvydas Ignotas <notasas@gmail.com>
Now all boards which are using davinci SPI driver
have moved to SPL_DM so drop the unneeded non-dm code.
Cc: Adam Ford <aford173@gmail.com>
Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
This would make SPL build to DM_SPL, SPL_OF_CONTROL.
Build fine with but not tested.
Cc: Vitaly Andrianov <vitalya@ti.com>
atmel_spi.h has register offsets, and atmel_spi_slave
structure, move it into .c file for better readability
and drop atmel_spi.h
Cc: Wenyou Yang <wenyou.yang@atmel.com>
atmel spi driver now accessible only when DM_SPI enabled.
So, remove nondm code.
Drop CONFIG_SYS_SPI_WRITE_TOUT there is no code usage.
Drop the nondm code from fsl_dspi.c since there
is no board or any other code using for it.
- Deadline for DM migration already passed by months.
- Sent couple of zap patches and
- No response on dm conversation
hence removed the driver.
Order the macros, private structures and simple functions
in a proper way to have more code readability.
No functionality changed.
and no response on full dm conversation hence removed
the nondm code.
Note: Look like there is no user for nondm code
for this driver.
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2020.07
- mx53: mx53menlo Convert to DM_ETH, fix fail boot
- imx8mp_evk: fix boot issue
- MX6, display5: fix environment
- drop warnings (watchdog) for i.MX8mm i.mx8mp
- enable bootaux for i.MX8M
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/695929999
This reverts commit 1f63ee656698724bcdc4e711b4ccd267f6bf64ab.
As reported by Ye Li on ML:
1. Removing the image_offset will break secondary (redundant) boot support for sd and emmc.
2. When booting from emmc boot partition, the image_offset is 0. But the flash.bin
generated by mkimage with imximage-8mp-lpddr4.cfg is for sd. It expects to be burn at 32KB offset.
The fit offset 0x60000 has already included the 32KB offset. So when you burn this flash.bin
to emmc boot partition at offset 0, the fit offset should subtract the 32KB (0x60000 - 0x8000).
