2020-07-27pci_ep: layerscape: Add the PCIe EP mode support for lx2160a-v2Xiaowei Bao
Add the PCIe EP mode support for lx2160a-v2 platform. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27pci: layerscape: Modify the ls_pcie_dump_atu functionXiaowei Bao
Modify the ls_pcie_dump_atu function, make it can print the INBOUND windows registers. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27pci_ep: layerscape: Add the SRIOV VFs of PF supportXiaowei Bao
Add the INBOUND configuration for VFs of PF. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27pci_ep: layerscape: Add Support for ls2085a and ls2080a EP modeXiaowei Bao
Due to the ls2085a and ls2080a use different way to set the BAR size, so add the BAR size init code here. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27pci_ep: layerscape: Add the workaround for errata A-009460Xiaowei Bao
The VF_BARn_REG register's Prefetchable and Type bit fields are overwritten by a write to VF's BAR Mask register. workaround: Before writing to the VF_BARn_MASK_REG register, write 0b to the PCIE_MISC_CONTROL_1_OFF register. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27pcie_ep: layerscape: Add the multiple function supportXiaowei Bao
Add the multiple function support for Layerscape platform, some PEXs of Layerscaple platform have more than one PF. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: dts: ls1046a: Add the PCIe EP nodeXiaowei Bao
Add the PCIe EP node for ls1046a. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27pci_ep: Add the init functionXiaowei Bao
Some EP deivces need to initialize before RC scan it, e.g. NXP layerscape platform, so add the init function in pci_ep uclass. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27pci: layerscape: Split the EP and RC driverXiaowei Bao
Split the RC and EP driver, and reimplement the EP driver base on the EP framework. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> [Rebased] Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27arm: dts: lx2160a: Increase configuration window sizeWasim Khan
lx2160a rev2 requires 4KB space for type0 and 4KB space for type1 iATU window. Increase configuration size to 8KB to have sufficient space for type0 and type1 window. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27configs:ls1046afrwy: Add tfa secure boot defonfigManish Tomar
Add TFA secure boot defconfig and Enables secure boot related configs in it. Signed-off-by: Manish Tomar <manish.tomar@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27freescale: ls1043aqds: drop ifdef CONFIG_SYS_I2CBiwen Li
- Drop ifdef CONFIG_SYS_I2C to initialize baudrate of i2c - Drop warning of i2c_early_init_f as follows, warning: implicit declaration of function 'i2c_early_init_f'; did you mean 'arch_early_init_r'? [-Wimplicit-function-declaration] Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27freescale: ls1043aqds: enable secure system counterBiwen Li
Enable secure system counter in board_early_init_f for udelay() to fix a bug that always return 0 by timer_read_counter() when boot from qspi(No TFA) Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27freescale: ls1046aqds: drop ifdef CONFIG_SYS_I2CBiwen Li
2020-07-27freescale: ls1046aqds: enable secure system counterBiwen Li
2020-07-27i2c: mxc: move i2c_early_init_f to common functionBiwen Li
Move i2c_early_init_f to common function to initialize baudrate of i2c Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27crypto/fsl: add RNG supportMichael Walle
Register the random number generator with the rng subsystem in u-boot. This way it can be used by EFI as well as for the 'rng' command. Signed-off-by: Michael Walle <michael@walle.cc> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27crypto/fsl: instantiate the RNG with prediciton resistanceMichael Walle
If it is already instantiated tear it down first and then reinstanciate it again with prediction resistance. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27crypto/fsl: don't regenerate secure keysMichael Walle
The secure keys (TDKEK, JDKEK, TDSK) can only be generated once after a POR. Otherwise the RNG4 will throw an error. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Horia Geantă <horia.geanta@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27crypto/fsl: support newer SEC modulesMichael Walle
Since Era 10, the version registers changed. Add the version registers and use them on newer modules. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Horia Geantă <horia.geanta@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27crypto/fsl: export caam_get_era()Michael Walle
We need the era in other modules, too. For example, to get the RNG version. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Horia Geantă <horia.geanta@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27crypto/fsl: make SEC%u status line consistentMichael Walle
Align the status line with all the other output in U-Boot. Before the change: DDR 3.9 GiB (DDR3, 32-bit, CL=11, ECC on) SEC0: RNG instantiated WDT: Started with servicing (60s timeout) After the change: DDR 3.9 GiB (DDR3, 32-bit, CL=11, ECC on) SEC0: RNG instantiated WDT: Started with servicing (60s timeout) Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Horia Geantă <horia.geanta@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27crypto/fsl: unused value in caam_hash_update()Heinrich Schuchardt
The value 0 assigned to final is overwritten before ever being used. Remove the assignment. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27crypto/fsl: correct printf() statement.Heinrich Schuchardt
The sequence of arguments should match the format string. For printing unsigned numbers we should use %u. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27arm64: ls1043a: Remove the workaround of erratum A-009929Hou Zhiqiang
The workaround has been implemented in PBI phase, so remove the duplicated implementation from U-Boot. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27configs: ls1012a: Increase CONFIG_SYS_MALLOC_LEN valueKuldeep Singh
Previous attempt to increase CONFIG_SYS_MALLOC_LEN was done in commit c084a8edf4e2 ("configs: ls1012a: Increase CONFIG_SYS_MALLOC_LEN size") which increased malloc memory to ~1M. PFE firmware alone requires 3M of dynamic memory allocation and therefore, increase the config value to a larger value i.e 5M. This size should be enough as of now to accommodate further memory requirements. Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27configs: lx2160aqds: enable CONFIG_BOARD_EARLY_INIT_RYangbo Lu
Enable CONFIG_BOARD_EARLY_INIT_R for SDHC adapter card identification and configuration. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27board: fsl: lx2160aqds: identify SDHC adapter during board initYangbo Lu
Add support for SDHC adapter identification and configuration during board init. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27Move eSDHC adapter card identification to board filesYangbo Lu
The eSDHC adapter card identification and multiplexing configuration through FPGA had been implemented in both common mmc driver and fsl_esdhc driver. However it is proper to move these code to board files and do it during board initialization. The FPGA registers are also board specific. This patch is to move eSDHC adapter card identification and multiplexing configuration from mmc driver to specific board files. And the option CONFIG_FSL_ESDHC_ADAPTER_IDENT is no longer needed. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> [Rebased, Removed T1040QDS change as board does not exist] Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27Drop global data sdhc_adapter for powerpcYangbo Lu
The sdhc_adapter of global data has not been used, and we do not have to use it as global data even we may need it in the future. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: ls1028ardb: add xspi parameter to qixis commandYuantian Tang
Add xspi boot source to qixis command to let the soc boot from flex-nor flash chip. Signed-off-by: Yuantian Tang <andy.tang@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: ls1012a: RGMII ports require internal delayChaitanya Sakinam
The correct setting for the RGMII ports on LS1012ARDB is to enable delay on both Rx and Tx so the interface mode used should be PHY_INTERFACE_MODE_RGMII_ID Signed-off-by: Chaitanya Sakinam <chaitanya.sakinam@nxp.com> Signed-off-by: Anji J <anji.jagarlmudi@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27include/configs: ls1012a: Remove fdt_high env variableUdit Agarwal
Remove "fdt_high" environment variable to use the bootm_size to safely contain a kernel, device tree and initrd for relocation. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27config: lx2160/2a: enable dspiZhao Qiang
Enable dspi in lx2160aqds tfa defconfig Enable CONFIG_SPI_FLASH_SST/EON in config file. Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: dts: fsl-lx2160a: add flash node under dspi to qds dtsZhao Qiang
Add flash node under dspi into fsl-lx2160a-qds.dtsi Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27crypto/fsl: fix unaligned accessMichael Walle
On aarch64 running with dcache off, will result in an unaligned access exception: => dcache off => hash sha1 $kernel_addr_r 100 "Synchronous Abort" handler, esr 0x96000061 elr: 00000000960317d8 lr : 00000000960316a4 (reloc) elr: 00000000fbd787d8 lr : 00000000fbd786a4 [..] The compiler emits a "stur x1, [x0, #12]". x1 is might just be 32 bit aligned pointer. Remove the unused u64 element from the union to drop the minimal alignment to 32 bit. Also remove the union, because it is no more needed. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27I2C: ls1043a, ls1046a: enable SYS_I2C_MXCBiwen Li
This enables SYS_I2C_MXC to fix a bug that failed to boot from sd card with image u-boot-with-spl-pbl.bin Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: rework spin tableMichael Walle
There are two issues: (1) The spin table doesn't convert the endianness of the jump address. Although there is code for it, the result isn't used at all (x0). (2) If something goes wrong, the function returns. But that doesn't make sense at all. Use the actual converted jump address as destination to fix. If there is an error, jump to a trap loop. And rearrange the code exception level switching code to make it smaller and clearer. This reduces the size of the spin table code section from 696 bytes to 424 bytes. If CONFIG_ARMV8_SWITCH_TO_EL1 the code size reduced from 696 bytes to 632 bytes. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: relocate spin table if EFI_LOADER is enabledMichael Walle
On ARM64, a 64kb region is reserved for the runtime services code. Unfortunately, this code overlaps with the spin table code, which also needs to be reserved. Thus now that the code is relocatable, allocate a new page from EFI, copy the spin table code into it, update any pointers to the old region and the start the secondary CPUs. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: clean exported symbols in spintable.SMichael Walle
Add a new variable secondary_boot_code_start, which holds a pointer to the start of the spin table code. This will help to relocate the code section. While at it, move the size variable from the end to the beginning so there is a common section for the variables. Remove any other symbols. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: drop first .ltorg directive in spintable.SMichael Walle
Now that the spin table is in a separate module, this is no longer necessary. Drop it. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: make wake_secondary_core_n() staticMichael Walle
This function is not used outside the module. Make it static. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: simplify get_spin_tbl_addr() callsMichael Walle
There is no need to cast around. Assign the address to the local variable and use it. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: remove determine_mp_bootpg()Michael Walle
Only the PowerPC architecture needs this function. Remove it. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: fix alignment for spin tableMichael Walle
Fix the alignment so it will match the comments. The spin table has to be 8 byte aligned, so ".align 3" is enough. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: load function pointer using ADRMichael Walle
Don't use LDR to load a pointer to a function. This will generate a literal which cannot be relocated. Use ADR which is PC-relative and therefore can easily be relocated. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: move spin table into own moduleMichael Walle
Move it out of lowlevel.S into spintable.S. On layerscape, the secondary CPUs are brought up in main u-boot. This will make it possible to only compile the spin table code for the main u-boot and omit it in SPL. This saves about 720 bytes in the SPL. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: properly use CPU_RELEASE_ADDRMichael Walle
The generic armv8 code already has support to bring up the secondary cores. Thus, don't hardcode the jump in the layerscape lowlevel_init to the spin table code; instead just return early and let the common armv8 code handle the jump. This way we can actually use the CPU_RELEASE_ADDR feature. Signed-off-by: Michael Walle <michael@walle.cc> [Rebased, Removed kontron_sl28.h change as file does not exist] Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: pretty print info about SMP coresMichael Walle
Make the print of the starting address a debug output and pretty print the info about online cores. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-27armv8: layerscape: fix spin-table supportMichael Walle
Spin tables are broken with bootefi. This is because - in contrast to the booti call chain - there is no call to smp_kick_all_cpus(). Due to this missing call the secondary CPUs are never released from their "wait for interrupt state", see secondary_boot_func() in lowlevel.S. Originally, this "wait for interrupt" is there to make sure, the spin table is cleared before the secondary cores read it for the first time. But the boot flow for the layerscape architecture is different from that. The CPUs are release from their BootROM _after_ U-Boot's spin-table is cleared, see fsl_layerscape_wake_seconday_cores() in mp.c. Thus, there is no need to wait for this interrupt and no need for kicking all cores on cpu_release. An atomic 64bit write to the spin-table and a "sev" is sufficient. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
