2006-08-25Fix typo in MCC200/PRS200 configurationWolfgang Denk
2006-08-25Update for MCC200 / PRS200 boards:Wolfgang Denk
- auto-adjust console device for Linux. - fix typos.
2006-08-25Merge with /home/tur/proj/fo300/u-bootWolfgang Denk
2006-08-24Updates for MCC200 / PRS200 boards:Wolfgang Denk
- support for configurations with SDRAM or DDR memory, - support for highboot and lowboot - adjusting environment definitions
2006-08-22Add a fix for a buggy USB device on the FO300 board.Bartlomiej Sieka
2006-08-18Minor cleanupWolfgang Denk
2006-08-18Add support for WTK FO300 board (TQM5200 based).Marian Balakowicz
2006-08-18Merge with /home/raj/git/u-bootWolfgang Denk
2006-08-18Merge with git+ssh://fifi/home/wd/git/u-boot/masterWolfgang Denk
2006-08-18Fix TQM834x hang.Rafal Jaworowski
2006-08-17Cleanup debug code for yucca board.Wolfgang Denk
2006-08-17MCC200: restrict addressable flash space to 32 MBWolfgang Denk
2006-08-17Add debug console on COM12 for MCC200 boardWolfgang Denk
2006-08-14Update for SC520 board.Wolfgang Denk
Patch by David Updegraff, 02 Dec 2005
2006-08-14Fixed common.h spelling error.Wolfgang Denk
Patch by Cory Tusar, 30 Nov 2005
2006-08-14Fix typo.Wolfgang Denk
Patch by Andreas Engel, 28 Nov 2005
2006-08-14Fix fatload command on FAT32 formatted partitions.Wolfgang Denk
Patch by Joachim Jaeger, 18 Nov 2005
2006-08-14Fix drivers/dm9000.c when configured in 32 bit mode.Wolfgang Denk
Patch by Eric Benard, 17 Nov 2005
2006-08-13Merge with /home/sr/git/u-boot/denxWolfgang Denk
2006-08-11Merge with /home/raj/git/u-bootWolfgang Denk
2006-08-11Fix preboot message on TQM85xx after switching to hush parser.Wolfgang Denk
2006-08-11Adapt TQM85xx ramdisk address to Linux kernel memory mapWolfgang Denk
2006-08-11Fix PCI-Express on PPC440SPe rev. A.Rafal Jaworowski
2006-08-10Merge with /home/raj/git/u-bootWolfgang Denk
2006-08-10Add support for PCI-Express on PPC440SPe (Yucca board).Rafal Jaworowski
2006-08-10Fix compiler warning for TRAB board.Wolfgang Denk
Patch by Martin Krause, 07 Aug 2006
2006-08-07Merge with /home/tur/proj/usb_sticks/u-bootWolfgang Denk
2006-08-07Fix control-c handing in CONFIG_CMDLINE_EDITINGStefan Roese
Properly pass break code back from readline. Patch by Roger Blofeld, 31 Jul 2006
2006-08-07Add commandline history support to all AMCC eval boardsStefan Roese
Patch by Stefan Roese, 07 Aug 2006
2006-08-07Add Macronix MXLV320T flash support for AMCC BambooStefan Roese
2006-08-07Change "mii info" to not print an error upon missing PHY at addressStefan Roese
2006-08-03Prevent USB commands from working when USB is stopped.Bartlomiej Sieka
2006-08-02Add rudimentary handling of alternate settings of USB interfaces - to fixBartlomiej Sieka
problems with some USB storage devices. Some code readability improvements.
2006-07-28PPC440 DDR setup: Set SDRAM0_CFG0[PMU]=0 for best performanceStefan Roese
AMCC suggested to set the PMU bit to 0 for best performace on the PPC440 DDR controller. Please see doc/README.440-DDR-performance for details. Patch by Stefan Roese, 28 Jul 2006
2006-07-27Merge with /home/sr/git/u-boot/denxWolfgang Denk
2006-07-27AMCC bamboo (440EP) U-Boot image reduced to 384kbyteStefan Roese
Please see doc/README.bamboo for details. Patch by Stefan Roese, 27 Jul 2006
2006-07-27Fix CONFIG_CMDLINE_EDITING implementationStefan Roese
2006-07-26Fix preboot message on TQM5200 after switching to hush parser.Wolfgang Denk
2006-07-23MCC200: set default configuration to low_boot DDR,Wolfgang Denk
and support for configurable options high_boot and/or SDRAM.
2006-07-22Add support for 256 MB SDRAM on CPU87Wolfgang Denk
Patch by Josef Wagner, 25 Nov 2005
2006-07-22Add configuration for cam5200 board (based on TQM5200S).Wolfgang Denk
2006-07-21Code cleanupWolfgang Denk
2006-07-21Code cleanup.Wolfgang Denk
2006-07-21More code cleanupWolfgang Denk
2006-07-21Disabled kvme080 board in MAKEALL because of build problems.Wolfgang Denk
2006-07-21Update NetStar boardWolfgang Denk
Patch by Ladislav Michl, 03 Nov 2005
2006-07-21Make code better readable.Wolfgang Denk
Patch by Ladislav Michl, 14 Sep 2005
2006-07-21Enable initrd ATAG for xm250 board.Wolfgang Denk
Patch by Josef Wagner, 05 Sep 2005
2006-07-21Document CONFIG_CMDLINE_EDITING in README.Wolfgang Denk
