Make the fixup matchable with dts and kernel. Update the compatible from
"fsl,flexcan-v1.0" to "fsl,p1010-flexcan" and Change the "clock-freq"
property to "clock-frequency". We also change flexcan frequency from
CCB-clock to CCB-clock/2 according to P1010 spec.
We now keep the old interfaces to make previous kernel work. They should
be removed in the future.
Signed-off-by: Jia Hongtao <B38951@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Erratum A-003999: Running Floating Point instructions requires special
initialization.
Impact:
Floating point arithmetic operations may result in an incorrect value.
Workaround:
Perform a read modify write to set bit 7 to a 1 in SPR 977 before
executing any floating point arithmetic operation. This bit can be set
when setting MSR[FP], and can be cleared when clearing MSR[FP].
Alternatively, the bit can be set once at boot time, and never cleared.
There will be no performance degradation due to setting this bit.
common/menu.c used printf() in a number of places to print user
provided, constant strings (like the "title" string). printf() is
dangerous here for example in case the user unwittingly embeds some
'%' caracters that printf() would interpret as formatting and then
pick up random arguments. Use puts() instead.
We also omit the trailing ':' in the title line - if a user wants
this, he can provide it as part of the title string.
* 'agust@denx.de' of git://git.denx.de/u-boot-staging:
MAKEALL: drop obsolete mx31pdk_nand target
dataflash: fix parameters order in write_dataflash()
hawkboard: Replace HAWKBOARD_KICK{0, 1}_UNLOCK defines
davinci_sonata: define CONFIG_MACH_TYPE for davinci_sonata board
davinci_schmoogie: define CONFIG_MACH_TYPE for davinci_schmoogie board
arm: a320evb: define mach-type in board config file
OMAP3: Use sdelay from arch/arm/cpu/armv7/syslib.c instead of cloning that.
Fix Stelian's email address
* 'master' of git://git.denx.de/u-boot-video:
DIU: 1080P and 720P support
CFB: Fix font rendering on mx5 framebuffer
The mx31pdk can boot only from NAND and the target was
already updated in boards.cfg. mx31pdk_nand is obsolete
and is dropped.
Fix parameters order in write_dataflash() function extern declaration in
the header file.
Parameters order, as in function definition, should be:
addr_dest, addr_src, size.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
This patch replaces the HAWKBOARD_KICK{0,1}_UNLOCK defines by
DV_SYSCFG_KICK{0,1}_UNLOCK.
The kick register values are not hawkboard specific but may be used
for all davinci boards. In commit f3c149d6c6e5ba8dd72baa86fe527837e4fb0e9a
new defines for these values wer introduced.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Syed Mohammed Khasim <sm.khasim@gmail.com>
Cc: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
This patch fixes the build breakage for the davinci_sonata board.
Cc: Sergey Kubushyn <ksi@koi8.net>
This patch fixes the build breakage for the davinci_schmoogie board.
MACH_TYPE_FARADAY was dropped from mach-types.h. Add it back to
board config file.
Signed-off-by: Yan-Pai Chen <ypchen@faraday-tech.com>
There is no need to have such a function twice.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
Acked-by: Dirk Behme <dirk.behme@googlemail.com>
Change my old email address which is no longer valid.
Signed-off-by: Stelian Pop <stelian@popies.net>
* 'master' of git://git.denx.de/u-boot-mmc:
Revert "mmc: retry the cmd8 to meet 74 clocks requirement in the spec"
mmc: mv_sdhci: Fix host version read for Armada100
As a result of the commit 6833260 the uart16550 driver
is broken for Microblaze big endian systems, because of
the missing 3 byte offset. Other than as described, not
all U-Boot BSP will treat properly the 3 byte offset.
This why prefer to mask out the 3 byte offset in general
and setup correct _REG_SIZE value depending on edianess.
Signed-off-by: Stephan Linz <linz@li-pro.net>
Tested-by: Michal Simek <monstr@monstr.eu>
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
cmd_nvedit.c: In function 'do_env_grep':
cmd_nvedit.c:182:3: warning: suggest parentheses around assignment used as truth value
Fix:
x86emu/ops2.c: In function 'x86emuOp2_set_byte':
x86emu/ops2.c:171:11: warning: variable 'name' set but not used [-Wunused-but-set-variable]
This reverts commit 02f3029f1810b99869254d0cf0a71946a008a728.
This patch add 3 times retry to CMD8 because the Marvell mmc controller
doesn't obey the power ramp up process in the SD specification 6.4.1.
(Please refer to figure 6.1 and 6.2 in the specification.)
The CMD0 should be send after power ramp up has been finished.
However, the Marvell mmc contorller must do power ramp up after the
first CMD0 command has been send.
This patch also affect existing platforms like Nokia N900 and other
platforms.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Acked-by: Lei Wen <leiwen@marvell.com>
sdhci_readw does not work for host version read in Armada100 series
SoCs. This patch fix this issue by making a sdhci_readl call to get host
version.
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
Add the 1920x1080 and 1280x720 resolution support.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Acked-by: Timur Tabi <timur@freescale.com>
CC: Anatolij Gustschin <agust@denx.de>
* 'hs@denx.de' of git://git.denx.de/u-boot-staging:
drivers/net/dnet.c: Fix GCC 4.6 warnings
board/xaeniax/flash.c: Fix GCC 4.6 warnings
net/bootp.c: Fix GCC 4.6 warning
common/cmd_bootm.c: Fix GCC 4.6 warnings
board/mx1ads/mx1ads.c: Fix GCC 4.6 warning
board/mx1ads/syncflash.c: Fix GCC 4.6 warnings
board/lubbock/flash.c: Fix GCC 4.6 warnings
drivers/net/cs8900.c: Fix GCC 4.6 warning
arch/arm/cpu/arm926ejs/omap/cpuinfo.c: Fix GCC 4.6 warnings
drivers/net/lan91c96.c: Fix GCC 4.6 warning
board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warning
drivers/mtd/onenand/samsung.c: Fix GCC 4.6 warning
drivers/usb/musb/musb_hcd.c: Fix GCC 4.6 warning
Fix:
davinci_i2c.c: In function 'flush_rx':
davinci_i2c.c:81:6: warning: variable 'dummy' set but not used
Acked-by: Heiko Schocher <hs@denx.de>
There are some magic constants in this drivers, which I cannot
fixup ... Eran, can you help here?
Cc: Eran Man <eran@nbase.co.il>
This supports I2C of Renesas SH.
I tested on SH7724.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Heiko Schocher <hs@denx.de>
Fix:
dnet.c: In function 'dnet_send':
dnet.c:136:9: warning: variable 'len' set but not used
dnet.c: In function 'dnet_set_hwaddr':
dnet.c:209:2: warning: dereferencing type-punned pointer will
break strict-aliasing rules [-Wstrict-aliasing]
Fix:
flash.c: In function 'flash_erase':
flash.c:223:6: warning: variable 'flag' set but not used
flash.c: In function 'write_data':
flash.c:392:6: warning: variable 'flag' set but not used
Fix:
bootp.c: In function 'BootpCopyNetParams':
bootp.c:108:11: warning: unused variable 'tmp_ip' [-Wunused-variable]
Fix:
cmd_bootm.c: In function 'bootm_load_os':
cmd_bootm.c:315:7: warning: unused variable 'unc_len'
[-Wunused-variable]
Fix:
mx1ads.c: In function 'board_early_init_f':
mx1ads.c:83:24: warning: variable 'tmp' set but not used
Fix:
syncflash.c: In function 'SF_SR':
syncflash.c:60:10: warning: variable 'tmp1' set but not used
syncflash.c: In function 'SF_PrechargeAll':
syncflash.c:96:6: warning: variable 'tmp' set but not used
syncflash.c: In function 'SF_Erase':
syncflash.c:112:6: warning: variable 'tmp' set but not used
syncflash.c: In function 'flash_init':
syncflash.c:155:6: warning: variable 'tmp' set but not used
Fix:
flash.c:223:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable]
flash.c:392:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable]
Fix:
cs8900.c: In function 'get_reg_init_bus':
cs8900.c:69:14: warning: variable 'c' set but not used
Fix:
cpuinfo.c: In function 'print_cpuinfo':
cpuinfo.c:155:6: warning: variable 'system_serial_low' set but not used
cpuinfo.c:154:6: warning: variable 'system_serial_high' set but not used
Fix:
lan91c96.c: In function 'dump_memory_info':
lan91c96.c:157:7: warning: variable 'mem_info' set but not used
lan91c96.c: In function 'smc_send_packet':
lan91c96.c:320:16: warning: variable 'ioaddr' set but not used
Fix:
pm9263.c: In function 'pm9263_lcd_hw_psram_init':
pm9263.c:167:20: warning: variable 'x' set but not used
Fix:
samsung.c: In function 's3c_onenand_check_lock_status':
samsung.c:486:6: warning: variable 'tmp' set but not used
Fix:
musb_hcd.c: In function 'submit_control_msg':
musb_hcd.c:851:6: warning: variable 'csr' set but not used
NDS32 and SANDBOX architecture were sharing the same IH_ARCH number
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Acked-by: Macpaul Lin <macpaul@andestech.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Remove unneccessary codes.
1. Clean up for cpu related code.
2. Clean up for timer related code.
Instead of linking the file into $(obj) tree use directly the source file.
This also prevents littered source tree if building not out-of-tree.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
This fixes a few printf() strings for size_t which are missing the 'z'
modifier.
device is already in *normal* (D0) mode => it doesn't need to be wake-up.
With this patch, we only wake-up (writing on TEST_BYTE register) if PM_MODE
bits of PM_CTRL register is in sleep (D1/D2) mode.
Signed-off-by: Bertrand Cachet <bertrand.cachet@heig-vd.ch>
Cleanup the env_common.c checkpatch warnings, errors and coding style.
Cleanup the env_nand.c checkpatch warnings, errors and coding style.
Cleanup the env_flash.c checkpatch warnings, errors and coding style.
Cleanup the env_sf.c checkpatch warnings, errors and coding style.
Cleanup the env_eeprom.c checkpatch warnings, errors and coding style.
