Definition update and change from 16bit to 32bit
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
Add CF specific modules header files
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Signed-off-by: John Rigby <jrigby@freescale.com>
Previous setting cause ips clock to be out of spec. This bug was found by John
Rigby from Freescale.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
MPC837xERDB board support includes:
* DDR2 330MHz hardcoded (soldered on the board)
* Local Bus NOR Flash
* I2C, UART and RTC
* eTSEC RGMII (TSEC0 - RTL8211B with MII;
* TSEC1 - VSC7385 local bus, hardcoded, requires seperate firmware
* load)
Signed-off-by: Kevin Lam <kevin.lam@freescale.com>
Signed-off-by: Joe D'Abbraccio <joe.d'abbraccio@freescale.com>
System registers that are modified are the Arbiter Configuration
Register (ACR), the System Priority Control Register (SPCR), and the
System Clock Configuration Register (SCCR).
Signed-off by: Michael F. Reiss <Michael.F.Reiss@freescale.com>
Signed-off by: Joe D'Abbraccio <ljd015@freescale.com>
Before, the order of arguments to the pixis_reset
command needed to be supplied in a hard-coded order.
Generalize the command parsing to allow any order.
Signed-off-by: James Yang <james.yang@freescale.com>
Acked-by: Jon Loeliger <jdl@freescale.com>
Convert the board/freescale/common/Makefile to use
CONFIG_* options to select which files to conditionally
compile into the board/freescale/common library rather
than conditionally compiling entire files.
Now handles::
CONFIG_FSL_PIXIS
CONFIG_FSL_DIU_FB
CONFIG_PQ_MDS_PIB
CONFIG_ID_EEPROM is introduced until CFG_ID_EEPROM is gone.
Use driver/net/uli526x.c as MPC8610HPCD default Ethernet driver.
Remove unused ethernet CONFIG_ options.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
continuation of commit b96c83d4ae475a70ef2635cd0e748174c44c8601
mpc8360emds.c: In function 'ft_board_setup':
mpc8360emds.c:327: warning: assignment makes pointer from integer without a cast
mpc8360emds.c:329: warning: passing argument 2 of 'fdt_getprop' makes integer from pointer without a cast
mpc8360emds.c:334: warning: passing argument 2 of 'fdt_setprop' makes integer from pointer without a cast
mpc8360emds.c:341: warning: assignment makes pointer from integer without a cast
mpc8360emds.c:343: warning: passing argument 2 of 'fdt_getprop' makes integer from pointer without a cast
mpc8360emds.c:348: warning: passing argument 2 of 'fdt_setprop' makes integer from pointer without a cast
use tree passed to us in local blob, not global fdt.
Also use fdt_path_offset to convert to relative offset, since absolute
reference is needed to check for rgmii-id mode string value.
These changes were identified by HighSmith Bill ,Mazzyar and Joseph for
DDR configuration in u-boot code. Some are related to performance, some
affect stability and some correct few basic errors in the current
configuration.
The changes have been tested and found to give better memory latency
figures on MPC8313eRDB.LMBench figures prove it.
The changes are:
- CS0_CONFIG[ AP_n_EN] is changed from 1 to 0
(this may improve performance for application with many read
or write to open pages).
- CS0_CONFIG[ODT_WR_CFG] is currently changed from 100 to
001 (activating all the CS when only one is used may cause
unwanted noise on the system)
- TIMING_CFG_1[ACTTOPRE] is changed from 9clks to 8clks (based on
Tras=45ns)
- TIMING_CFG_1[REFREC] changed from 21 clks to 18clks.
- TIMING_CFG_2[AL] value changed from 0 setting to 1 clk to
comply with the 3 ODT clk requirements)
- TIMING_CFG_2[CPO] was set to a reserved value, changed to RL+3/4.
- TIMING_CFG_2[FOUR_ACT] is changed from 10 clks to 6clks.
- DDR_SDRAM_MODE[AL]changed from 0 to 1.
- DDR_SDRAM_MODE[WRREC] changed from 1 clk to 3 clks.
- DDR_SDRAM_INTERVAL[REFINT] is changed from 0x0320 to 0x0510.
- DDR_SDRAM_INTERVAL[BSTOPRE] is changed from 0x64 to 0x0500.
The patch is based of git://www.denx.de/git/u-boot-mpc83xx.git
The last commit on this tree was 6775c68683a53c7abc778774641aac6f833a2cbf
Signed-off-by: Poonam Aggrwal-b10812 <b10812@freescale.com>
Cc: Bill HighSmith <Bill.Highsmith@freescale.com>
Cc: Razzaz Mazyar <MRazzaz@freescale.com>
Cc: Josep P J <PJ.Joseph@freescale.com>
The isdram command prints out decoded information the "serial presence
detect" (SPD) chip on the SDRAM SIMMs. This can be very helpful when
debugging memory configuration problems.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
The features list:
- Boot from NOR Flash
- DDR2 266MHz hardcoded configuration
- Local bus NOR Flash R/W operation
- I2C, UART, MII and RTC
- eTSEC0/1 support
- PCI host
Signed-off-by: Dave Liu <daveliu@freescale.com>
The TSEC emergency priority definition of 831x/837x
is different than the definition of 834x in SPCR register.
Add the other config of TSEC emergency priority into
cpu_init.c
The MPC8360ERDK board support patch is added before
the commit 2c5b48fc205c3e2752910da8f39209ed075929e5
so, miss clean up it.
The patch clean up the miss cache config.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
OneNAND: Separate U-Boot dependent code from OneNAND
adjust default environment;
disable SCC ethernet (not used on this board).
SH7710/SH7712 of SH3 CPU are supported.
SH771X is called SH-Ether, and has the Ether controller in CPU.
The driver of Ether is not included in this patch.
This patch add the support of map_physmem() and unmap_physmem()
used with Common Flash Interface(CFI) driver.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
qe.c: In function 'qe_upload_firmware':
qe.c:390: warning: pointer targets in passing argument 2
uec.c: In function 'uec_initialize':
uec.c:1236: warning: 'uec_info' may be used uninitialized
Now that bit 29 is the USB PHY reset bit, update the Kilauea port
to remove the USB PHY reset after powerup. The CPLD will keep the
USB PHY in reset (active low) until the bit is set to 1 in
board_early_init_f().
Signed-off-by: Michael Schwingen <michael@schwingen.org>
