This serial driver had wrong name of the source file for some time
now. The name of the driver was serial.c instead of any more logical
and fitting name. Thus, rename the driver source file to serial_ns16550.c
and be done with it.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Tom Rini <trini@ti.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Mike Frysinger <vapier@gentoo.org>
Having both USBTTY and CONFIG_SERIAL_MULTI enabled in SPL, the
usbtty.c file is protected in Makefile to not be compiled into
the SPL. Yet, the ns16550 serial driver does not contain such
protection. Add it to avoid missing symbol error.
If case the get_current() call fails before relocation, the U-Boot
must try to print an error message, fail and either reset or halt.
Such error is critical enough to halt the system, as it means the
system is in very bad state.
This is now also used in SPL, since CONFIG_SERIAL_MULTI is enabled
unconditionally. To avoid compiling whole vsprintf.c into SPL, use
puts() to print error message and hang() to stop the system in case
of SPL build.
Remove the empty bodies from serial_* functions from MXS SPL code.
These empty implementations are now in common/serial.c instead so
declaring them also in the SPL code would cause a colision once
serial multi is enabled unconditionally.
Implement support for CONFIG_SERIAL_MULTI into sh serial driver.
This driver was so far only usable directly, but this patch also adds
support for the multi method. This allows using more than one serial
driver alongside the sh driver. Also, add a weak implementation
of default_serial_console() returning this driver.
Cc: Phil Edworthy <PHIL.EDWORTHY@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Implement support for CONFIG_SERIAL_MULTI into sa1100 serial driver.
driver alongside the sa1100 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into s3c44b0 serial driver.
driver alongside the s3c44b0 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into pl01x serial driver.
driver alongside the pl01x driver. Also, add a weak implementation
Cc: Mathieu J. Poirier <mathieu.poirier@linaro.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: John Rigby <john.rigby@linaro.org>
Cc: Rabin Vincent <rabin.vincent@stericsson.com>
Implement support for CONFIG_SERIAL_MULTI into netarm serial driver.
driver alongside the netarm driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into mxc serial driver.
driver alongside the mxc driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into max3100 serial driver.
driver alongside the max3100 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into lpc2292 serial driver.
driver alongside the lpc2292 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into lh7a40x serial driver.
driver alongside the lh7a40x driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into ks8695 serial driver.
driver alongside the ks8695 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into ixp serial driver.
driver alongside the ixp driver. Also, add a weak implementation
Cc: Michael Schwingen <michael@schwingen.org>
Implement support for CONFIG_SERIAL_MULTI into imx serial driver.
driver alongside the imx driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into clps7111 serial driver.
driver alongside the clps7111 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into sandbox serial driver.
driver alongside the sandbox driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into s3c64xx serial driver.
driver alongside the s3c64xx driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into s3c4510b serial driver.
driver alongside the s3c4510b driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into OpenCores serial driver.
driver alongside the OpenCores driver. Also, add a weak implementation
Cc: Scott McNutt <smcnutt@psyent.com>
Implement support for CONFIG_SERIAL_MULTI into ns9750 serial driver.
driver alongside the ns9750 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into MCF serial driver.
driver alongside the MCF driver. Also, add a weak implementation
Cc: TsiChung Liew <tsicliew@gmail.com>
Implement support for CONFIG_SERIAL_MULTI into lpc32xx serial driver.
driver alongside the lpc32xx driver. Also, add a weak implementation
Cc: Vladimir Zapolskiy <vz@mleia.com>
Implement support for CONFIG_SERIAL_MULTI into atmel serial driver.
driver alongside the atmel driver. Also, add a weak implementation
Cc: Xu, Hong <Hong.Xu@atmel.com>
Implement support for CONFIG_SERIAL_MULTI into altera serial driver.
driver alongside the altera driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into altera_jtag serial driver.
driver alongside the altera_jtag driver. Also, add a weak implementation
Cc: Thomas Chou <thomas@wytron.com.tw>
Implement support for CONFIG_SERIAL_MULTI into p3mx serial driver.
driver alongside the p3mx driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into sconsole serial driver.
driver alongside the sconsole driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into ml2 serial driver.
driver alongside the ml2 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into evb64260 serial driver.
driver alongside the evb64260 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into cpci750 serial driver.
driver alongside the cpci750 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into cogent serial driver.
driver alongside the cogent driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into bmw serial driver.
driver alongside the bmw driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into amirix serial driver.
driver alongside the amirix driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into marvell serial driver.
driver alongside the marvell driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into leon3 serial driver.
driver alongside the leon3 driver. Also, add a weak implementation
Cc: Peter Tyser <ptyser@xes-inc.com>
Implement support for CONFIG_SERIAL_MULTI into leon2 serial driver.
driver alongside the leon2 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into iop480 serial driver.
driver alongside the iop480 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into mpc85xx serial driver.
driver alongside the mpc85xx driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into both SCC and SMC mpc8260
serial drivers. These drivers were so far only usable directly, but this
patch also adds support for the multi method. This allows using more than
one serial driver alongside the mpc8260 drivers. Also, add a weak
implementation of default_serial_console() returning this driver.
Implement support for CONFIG_SERIAL_MULTI into mpc8220 serial driver.
driver alongside the mpc8220 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into mpc5xx serial driver.
driver alongside the mpc5xx driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into JZ serial driver.
driver alongside the JZ driver. Also, add a weak implementation
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Implement support for CONFIG_SERIAL_MULTI into asc serial driver.
driver alongside the asc driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into au1x00 serial driver.
driver alongside the au1x00 driver. Also, add a weak implementation
Rework the emulation of serial console via JTAG from simple ad-hoc
implementation of serial port routines to CONFIG_SERIAL_MULTI and
enable CONFIG_SERIAL_MULTI unconditionally for blackfin.
In order for the JTAG serial console to take precedence over all
other serial ports available in system, implement override for
default_serial_console call returning this JTAG serial console.
This brings in a bit of a growth of size, but eventually will allow
us to unconditionally enable CONFIG_SERIAL_MULTI throughout the whole
U-Boot and maintain only one serial subsystem.
Remove the prototypes for zoom2_serial_deviceN from serial.h . This
can't be done right away, as they are referenced from the zoom2
config file. Therefore, adjust the code so the config file only
specifies number of the port. Then, replace the simple return in
default_serial_console() with a switch across possible values, which
returns the zoom2_serial_deviceN . With such adjustment in place,
the exported prototypes in serial.h can be safely removed.
Rename the serial_register_bfin_uart() to bfin_initialize_serial()
to be consistent with the rest of the naming. Next, remove it's
prototype from serial.h and properly insert it into serial.c as
the rest of the serial initialization functions.
Remove the exports from serial.h as they are only used in the blackfin
serial driver. Furthermore, they are only used for registration, which
is handled already inside that driver and default_serial_port() call,
which is also handled in that driver.
