2011-09-03arm: fix bd pointer dereference prior initializationIgor Grinberg
gd->bd pointer has been used prior been initialized. Move the relevant code after the initialization. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-09-03arm, lib/board.c: use gd->ram_size instead of bd->bi_memsizeHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-09-03mx5: Remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFFJason Liu
CONFIG_L2_OFF is obsolete after the following commit: e47f2db5371047eb9bcd115fee084e6a8a92a239 armv7: rename cache related CONFIG flags Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF Since imx5 does not provide L2 cache operations(Enable/Disable) Simply remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFF Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc:Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-03MX31: removed warnings due to clock.hStefano Babic
2011-09-03integrator: convert to new build systemLinus Walleij
This deletes the integrator split_by_variant.sh script and defines a number of unique board types for the core modules that are meaningful to support for the Integrator AP/CP, i.e. the ones that did not just say "unsupported core module" in split_by_variant.sh. If more core modules need to be supported they are easy to add. We delete all the old cruft in Makefile and MAKEALL that was working around the old way of building boards. We create a unique config file per board to satisfy the build system, but they are just oneliners that include the existing integratorap.h and integratorcp.h configs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorcp: make the board compileLinus Walleij
This defines the requires CONFIG_SYS_* variables to make the Integrator CP board compile. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: remove hardcoded 32MB memory cmdlineLinus Walleij
The default configuration for the Integrator AP forces memory to be 32 MB on the command line to the kernel, while we have perfect information and detection of the actual memory size in the ATAGs. Delete the confusion. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: support some rudimentary commandsLinus Walleij
This adds support for a subset of the default commands for the Integrator, however since the card does not have Ethernet (unless you plug in a PCI card) we can not use the default command set. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: support the hush shellLinus Walleij
Give us some kind of sane shell environment so the bootloader can be used. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: support relocationLinus Walleij
The integrator board was apparently never converted over to support relocation until now. After this the integrator u-boot both compiles and boots on the Integrator AP. This also fixes the SDRAM memory size detection. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: make the compile work againLinus Walleij
The integratorap/cp config for u-boot was outdated and would not even compile, so fix the obvious missing bits for it to start building. After this "make ap920t_config/make all" starts working again. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03arm: lib: memcpy: Do not copy to same addressMatthias Weisser
In some cases (e.g. bootm with a elf payload which is already at the right position) there is a in place copy of data to the same address. Catching this saves some ms while booting. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-09-03arm: omap: innovator: use common code for machine typeIgor Grinberg
Innovator and H2 boards used machine_is_* macros for setting the machine type. These macros are expanded in compile time and thus leaves unreachable code (though gcc might optimize it). Switch them to use common code for machine type setting. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-09-03arm: nvidia and smdk6400: use common code for machine typeIgor Grinberg
NVIDIA boards and Samsung SMDK6400 already use a local variant of CONFIG_MACH_TYPE option. Switch to use the new common code. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-09-03MAKEALL ARMv7: Use boards.cfgDirk Behme
Use the boards from boards.cfg for building ./MAKEALL ARMV7. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2011-09-03atmel: Update support of board AT91SAM9M10G45-EK to new styleThomas Petazzoni
Based on earlier work by Alex Waterman <awaterman@dawning.com>. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03AT91: fix at91sam9g45.h to include USB Host definesReinhard Meyer
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-09-03make pm9g45 buildable for v2011.06 releaseAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> changed at91_serial_hw_init to at91_seriald_hw_init
2011-09-03make pm9263 buildable for v2011.06 releaseAsen Dimov
2011-09-03atmel: update at91sam9m10g45 SoC support to new styleThomas Petazzoni
2011-09-03pm9261: compiles with the AT91 reworked schemeAsen Dimov
2011-09-03tny_a9260/tny_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> CC: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03sbc35_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> Cc: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Removed SBC35 from MAKEALL
2011-09-03at91: reworked support for meesc boardMatthias Fuchs
The meesc board support was broken. Within this opportunity, I completely reworked the board files. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu> Signed-off-by: Matthias Fuchs <Matthias.Fuchs@esd.eu>
2011-08-31MPC8xx: fix build problem for ETX094 boardWolfgang Denk
Commit 7616e78 "Add Ethernet hardware MAC address framework to usbnet" increased the code size and broke building for the ETX094 board. Adjust the linker script to make it build again. While we are at it, remove unused u-boot.lds.debug Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-08-31phy.c: make less verbose - turn printf() into debug()Wolfgang Denk
The PHY driver was too verbose and corrupted the boot message display like this: ... Net: TSEC0 connected to Marvell 88E1111S TSEC1 connected to Marvell 88E1111S TSEC0, TSEC1 ... Turn printf() into debug() so we het the expected output again: ... Net: TSEC0, TSEC1 ... Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org>
2011-08-26Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
* 'master' of git://git.denx.de/u-boot-sh: sh: add calling mmc_initialize in board.c sh: sh7757lcr: Add KEEP order to start.o section usb: r8a66597: Fix argument mistake of inl sh: Clean up rsk7264 board settings sh: sh2a: Add sh2a optimize to config.mk sh: Fix rsk7203 alignment problem sh: Add support for SH2A freestanding build sh: Add Renesas rsk7264 board
2011-08-26Merge branch 'master' of git://git.denx.de/u-boot-ubiWolfgang Denk
* 'master' of git://git.denx.de/u-boot-ubi: ubifs: Fix bad free() sequence in ubifs_finddir()
2011-08-22sh: add calling mmc_initialize in board.cYoshihiro Shimoda
Some SH have MMC controller. So, if we need it, we have to call the mmc_initialize(). Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: sh7757lcr: Add KEEP order to start.o sectionYoshihiro Shimoda
The sh7757lcr has a local u-boot.lds because the sh7757lcr is only supported the SPI booting. This patch refers from the commit "sh: Add KEEP order to start.o section" (commit ID: b52da2aed8c2c388661f369052a97d5b5c9ed00a). Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22usb: r8a66597: Fix argument mistake of inlNobuhiro Iwamatsu
Fail in build, because argument of inl used in r8a66597_read_fifo is wrong. r8a66597.h:441:35: error: macro "inl" passed 2 arguments, but takes just 1 In file included from r8a66597-hcd.c:25: r8a66597.h: In function ‘r8a66597_read_fifo’: r8a66597.h:441: error: ‘inl’ undeclared (first use in this function) r8a66597.h:441: error: (Each undeclared identifier is reported only once r8a66597.h:441: error: for each function it appears in.) Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Clean up rsk7264 board settingsPhil Edworthy
Adjusted default settings so that we can boot zImages and uImages. Removed unused settings, use default commands and where possible calculate all other settings. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: sh2a: Add sh2a optimize to config.mkNobuhiro Iwamatsu
Only the optimization of sh2 had been supported up. This adds the optimization of sh2a. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Fix rsk7203 alignment problemPhil Edworthy
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Add support for SH2A freestanding buildPhil Edworthy
SH2A toolchains often only provide an fdpic version of libgcc. This can't be used with bare-metal software like U-Boot, so this patch provides the necessary functions extracted from libgcc. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-19ubifs: Fix bad free() sequence in ubifs_finddir()Wolfgang Denk
Free private_data member element before freeing file structure. This was causing malloc to crash. Also remove unnecessary variable assigments as file structure gets free'd as well. Signed-off-by: Rod Boyce <uboot@teamboyce.co.uk> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-08-08usb: increase non-bulk timeout for slow chipsets.Jason Cooper
If you take a look at 96820a35, you'll see the original timeout was CONFIG_SYS_HZ. Which is 1000. After the mentioned change, non-bulk timeout was changed to 100. This causes timeout failures on the dreamplug platform when trying to initialize the usb microsd reader. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-08-08USB: Move USB_PRINTF() out of ifdef in usb_scan_devices()Marek Vasut
2011-08-08USB: Set portnr so USB1.1 and 1.0 devices work on EHCI controllersMarek Vasut
2011-08-08usb: r8a66597: Fix argument mistake of inlNobuhiro Iwamatsu
2011-08-08Put common autoload code into auto_load() functionSimon Glass
This is a small clean-up patch. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-08Add documentation for USB Host NetworkingSimon Glass
This describes what it is for, devices supported, how to enable for your board in U-Boot, setting up the server, and notes about MAC addresses. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-08Add Ethernet hardware MAC address framework to usbnetSimon Glass
Built-in Ethernet adapters support setting the mac address by means of a ethaddr environment variable for each interface (ethaddr, eth1addr, eth2addr). This adds similar support to the USB network side, using the names usbethaddr, usbeth1addr, etc. They are kept separate since we don't want a USB device taking the MAC address of a built-in device or vice versa. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-08Add support for SMSC95XX USB 2.0 10/100MBit Ethernet AdapterSimon Glass
The SMSC95XX is a USB hub with a built-in Ethernet adapter. This adds support for this, using the USB host network framework. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-04mpc5200: digsy_mtc: fix extension board EEPROM I2C address for rev5Anatolij Gustschin
On newer rev5 hardware the extension board EEPROM I2C address has been changed to 0x54. Make this I2C address configurable depending on CONFIG_DIGSY_REV5 so that extention board presence detection works correctly on newer hardware. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-08-04hwmon: do not init sensors on startupHeiko Schocher
The U-Boot Design Principles[1] clearly say: Initialize devices only when they are needed within U-Boot, i.e. don't initialize the Ethernet interface(s) unless U-Boot performs a download over Ethernet; don't initialize any IDE or USB devices unless U-Boot actually tries to load files from these, etc. (and don't forget to shut down these devices after using them - otherwise nasty things may happen when you try to boot your OS). So, do not initialize and read the sensors on startup. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Holger Brunck <holger.brunck@keymile.com>
2011-08-04Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: drivers/rtc: add Marvell Integrated RTC Armada100: Add Board Support for Marvell GuruPlug-Display Armada100: MFP macro naming correction arm: auto gen asm-offsets.h for mb86r0x spear: fix build errors for spear3xx/spear600 platforms cosmetic: arm: lib/board.c: Coding Style cleanup ARM: versatile: fix board support SMDKV310: Enable device tree support SMDKV310: MMC_SPL: Fix building when using "make O=" arm: a320: enable tagged list support arm: a320: fix multiline comment style ARMv7: u8500_href: Add missing header to fix compiler warning Removed unused define, CONFIG_ARMV7. avr32: add grasshopper (ICnova AP7000) board AT91/SPI: fix atmel_dataflash_spi.c to allow building without warnings MAKEALL: remove AT91 boards that are in boards.cfg AT91: Makes AT91SAM9263-EK build correctly against u-boot-atmel/master AT91: Makes AT91SAM9263 SoC build correctly against u-boot-atmel/master AT91: Board fix for AT91SAM9261-EK AT91: SoC fix at91sam9261_matrix.h AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/master AT91: Makes AT91SAM9RL SoC build correctly against u-boot-atmel/master AT91: change common at91sam9261 files to compile with new scheme AT91: fix mistake in at91sam9260_devices.c(spi1_hw_init) a/a/c/arm920t/at91/reset.c: drop obsolete CONFIG_AT91RM9200_USART README: fix arm920t/at91 path net/eth.c: drop obsolete at91rm9200 support README.at91-soc: remove AT91(RM9200) joining notice a/a/c/arm920t/cpu.c: remove CONFIG_AT91_LEGACY warning MAKEALL: remove obsolete at91rm9200 soc ARM: remove obsolete at91rm9200 omap4: clock init support for omap4460 omap4: support TPS programming omap: reuse omap3 gpio support in omap4 omap4: sdram init changes for omap4460 omap4: add omap4460 revision detection mkimage: Add OMAP boot image support omap: add MMC and FAT support to SPL omap: add basic SPL support armv7: start.S: fixes and enhancements for SPL omap4: automatic sdram detection omap4: calculate EMIF register values omap4: add sdram init support omap4: add clock support omap4: add OMAP4430 revision check omap4: cleanup pin mux data omap4: utility function to identify the context of hw init DA8xx: fix LPSC constants DA8xx: switch an enum to defines for consistency DA8xx: add MMC/SD controller addresses DaVinci EMAC: declare function for all DA8xx CPUs DA8xx: add generic GPIO driver DaVinci: rename gpio_defs.h to gpio.h omap3evm: eth: Include functions only when necessary omap3evm: Update ethernet reset sequence for Rev.G board omap3evm: eth: split function setup_net_chip omap3: Include array definition only when it is used omap730p2: fix build breaks omap2420h4: fix build breaks omap1610inn: fix build breaks omap1510inn: fix build breaks omap5912osk: fix build breaks omap1610h2: fix build breaks
2011-08-04video: mb862xx: change controller detection messageAnatolij Gustschin
