Move this field into arch_global_data and tidy up.
These fields are not used on x86, so punt them.
[trini: Add arch/x86/cpu/cpu.c changes after Graeme's comments]
We currently assume that the global data pointer is at the start of
struct global_data. We want to remove this restriction, and it is
easiest to do this in C.
Remove the asm code and add equivalent code in C.
This idea was proposed by Graeme Russ here:
http://patchwork.ozlabs.org/patch/199741/
[trini: Apply Graeme Russ' comments
http://patchwork.ozlabs.org/patch/206305/ here, re-order]
Remove this unused field.
Move these fields into arch_global_data and tidy up.
[trini: Address tlb_size in this patch as well]
This field doesn't appear to be used for anything important, so drop it.
Move these fields into arch_global_data.
We plan to move architecture-specific data into a separate structure so
that we can make the rest of it common.
As a first step, create struct arch_global_data to hold these fields.
Initially it is empty.
This patch applies to all archs at once. I can split it if this is really
a pain.
In case a function argument is known/fixed size array in C, the argument is
still decoyed as pointer instead ( T f(U n[k]) ~= T fn(U *n) ) and therefore
calling sizeof on the function argument will result in the size of the pointer,
not the size of the array.
The VFAT code contains such a bug, this patch fixes it.
Reported-by: Aaron Williams <Aaron.Williams@cavium.com>
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Aaron Williams <Aaron.Williams@cavium.com>
Tested-by: Michal Simek <michal.simek@xilinx.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
No one expects to end up in a delayed environment if
CONFIG_DELAY_ENVIRONMENT isn't defined.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Acked-by: Allen Martin <amartin@nvidia.com>
Remove the board specific linker script. It is not
needed anymore, the unified MIPS linker script can
be used instead.
The qi_lb60 target produces a slightly different
image after the change than before. The value of
'num_got_entries' symbol is different:
@@ -49,7 +49,7 @@
801000b4: 80122d00 lb s2,11520(zero)
801000b8: 80123500 lb s2,13568(zero)
801000bc: 80123ef8 lb s2,16120(zero)
-801000c0: 00000139 0x139
+801000c0: 00000136 tne zero,zero,0x4
801000c4 <in_ram>:
801000c4: 8d0bfffc lw t3,-4(t0)
This is caused by the different placement of the
'__got_start' and '__got_end' symbols between the
board specific scrip and the unified script.
board specific script:
__got_start = .;
.got : { *(.got) }
__got_end = .;
unified script:
.got : {
__got_start = .;
*(.got)
__got_end = .;
Despite this difference, the resulting images are
functionally identical.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Xiangfu Liu <xiangfu@openmobilefree.net>
be used instead.
All dbau1x00 targets are producing identical binary
images after the change than before.
be used instead.
All incaip targets are producing identical binary
be used instead.
All vct targets are producing identical binary
be used instead.
All pb1x00 targets are producing identical binary
be used instead.
All qemu_mips targets are producing identical binary
The patch adds an unified linker script file which
can be used for all currently supported MIPS targets.
Cc: Stefan Roese <sr@denx.de>
The OUTPUT_FORMAT command in linker scripts
was always misused due to some endianess and
toolchain problems.
Use GCC flags to ensure proper output format,
and get rid of the OUTPUT_FORMAT commands in
the board specific u-boot.lds files.
The current code uses four instructions and a
temporary register to calculate the relocation
offset and to adjust the gp register.
The relocation offset can be calculated directly
from the CONFIG_SYS_MONITOR_BASE constant and from
the destination address. The resulting offset can
be used to adjust the gp pointer.
This approach makes the code a bit simpler because
it needs two instructions only.
The difference between the address of the original
and the relocated _GLOBAL_OFFSET_TABLE_ is always
the same as the relocation offset.
The relocation offset is already computed and it is
available in the 's1/t6' register. Use that to adjust
the relocated _G_O_T_ address, instead of calculating
the offset again from the _gp value.
The P2020DS build had grown too large, and video support isn't enabled
in almost any other Freescale board. Disabling it allows us to keep
building, and provides options for reenabling it later.
Signed-off-by: Andy Fleming <afleming@freescale.com>
QIXIS FPGA is accessable via both i2c and flash controller.
Only flash controller access is supported.
Add support of i2c based access. It is quite useful in the scenario
where either flash controller path is broken or not present.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
When CoreNet Fabric (CCF) internal resources are consumed by the cores,
inbound SRIO messaging traffic through RMan can put the device into a
deadlock condition.
This errata workaround forces internal resources to be reserved for
upstream transactions. This ensures resources exist on the device for
upstream transactions and removes the deadlock condition.
The Workaround is for the T4240 silicon rev 1.0.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
If property 'fsl,sec-era' is already present, it is updated.
This property is required so that applications can ascertain which
descriptor commands are supported on a particular CAAM version.
Signed-off-by: Vakul Garg <vakul@freescale.com>
Cc: Andy Fleming <afleming@gmail.com>
Configuring custom memory init value using CONFIG_MEM_INIT_VALUE in
the board config file doesn't work and memory is always initialized
to the value 0xdeadbeef. Only use this default value if a board doesn't
define CONFIG_MEM_INIT_VALUE.
Cc: Andy Fleming <afleming@freescale.com>
e6500 implements MMUv2 and supports power-of-2 page sizes rather than
power-of-4. Add support for such pages.
BSC9132QDS is a Freescale reference design board for BSC9132 SoC.
BSC9132 SOC is an integrated device that targets the evolving Microcell,
Picocell, and Enterprise-Femto base station market subsegments.
It combines Power Architecture e500v2 and DSP StarCore SC3850 core
technologies with MAPLE-B2F baseband acceleration processing elements.
BSC9132QDS Overview
2Gbyte DDR3 (on board DDR), Dual Ranki
32Mbyte 16bit NOR flash
128Mbyte 2K page size NAND Flash
256 Kbit M24256 I2C EEPROM
128 Mbit SPI Flash memory
SD slot
USB-ULPI
eTSEC1: Connected to SGMII PHY
eTSEC2: Connected to SGMII PHY
PCIe
CPRI
SerDes
I2C RTC
DUART interface: supports one UARTs up to 115200 bps for console display
Apart from the above it also consists various peripherals to support DSP
functionalities.
This patch adds support for mainly Power side functionalities and peripherals
Signed-off-by: Naveen Burmi <NaveenBurmi@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
The BSC9132 is a highly integrated device that targets the evolving
Microcell, Picocell, and Enterprise-Femto base station market subsegments.
The BSC9132 device combines Power Architecture e500 and DSP StarCore SC3850
core technologies with MAPLE-B2P baseband acceleration processing elements
to address the need for a high performance, low cost, integrated solution
that handles all required processing layers without the need for an
external device except for an RF transceiver or, in a Micro base station
configuration, a host device that handles the L3/L4 and handover between
sectors.
The BSC9132 SoC includes the following function and features:
- Power Architecture subsystem including two e500 processors with
512-Kbyte shared L2 cache
- Two StarCore SC3850 DSP subsystems, each with a 512-Kbyte private L2
cache
- 32 Kbyte of shared M3 memory
- The Multi Accelerator Platform Engine for Pico BaseStation Baseband
Processing (MAPLE-B2P)
- Two DDR3/3L memory interfaces with 32-bit data width (40 bits including
ECC), up to 1333 MHz data rate
- Dedicated security engine featuring trusted boot
- Two DMA controllers
- OCNDMA with four bidirectional channels
- SysDMA with sixteen bidirectional channels
- Interfaces
- Four-lane SerDes PHY
- PCI Express controller complies with the PEX Specification-Rev 2.0
- Two Common Public Radio Interface (CPRI) controller lanes
- High-speed USB 2.0 host and device controller with ULPI interface
- Enhanced secure digital (SD/MMC) host controller (eSDHC)
- Antenna interface controller (AIC), supporting four industry
standard JESD207/four custom ADI RF interfaces
- ADI lanes support both full duplex FDD support & half duplex TDD
- Universal Subscriber Identity Module (USIM) interface that
facilitates communication to SIM cards or Eurochip pre-paid phone
cards
- Two DUART, two eSPI, and two I2C controllers
- Integrated Flash memory controller (IFC)
- GPIO
- Sixteen 32-bit timers
This patch adds the ability for the FSL DDR interactive debugger to
automatically run the sequence of commands stored in the ddr_interactive
environment variable. Commands are separated using ';'.
ddr_interactive=compute; edit c0 d0 dimmparms caslat_X 0x3FC0; go
Signed-off-by: James Yang <James.Yang@freescale.com>
Documentation fix to README.fsl-ddr to fix typos and
to reflect use of 'd' hotkey to enter the FSL DDR debugger.
Add copy command which allows copying of DIMM/controller settings.
This saves tedious retyping of parameters for each identical DIMM
or controller.
This fix allows the name of the stage to be specifed after the
controler and DIMM is specified. Prior to this fix, if the
data stage name is not the first entry on the command line,
the operation is applied to all controller and DIMMs.
Move the FSL DDR prompt command parsing to a separate function
so that it can be reused.
Using environmental variable "ddr_interactive" to activate interactive DDR
debugging seomtiems is not enough. For example, after updating SPD with a
valid but wrong image, u-boot won't come up due to wrong DDR configuration.
By enabling key press method, we can enter debug mode to have a chance to
boot without using other tools to recover the board.
CONFIG_FSL_DDR_INTERACTIVE needs to be defined in header file. To enter the
debug mode by key press, press key 'd' shortly after reset, like one would
do to abort auto booting. It is fixed to lower case 'd' at this moment.
Signed-off-by: York Sun <yorksun@freescale.com>
In order to be able to build a u-boot.pbl image, both the
CONFIG_PBLPBI_CONFIG and CONFIG_PBLRCW_CONFIG variables have to be
defined.
This patch sets these two files for the P2041RDB board.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
All the dev boards of Freescale's QorIQ family have a RCW that is
supported by the u-boot.pbl build target. This patch adds one for the
P2041 dev board.
This RCW is suitable for the RAMBOOT_PBL scenarios and was tested on the
P2041RDB booting from the eSPI NOR Flash (P2041RDB_SPIFLASH config).
Qixis FPGA has tag data contains image name and build date.
It is helpful to identify the FPGA image precisely.
Acked-by: Timur Tabi <timur@freescale.com>
This function is called by "qixis_reset switch" command and
switch settings are calculated from qixis FPGA registers.
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
and switch settings are calculated from FPGA/qixis registers.
Remove #ifdef so that "qixis dump" command is always available
Add "qixis_reset switch" command to dump switch settings
Qixis doesn't have 1:1 switch mapping. We need to reverse engineer from
registers to figure out switch settings. Not all bits are available.
B4860QDS is a high-performance computing evaluation, development and
test platform supporting the B4860 QorIQ Power Architecture processor.
B4860QDS Overview
- DDRC1: Ten separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s,
ECC, 4 GB of memory in two ranks of 2 GB.
- DDRC2: Five separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, ECC, 2 GB of memory. Single rank.
- SerDes 1 multiplexing: Two Vitesse (transmit and receive path) cross-point
16x16 switch VSC3316
- SerDes 2 multiplexing: Two Vitesse (transmit and receive path) cross-point
8x8 switch VSC3308
- USB 2.0 ULPI PHY USB3315 by SMSC supports USB port in host mode.
- B4860 UART port is available over USB-to-UART translator USB2SER or over
RS232 flat cable.
- A Vitesse dual SGMII phy VSC8662 links the B4860 SGMII lines to 2xRJ-45 copper
connectors for Stand-alone mode and to the 1000Base-X over AMC MicroTCA
connector ports 0 and 2 for AMC mode.
- The B4860 configuration may be loaded from nine bits coded reset
configuration reset source. The RCW source is set by appropriate
DIP-switches:
- 16-bit NOR Flash / PROMJet
- QIXIS 8-bit NOR Flash Emulator
- 8-bit NAND Flash
- 24-bit SPI Flash
- Long address I2C EEPROM
- Available debug interfaces are:
- On-board eCWTAP controller with ETH and USB I/F
- JTAG/COP 16-pin header for any external TAP controller
- External JTAG source over AMC to support B2B configuration
- 70-pin Aurora debug connector
- QIXIS (FPGA) logic:
- 2 KB internal memory space including
- IDT840NT4 clock synthesizer provides B4860 essential clocks : SYSCLK,
DDRCLK1, 2 and RTCCLK.
- Two 8T49N222A SerDes ref clock devices support two SerDes port clocks
- total four refclk, including CPRI clock scheme
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Sandeep Singh <Sandeep@freescale.com>
Different personalities/derivatives of SoC may have reduced cluster. But it is
not necessary for last valid DCFG_CCSR_TP_CLUSTER register to have
DCFG_CCSR_TP_CLUSTER[EOC] bit set to represent "End of Clusters".
EOC bit can still be set in last DCFG_CCSR_TP_CLUSTER register of orignal SoC
which may not be valid for the personality.
So add initiator type check to find valid cluster.
