Based on patch by: Albert Aribaud <albert.aribaud@free.fr>
Commit 29c6fbe0471afd7ffa41fcb2103eec5b53294897 broke
building for 83xx boards with USB support:
ehci-fsl.c: In function 'ehci_hcd_init':
ehci-fsl.c:43: error: 'CONFIG_SYS_FSL_USB_ADDR' undeclared (first use in this function)
ehci-fsl.c:43: error: (Each undeclared identifier is reported only once
ehci-fsl.c:43: error: for each function it appears in.)
make[1]: *** [ehci-fsl.o] Error 1
If a NOR flash is write protected it can not be initialized/detected so
add the ability for boards to skip NOR initialization on bootup. A
board can skip NOR initialization by implementing the
board_flash_wp_on() function.
Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
CC: sr@denx.de
Add missing codes according to original datasheet.
This patch also makes ftrtc010 could be adapted to PCLK and EXT_CLK.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
This patch removes the "magic number" delays and instead
monitors state changes in the status register bits.
Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org>
Tested-by: Heiko Schocher <hs@denx.de>
Signed-off-by: Steve Sakoman <steve.sakomanlinaro.org>
This patch matches the poll interval (1 millisecond) and timeout (1 second)
used in the linux driver. It also adds a return value of 0 in the event of
a timeout error and cleans up some formatting errors in that section of the
code.
Commit 0ad7f0950a9bc0a69b3cd5f34ccf7da25fcf1c6d [ppc4xx: cleanup
default environment for AMCC boards] broke the default env for
many PPC4xx boards. The '\0' character got removed at the end
of some environment commands like "update". This patch adds the
missing '\0' characters again.
Until now, the Sequoia RAM-booting image disabled NOR flash support
as this image was mainly created for NAND-only boards. This patch
now enables NOR flash support for this RAM-booting version as well.
Add CONFIG_POST_UART to implement a board specific UART POST test.
This is done since lwmon5 needs to set POST_ALWAYS to run this
test on each reboot. And we don't want to change the default
behavious of this this.
Remove uneccessary functions to access the TCR/TSR registers as well.
uli526x.c: In function 'uli526x_init_one':
uli526x.c:314:2: warning: dereferencing type-punned pointer will break strict-aliasing rules
On an XPedite5370 over 11KBytes were saved:
Before:
332456 33364 33476 399296 617c0 ./u-boot
After:
321075 33836 33476 388387 5ed23 ./u-boot
On an XPedite5170 over 11KBytes were saved:
Before:
319488 28700 33204 381392 5d1d0 ./u-boot
After:
307663 29144 33204 370011 5a55b ./u-boot
Previously io_sel=0xe incorrect stated PCIE1 was enabled. Also add
support for the mpc8640's PCIE2 interface.
Update to use the recent, common FSL PCI initialization code.
CC: sr@denx.de
CC: joe.hamman@embeddedspecialties.com
Some OSes require that secondary cores not be initialized when they
are booted (eg VxWorks). By default when U-Boot is compiled with the
CONFIG_MP option all secondary cores are brought out of reset and held
in spinloops. Setting the "mp_holdoff" environment variable to 'yes'
or '1' will cause U-Boot to leave secondary cores in their default
state.
Signed-off-by: Aaron Sierra <asierra@xes-inc.com>
When DDR controller interleaving is eabled and less than all bank (chip-select)
interleaving is seletected, the unused chip-select should be disabled.
Signed-off-by: York Sun <yorksun@freescale.com>
800, 900, 1000, 1200MT/s data rate parameters are added for fixed sdram
setting. SPD based parameters and fixed parameters can be toggled by hwconfig.
To use fixed parameters,
hwconfig=fsl_ddr:sdram=fixed
To use SPD parameters,
hwconfig=fsl_ddr:ctlr_intlv=cacheline,bank_intlv=cs0_cs1
Using PIC TFRR register for post word load/store for generic MPC85xx.
The memory test is performed after DDR initialization when U-boot stills runs
in flash and cache. On recent mpc85xx platforms, the total memory can be more
than 2GB. To cover whole memory, it needs be mapped 2GB at a time using a
sliding TLB window. After the testing, DDR is remapped with up to 2GB memory
from the lowest address as normal.
If memory test fails, DDR DIMM SPD and DDR controller registers are dumped for
further debugging.
A worker function setup_ddr_tlbs_phys() is introduced to implement more
control on physical address mapping.
The device tree (fdt) must always exist in within the bootmap (usually the
first 16MB of RAM). If it doesn't, then boot_relocate_fdt() will allocate
an LMB region in the bootmap and copy the fdt into that region. It will
also increase the size of the fdt.
If the fdt is already in the bootmap, then previously the memory was just
reserved. There was no contingency if the reservation failed, however.
By always allocating an lmb region and copying/resizing the fdt into that
region, the code is simplified and the memory region is always allocated
properly.
Also change the types of some variables to avoid some typecasts.
Tested-by: Ira Snyder <iws@ovro.caltech.edu>
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
Add a common helper that will set the PHY connection type based on enum.
We use this on eTSEC, UCC, and will with Fman in the future.
Have a common enum for phy types that we use in the UCC driver. We will
also use this enum for dealing with phy connection fixup in the device
tree.
Last commit 3831530dcb7b71329c272ccd6181f8038b6a6dd0a was intended
"explicitly specify FAT12/16 root directory parsing buffer size, instead
of relying on cluster size". Howver, the underlying function requires
the size of the buffer in blocks, not in bytes, and instead of passing
a double sector size a request for 1024 blocks is sent. This generates
a buffer overflow with overwriting of other structure (in the case seen,
USB structures were overwritten).
CC: Mikhail Zolotaryov <lebon@lebon.org.ua>
Commit a6bd9e8 "FDT: Add fixup support for multiple banks of memory"
removed code but forgot to remove the variables used by it, resulting
in warnings:
fdt_support.c: In function 'fdt_fixup_memory_banks':
fdt_support.c:399: warning: unused variable 'sizecell'
fdt_support.c:399: warning: unused variable 'addrcell'
Remove the declarations, too.
Appendix B "EHCI 64-Bit Data Structures" of the "Enhanced Host
Controller Interface Specification for Universal Serial Bus" (Rev.
1.0, March 12, 2002) defines additional fields which were missing in
U-Boot's struct qTD; as these are also present in recent versions of
struct ehci_qtd in the Linux kernel, we add them here, too.
This fixes some nasty memory corruption problems.
Reported-by: Dan Lykowski <lykowdk@gmail.com>
See http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/76942
Cc: Remy Bohmer <linux@bohmer.net>
Cc: Dan Lykowski <lykowdk@gmail.com>
Tested-by: Stefano Babic <sbabic@denx.de>
Removed warnings generated in the mx31_set_pad() function.
Follow up to commit 620f1f6a64095ed558e68d37f1965d015cd49b02
removed compiler warning for (now) unused cmd_tbl_t* cmdtp
