1. Drop legacy emmcboot wrapper from env.
2. Change the "boot try" order. Default one is: SD -> eMMC -> USB -> DHCP
3. Drop DFU defines
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
3. Drop DFU defines
3. Drop DFU defines
This introduces automatic boot counter that increases after every
reset.After a power-on reset, it will be initialized with 1,
and each reboot will increment the value by 1. By default it's
disabled if bootlimit isn't set.
To enable this feature you have set bootcount limit ("bootlimit"),
alternate boot action ("altbootcmd") that will be performed if
the new value of bootcount exceeds the value of bootlimit, and
"upgrade_available" to let U-Boot automatically increase and save
the counter value after every reset:
> setenv bootlimit 5
> setenv upgrade_available 1
> setenv altbootcmd "bootm ..."
In case the bootlimit exceeds, the message will be shown and
albootcmd executed:
Warning: Bootlimit (5) exceeded. Using altbootcmd.
To reset bootcount run:
> bootcount reset
Print current value:
> bootcount print
s/fdt-module/fdt_module/g, as we don't use dash in fdt_file anymore.
Fixes: 4c63a601("apalis-tk1: support v1.2 hardware revision")
1. Use distro_bootcmd as default boot command instead of
legacy emmcboot wrapper.
2. Drop emmcboot and sdboot wrappers.
3. Provide proper boot order for Distro Boot.
The distro bootscript uses kernel_image to get the file name of
the kernel, so change that variable name.
UBI boot has precedence in the default boot command. If one wants
to boot from SD with a working NAND installation stop in U-Boot
and enter:
setenv fdtfile ${soc}-colibri-${fdt_board}.dtb && run distro_bootcmd
This allows to boot from SD/USB with passing the rootfs partition via UUID.
When using distro boot to boot from UBI volumes the boot partition
has been hardcoded to "UBI" (capital letters). However, our default
MTD layout uses "ubi" (lower case letter). Define "ubi" as the
default UBI partition for distro boot for Toradex. This allows to
use distro boot without having to redefine the MTD partition layout
which is useful for TorizonCore.
Define addresses required for full distro boot support.
Store all console-related kernel parameters
in dedicated variable.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This got dropped by a global 'make savedefconfig' resync as
required patches are still in flight.
Enable CONFIG_OF_SYSTEM_DEFAULT for Apalis iMX8.
As per kernel commit 0672d22a1924 ("ARM: dts: imx: Fix the AR803X phy-mode)
the correct phy-mode should be "rgmii-id", so fix it accordingly
to fix the Ethernet regression.
This problem has been exposed by commit:
commit 13114f38e2ccea9386726d8b9831dfc310589548
Author: Vladimir Oltean <vladimir.oltean@nxp.com>
Date: Thu May 7 00:11:51 2020 +0200
phy: atheros: Explicitly disable RGMII delays
To eliminate any doubts about the out-of-reset value of the PHY, that
the driver previously relied on.
If bisecting shows that this commit breaks your board you probably have
a wrong PHY interface mode. You probably want the
PHY_INTERFACE_MODE_RGMII_RXID or PHY_INTERFACE_MODE_RGMII_ID mode.
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Fix the phy-mode accordingly to fix the regression.
Migration to DM_ETH is mandatory, so convert mx6cuboxi to Ethernet
Driver Model.
This also brings the benefit of restoring Ethernet functionality.
Reported-by: Tom Rini <trini@konsulko.com>
Tested-by: Tom Rini <trini@konsulko.com>
Sync the device tree with 5.8-rc1.
It basically contains the following extra kernel commit:
commit 86b08bd5b99480b79a25343f24c1b8c4ddcb5c09
Author: Russell King <rmk+kernel@armlinux.org.uk>
Date: Wed Apr 15 16:44:17 2020 +0100
ARM: dts: imx6-sr-som: add ethernet PHY configuration
Add ethernet PHY configuration ahead of removing the quirk that
configures the clocking mode for the PHY. The RGMII delay is
already set correctly.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
, which passes the 'qca,clk-out-frequency' property and it is important
to specify the correct frequency generated by the AR8035.
As we move towards driver model, it is required to let the FEC driver
know how to properly deal with an Ethernet PHY subnode in the device tree.
For example:
&fec {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_microsom_enet_ar8035>;
phy-handle = <&phy>;
phy-mode = "rgmii-id";
phy-reset-duration = <2>;
phy-reset-gpios = <&gpio4 15 GPIO_ACTIVE_LOW>;
status = "okay";
mdio {
#address-cells = <1>;
#size-cells = <0>;
phy: ethernet-phy@0 {
reg = <0>;
qca,clk-out-frequency = <125000000>;
Currently the PHY node pointer is incorrectly associated with the
Ethernel controller instead of the PHY node itself.
This causes the PHY properties, such as "qca,clk-out-frequency" in
the example above to not get parsed.
Fix this problem by populating the phy_of_node node.
Suggested-by: Vladimir Oltean <vladimir.oltean@nxp.com>
The clock ouput frequency is calculated incorrectly for AR8035 due to
wrong masking of priv->clk_25m_reg and priv->clk_25m_mask.
This same issue has been already fixed in the kernel by:
commit b1f4c209d84057b6d40b939b6e4404854271d797
Author: Oleksij Rempel <o.rempel@pengutronix.de>
Date: Wed Apr 1 11:57:32 2020 +0200
net: phy: at803x: fix clock sink configuration on ATH8030 and ATH8035
The masks in priv->clk_25m_reg and priv->clk_25m_mask are one-bits-set
for the values that comprise the fields, not zero-bits-set.
This patch fixes the clock frequency configuration for ATH8030 and
ATH8035 Atheros PHYs by removing the erroneous "~".
To reproduce this bug, configure the PHY with the device tree binding
"qca,clk-out-frequency" and remove the machine specific PHY fixups.
Fixes: 2f664823a47021 ("net: phy: at803x: add device tree binding")
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Russell King <rmk+kernel@armlinux.org.uk>
Tested-by: Russell King <rmk+kernel@armlinux.org.uk>
Apply the same fix in the U-Boot driver.
Tested on a i.MX6 Hummingboard.
Reviewed-by: Michael Walle <michael@walle.cc>
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-07-rc5 (2)
Fix memory reservations: do not use random bytes from the stack.
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- fix SD card cart detect on DHCOM and ST boards
The cd-gpios with (GPIO_ACTIVE_LOW | GPIO_PULL_UP) gpio is thus far
unsupported, reinstate the old cd-gpios behavior until this handling
is fully implemented. This avoid potential issue for SDCard boot:
the card detect fails with floating gpio.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
is fully implemented. This permits the DHSOM to boot from SD again,
without this patch the card detect fails.
Cc: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
fdtdec_get_addr_size reads the uses a fixed value for address & size
cell properties which may not be correct always.
Use the auto variant of the function which automatically reads
#address-cells & #size-cells from parent and uses to read the "reg"
property.
Signed-off-by: Atish Patra <atish.patra@wdc.com>
On 32 bit systems fdt_addr_t may be 4 bytes long but size is defined as
u64. Avoid filling the upper 4 bytes of the sizep parameter of
fdtdec_get_addr_size_auto_parent() with random bytes from the stack by
defining a separate variable fdt_size.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
This allows Nano to use the key M.2 on the CVB to connect and use a M.2
NVMe SSD stick. Works on my Nano B00, WD SN750 NVMe SSD shows up
w/'nvme' commands. Will add booting from NVMe via distro cmds in a future
patch.
Signed-off-by: Tom Warren <twarren@nvidia.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-video
- fix stdout in default environment for apalis_imx6, colibri_imx6
and cm_fx6 boards
Take over maintainership for Colibri T20 module.
Acked-by: Lucas Stach <dev@lynxeye.de>
The PSCI nodes are currently not populated for the Tegra210 and Tegra186
devices. This prevents the PSCI driver from being able to identify the
PSCI method used by these devices and causes the probe of the PSCI
driver to fail.
Since commit 81ea00838c68 ("efi_loader: PSCI reset and shutdown") was
added, which moves the PSCI EFI system reset handler into the PSCI
driver, this has prevented the EFI system reset from working for
Tegra210 and Tegra186. Therefore, populating these nodes is necessary
to fix the EFI system reset for Tegra210 and Tegra186.
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
When CONFIG_OF_LIVE is enabled, dev_of_offset() cannot be used and
if used returns an invalid offset. This causes the call to
fdt_stringlist_get() in the psci_probe() to fail to read the 'method'
property from the PSCI node for the device and hence prevents PSCI
from working. Fix this by using the ofnode_read_string() API instead
of the fdt_stringlist_get() because this will handle reading the
property both when CONFIG_OF_LIVE is enabled or disabled.
Due to the above problem and since commit 81ea00838c68 ("efi_loader:
PSCI reset and shutdown") was added, the EFI system reset has been
broken for Tegra210 and Tegra196 platforms. This also fixes the EFI
system reset for these Tegra platforms.
- Add guestfstools, efitools
- Latest Ubuntu/bionic snapshot
The ethernet PHY on all known Gen3 boards takes a while to come out
of reset, increase the auto-negotiation timeout to prevent it from
timing out in case the ethernet is used right after the board was
reset.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
After migration to DM 'vga' name is not longer supported,
change it to 'vidconsole' in the default environment.
Acked-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic
- move amlogic board documentation into doc/board in RsT format
Add the recently added reStructuredText board documentation in the
appropriate MAINTAINERS files.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Move the natural text Amlogic board README files to doc/board/amlogic
into reStructuredText and :
- add reStructuredText markup for bash code
- fix secondary titles markup
- move board support into global support matrix
- fix boot with OP-TEE for stm32mp15 boards
Add OP-TEE firmware node in stm32mp15 U-Boot DTSI. This node is
needed since commit [1] that changed U-Boot/stm32mp15 to detect
OP-TEE availability by probing the resource instead of relying on
U-Boot configuration. The software sequence implemented by [1] is
fine but U-Boot DTS/DTSI files were not updated accordingly since,
hence OP-TEE presence is never detected by U-Boot, preventing Linux
kernel from using OP-TEE resources.
For consistency and to synchronize stm32mp15 DTSI files (excluding
U-Boot specific DTSI files) with the Linux kernel ones, this change
also moves the OP-TEE reserved memory nodes from board generic DTSI
files to U-Boot specific board DTSI files.
Link: [1] commit 43df0a159df6 ("stm32mp1: dynamically detect op-tee presence")
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Fix the sequence in stm32mp1 fdt.c that disables OP-TEE resources
defined in FDT when U-boot detects OP-TEE firmware is not present.
Before this change, helper function stm32_fdt_disable_optee()
set property status to "disabled" for the OP-TEE reserved memory
nodes but this has no impact since Linux kernel does not consider
the status property for reserved-memory subnodes. This change
make U-Boot to attempt to delete the node instead.
Fixes: 4a1b975dac02 ("board: stm32mp1: reserve memory for OP-TEE in device tree")
Use correct printf code in efi_image_parse().
Add random number generation to HTML documentation.
The fix in commit b7adcdd073c0 has the side-effect that the regulator
will be disabled when requesting the relevant gpio in
regulator_common_ofdata_to_platdata() and enabled in
regulator_pre_probe() when the regulator was already enabled.
This leads to a short interruption in the 3.3V power to the PCIe
slot on the firefly-rk3399 which makes an ADATA SX8000NP NVMe SSD
unhappy.
Fix this by setting the GPIOD_IS_OUT_ACTIVE flag again when the
'regulator-boot-on' property is set, but check for this property
explicitly instead of relying on the "boot_on" member of
the uclass platdata.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
- Assorted bug fixes
Update the comment for SYS_RELOC_GD_ENV_ADDR as gd->env_addr is updated
in board_r.c::initr_reloc_global_data() under the compilation flags
CONFIG_SYS_RELOC_GD_ENV_ADDR
Several configutation options require additional memory before relocation:
* CONSOLE_RECORD
* LOG
* RSA
The current default of 0x400 is too small to encompass them all. Increase
the value of SYS_MALLOC_F_LEN to 0x2000 for ARCH_QEMU.
This reverts commit 0486497e2b5f4d36fa968a1a60fea358cbf70b65.
The strtoul has well-defined semantics. It is defined by the C standard and
POSIX. To quote the relevant section of the man pages,
> If base is zero or 16, the string may then include a "0x" prefix, and the
> number will be read in base 16; otherwise, a zero base is taken as 10
> (decimal) unless the next character is '0', in which case it is taken as
> 8 (octal).
Keeping these semantics is important for several reasons. First, it is very
surprising for standard library functions to behave differently than usual.
Every other implementation of strtoul has different semantics than the
implementation in U-Boot at the moment. Second, it can result in very
surprising results from small changes. For example, changing the string
"1f" to "20" causes the parsed value to *decrease*. Forcing use of the "0x"
prefix to specify hexidecimal numbers is a feature, not a bug. Lastly, this
is slightly less performant, since the entire number is parsed twice.
This fixes the str_simple_strtoul test failing with
test/str_ut.c:29, run_strtoul(): expect_val == val: Expected 0x44b (1099), got 0x1099ab (1087915)
test/str_ut.c:46, str_simple_strtoul(): 0 == run_strtoul(uts, str2, 0, 1099, 4): Expected 0x0 (0), got 0x1 (1)
Signed-off-by: Sean Anderson <seanga2@gmail.com>
CC: Michal Simek <michal.simek@xilinx.com>
CC: Shiril Tichkule <shirilt@xilinx.com>
s/booot/boot/g
The first ase is booot instead of boot and second u-booot instead of
u-boot.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Fix the loop that parses FDT for a reserved memory node named "optee".
Before this change, if at least one subnode was found in the
reserved-memory node, the function endlessly looped since instruction
continue returned back in the loop without updating variable subnode.
This change fixes the issue by using a for loop.
Fixes: 6ccb05eae01b ("image: fdt: copy possible optee nodes to a loaded devicetree")
