Several boards used different ways to specify the size of the
protected area when enabling flash write protection for the sectors
holding the environment variables: some used CONFIG_ENV_SIZE and
CONFIG_ENV_SIZE_REDUND, some used CONFIG_ENV_SECT_SIZE, and some even
a mix of both for the "normal" and the "redundant" areas.
Normally, this makes no difference at all. However, things are
different when you have to deal with boards that can come with
different types of flash chips, which may have different sector
sizes.
Here we may have to chose CONFIG_ENV_SECT_SIZE such that it fits the
biggest sector size, which may include several sectors on boards using
the smaller sector flash types. In such a case, using CONFIG_ENV_SIZE
or CONFIG_ENV_SIZE_REDUND to enable the protection may lead to the
case that only the first of these sectors get protected, while the
following ones aren't.
This is no real problem, but it can be confusing for the user -
especially on boards that use CONFIG_ENV_SECT_SIZE to protect the
"normal" areas, while using CONFIG_ENV_SIZE_REDUND for the
"redundant" area.
To avoid such inconsistencies, I changed all sucn boards that I found
to consistently use CONFIG_ENV_SECT_SIZE for protection. This should
not cause any functional changes to the code.
Cc: Paul Ruhland
Cc: Pantelis Antoniou <panto@intracom.gr>
Cc: Stefan Roese <sr@denx.de>
Cc: Gary Jennejohn <garyj@denx.de>
Cc: Dave Ellis <DGE@sixnetio.com>
Return value of mmc_send_if_cond() can be safely ignored (as it is
done in Linux). This makes older cards work with MXC MCI controller.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This patch now enabled this cfi-mtd wrapper to correctly detect and
erase the last sector in an NOR FLASH device.
CS4 on SPI0 has a dedicated PH8 pin which needs to be enabled as a
peripheral in order to work.
A missing set of parenthesis caused the silicon revision to apply only to
the BF533 and not the BF531/BF532 variants.
Currently using JFFS2 with MTDPARTS enabled doesn't work. This is because
mtdparts_init() is available in both files, cmd_mtdparts.c and
cmd_jffs2.c. Please note that in the original cmd_jffs2.c file (before
the jffs2/mtdparts command/file split those 2 different versions
already existed. So this is nothing new. The main problem is that the
variables "current_dev" and "current_partnum" are declared in both
files now. This doesn't work.
This patch now changes the names of those variable to more specific
names: "current_mtd_dev" and "current_mtd_partnum". This is because
this patch also changes the declaration from static to global, so
that they can be used from both files.
Please note that my first tests were not successful. The MTD devices
selected via mtdparts are now accessed but I'm failing to see the
directory listed via the "ls" command. Nothing is displayed. Perhaps
I didn't generate the JFFS2 image correctly (I never used JFFS2 in
U-Boot before). Not sure. Perhaps somebody else could take a look at
this as well. I'll continue looking into this on Monday.
Cc: Detlev Zundel <dzu@denx.de>
Cc: Ilya Yanok <yanok@emcraft.com>
Cc: Renaud barbier <renaud.barbier@ge.com>
The pins for async memory where parallel flash lives are not enabled by
default, so make sure we mux them as needed.
Signed-off-by: Graf Yang <graf.yang@analog.com>
This patch enables Smart Media (SMC) ECC byte ordering which is used
on the PPC4xx NAND FLASH controller (NDFC). Without this patch we have
incompatible ECC byte ordering to the Linux kernel NDFC driver.
Acked-by: Scott Wood <scottwood@freescale.com>
This patch now uses the correct ECC byte order (Smart Media - SMC)
to be used on the 4xx NAND FLASH driver. Without this patch we have
Please note that we also have to enable CONFIG_MTD_NAND_ECC_SMC in
drivers/mtd/nand/nand_ecc.c for correct operation. This is done with
a seperate patch.
This patch moves the definition for the PPC4xx NAND FLASH controller
(NDFC) CONFIG_NAND_NDFC into include/ppc4xx.h. This is needed for the
upcoming fix for the ECC byte ordering of the NDFC driver.
cmd_ide.c:547: error: inline function 'ide_inb' cannot be declared weak
removing the inline attribute fixes it.
Configuring for TQM834x board...
cpu_init.c: In function 'cpu_init_f':
cpu_init.c:262: warning: array subscript is above array bounds
cpu_init.c:263: warning: array subscript is above array bounds
cpu_init.c:270: warning: array subscript is above array bounds
Return -ENODEV instead of 0 when trying to read from a non existing volume.
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
The timer_init() function was not using the right csync instruction, nor
was it doing it right after disabling the core timer.
The timer_reset() function would reset the timestamp, but not the actual
timer, so there was a common edge case where get_timer() return a jump of
one timestamp (couple milliseconds) right after resetting. This caused
many functions to improperly timeout right away.
This fixes the following build warnings:
board.c: In function 'board_init_r':
board.c:328: warning: unused variable 'i'
board.c:326: warning: unused variable 'e'
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
All these functions are expected to be static inline-ed.
This patch also fixes the following build warnings on MIPS targets:
include/asm/bitops.h: In function 'ext2_find_next_zero_bit':
include/asm/bitops.h:862: warning: '__fswab32' is static but used in inline function 'ext2_find_next_zero_bit' which is not static
include/asm/bitops.h:885: warning: '__fswab32' is static but used in inline function 'ext2_find_next_zero_bit' which is not static
include/asm/bitops.h:887: warning: '__fswab32' is static but used in inline function 'ext2_find_next_zero_bit' which is not static
Implement ethernet halt() by putting MAC0 in reset.
If we do not do this, we will get memory corruption
when ethernet frames are received during early OS boot.
Signed-off-by: Thomas Lange <thomas@corelatus.se>
Update CHANGELOG.
U-Boot does not currently build for PXA platforms with USB support
enabled:
usb.c:46: error: 'UP2OCR' undeclared (first use in this function)
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Markus Klotzbuecher <mk@denx.de>
Edited commit message.
Commit 574b319512 introduced a subtle bug by mixing a list of tests
for "dev_desc->type" and "dev_desc->if_type" into one switch(), which
then mostly did not work because "dev_desc->type" cannot take any
"IF_*" type values. A later fix in commit 8ec6e332ea changed the
switch() into testing "dev_desc->if_type", but at this point the
initial test for unknown device types was completely lost, which
resulted in output like that for IDE ports without device attached:
Device 1: Model: Firm: Ser#:
Type: # 1F #
Capacity: not available
This patch re-introduces the missing test for unknown device types.
Tested-by: Stefan Roese <sr@denx.de>
This patch fixes a problem in the CPU frequency calculation. Without it
a 798MHz CPU is displayed as 368.503 MHz. And with it it's 798 MHz.
Signed-off-by: Detlev Zundel <dzu@denx.de>
The 'inline' is conflicting with the semantic of 'weak' attribute and with the
way the show_boot_progress() function is used.
Also gcc 4.4 is complaining about it:
main.c:51: error: inline function 'show_boot_progress' cannot be declared weak
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
cpu/mpc8260/cpu.c used to use do_fixup_by_path_u32() to update the
clock frequencies in the device tree, using a CPU path
"/cpus/OF_CPU", with OF_CPU beind defined in the board config file.
However, this does not work when one board config file (here:
MPC8260ADS.h) is intended to be used for several diffrent CPUs and
therefor contains a generic definition like "cpu@0", as the device
trees that will then be loaded will contain specific names like
"PowerPC,8272@0".
We switch to using do_fixup_by_prop_u32() instead, so we can search
for device_type="cpu", as it is done in other architectures, too.
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Heiko Schocher <hs@denx.de>
Add CONFIG_SYS_MONITOR_LEN macro to apollon board config.
CONFIG_SYS_MONITOR_LEN defines the U-Boot image size.
and is used by OneNAND ipl when reading U-Boot image.
Signed-off-by: Rohit Hagargundgi <h.rohit at samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
This will make CONFIG_NET_MULTI the only net driver configuration and
we'll be able to remove this option.
The pin which was used in preliminary versions of the board for ide
reset is really connected to the rtc clock.
This patch adds, under tools folder, a new command called imls. Its
goal is the same of UBoot's imls but it can be used as Linux shell
command. It reads from raw mtd partition and prints the list of the
stored images.
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Fix some issues introduced from commit:
2f70c49e5b9813635ad73666aa30f304c7fdeda9
suggested by Mike Frysinger.
- added some comment for the env_id variable in common_cmd_nvedit.c
- moved some variables in fn scope instead of file scope
- NetInitLoop now static void
Acked-by: Ben Warren <biggerbadderben@gmail.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
I never acked a patch that adds me as phycore i.MX31 maintainer nor was
it me who pushed the patches, so remove myself from the maintainer list
so that other people do not longer wait for my ack.
AFEB9260 uses PA10, PA11 for ETX2 and ETX3.
Also, due to extarnal pull-up on IRQ line, Micrel PHY ID is 1 after reset sequence,
not 0.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
We don't know what state the ethernet PHY is in when starting up, so make
sure we set it to a sane state. This fixes troubles seen when Linux boots
up, configures the PHY is a non-default state, and then the system reboots
into U-Boot which previously expected a reset state only.
The BF527-EZKIT settings for storing the environment in SPI flash wasn't
using the correct sector settings for the SPI flash part that is actually
on the board.
When the clock functions were changed to use cached values (and thereby
avoiding expensive math functions), early serial debug broke because the
baud programming is called before external memory is available.
When dropping jump block support, the assumption was that all bootroms
supported entry point redirection via the EVT1 register. Unfortunately,
this turned out to be incorrect for the oldest Blackfin parts (BF533-0.2
and older and BF561). No one really noticed earlier because these parts
usually are booted by bypassing the bootrom entirely, and older BF533
parts are not supported at all (too many anomalies).
Make sure we recurse through serial_putc() rather than bang on the UART
transmit register directly to avoid hardware overflows when using \n.
Update CHANGELOG.
lowlevel_init.S is not used any more so remove it.
As consequence, we also don't have to generate u-boot.lds
but can use a static version as before.
This also fixes the out-of-tree build problem introduced
with commit f0a2c7b4 "at91: add support for the PM9263 board"
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
The Beagle Rev C boards pull UART2 from an alternate set of balls.
Signed-off-by: Steve Sakoman <steve@sakoman.com>
