Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Due to changes in distro environment, ENV_SIZE limit was reached on Dragonboard.
This patch increases environment size to 8KiB.
Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
The following changes are made to the clock API:
* The concept of "clocks" and "peripheral clocks" are unified; each clock
provider now implements a single set of clocks. This provides a simpler
conceptual interface to clients, and better aligns with device tree
clock bindings.
* Clocks are now identified with a single "struct clk", rather than
requiring clients to store the clock provider device and clock identity
values separately. For simple clock consumers, this isolates clients
from internal details of the clock API.
* clk.h is split so it only contains the client/consumer API, whereas
clk-uclass.h contains the provider API. This aligns with the recently
added reset and mailbox APIs.
* clk_ops .of_xlate(), .request(), and .free() are added so providers
can customize these operations if needed. This also aligns with the
recently added reset and mailbox APIs.
* clk_disable() is added.
* All users of the current clock APIs are updated.
* Sandbox clock tests are updated to exercise clock lookup via DT, and
clock enable/disable.
* rkclk_get_clk() is removed and replaced with standard APIs.
Buildman shows no clock-related errors for any board for which buildman
can download a toolchain.
test/py passes for sandbox (which invokes the dm clk test amongst
others).
This adds a sandbox reset implementation (provider), a test client
device, instantiates them both from Sandbox's DT, and adds a DM test
that excercises everything.
A reset controller is a hardware module that controls reset signals that
affect other hardware modules or chips.
This patch defines a standard API that connects reset clients (i.e. the
drivers for devices affected by reset signals) to drivers for reset
controllers/providers. Initially, DT is the only supported method for
connecting the two.
The DT binding specification (reset.txt) was taken from Linux kernel
v4.5's Documentation/devicetree/bindings/reset/reset.txt.
Tegra186's HSP module implements doorbells, mailboxes, semaphores, and
shared interrupts. This patch provides a driver for HSP, and hooks it
into the mailbox API. Currently, only doorbells are supported.
Rename mailbox*.h to match the naming convention requested during review
of the new reset subsystem.
The documentation of parameters in arch/sandbox/include/asm/gpio.h is
either missing or faulty.
This patch corrects the documentation.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
A number of style fixes across the files in this directory, including:
* Correct invalid kernel-doc content.
* Tidy up massive comment in fdt_region.c.
* Use correct spelling of "U-Boot".
* Replace tests of "! <var>" with "!<var>".
* Replace "libfdt_env.h" with <libfdt_env.h>.
A bug in the pca953x driver prevents correct reading of GPIO input
values beyond the 8th GPIO; all values are reported as zero. Setting of
GPIO output values is not affected.
This patch fixes the reading behavior.
Reviewed-by: Peng Fan <van.freenix@gmail.com>
Some architectures as m68k still need to use CONFIG_NEEDS_MANUAL_RELOC,
and are not still using the device tree.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
I do not insist on CONFIG_BOOTDELAY=3. The default value in Kconfig,
CONFIG_BOOTDELAY=2, is just fine for these boards.
The DRAM PHY layer on PH1-LD20 is able to calibrate PHY parameters
periodically. This compensates for the voltage and temperature
deviation and improves the PHY parameter adjustment. Instead, it
requires 64 byte scratch memory in each DRAM channel for the dynamic
training. The memory regions must be reserved in DT before jumping
to the kernel.
The scratch area can be anywhere in each DRAM channel, but the DRAM
init code in SPL currently assigns it at the end of each channel.
So, it makes sense to reserve the regions on run-time by U-Boot
instead of statically embedding it in the DT in Linux. Anyway,
a boot-loader should know much more about memory initialization
than the kernel.
I just did not notice this option had an entry in Kconfig.
This will make it easier to select config options specific to
particular ARM processor generation.
At first, 256 byte of the head of DRAM space was reserved for some
reasons. However, as the progress of development, it turned out
unnecessary, and it was never used in the end. Move the CPU release
address to leave no space.
Correct the error message in spl_load_image_ext() when image parsing
fails. Instead of "ext4fs_read failed" print "failed to parse image
header".
Signed-off-by: Petr Kulhavy <brain@jikos.cz>
CC: Guillaume GARDET <guillaume.gardet@free.fr>
CC: Tom Rini <trini@konsulko.com>
Fix the following build errors when building sandbox on x86 32-bit:
In file included from fs/cbfs/cbfs.c:8:0:
include/malloc.h:364:7: error: conflicting types for 'memset'
void* memset(void*, int, size_t);
In file included from include/compiler.h:123:0,
from include/cbfs.h:10,
from fs/cbfs/cbfs.c:7:
include/linux/string.h:78:15: note: previous declaration of 'memset' was here
extern void * memset(void *,int,__kernel_size_t);
include/malloc.h:365:7: error: conflicting types for 'memcpy'
void* memcpy(void*, const void*, size_t);
include/linux/string.h:81:15: note: previous declaration of 'memcpy' was here
extern void * memcpy(void *,const void *,__kernel_size_t);
scripts/Makefile.build:280: recipe for target 'fs/cbfs/cbfs.o' failed
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
CONFIG_VERSION_VARIABLE isn't always defined, so we can't simply look up
its value directly, or an exception will occur if it isn't defined.
Instead, we must use .get() to supply a default value if the variable
isn't defined.
Fixes: da37f006e7c5 ("tests: py: disable main_signon check for printenv cmd")
Acked-by: Heiko Schocher <hs@denx.de>
arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h
Currently DFU is not working.
Adjust CONFIG_SYS_MALLOC_LEN and dfu_alt_info so that we are
able to flash u-boot.imx into the eMMC via dfu using the
following method:
=> dfu 0 mmc 0
In the host PC:
dfu-util -D u-boot.imx -a boot
This is the same approach done in the mx6sl warp board.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Add a README file for helping users to install U-Boot into the eMMC.
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
The latest version of warp7 board provides the connection of the
WDOG1_B pin to the PMIC.
Program the watchdog to enable the WDOG1_B output which causes
a POR reset.
Based on the imx7dsabresd code.
The current pad DSE for QSPI is 60ohm. This setting cause
too strong drive to clock and data signals. Need to change
the DSE to 120ohm for better signal quality.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Q901 is PMOS, LCD_nPWREN should be at low voltage then output is 3V3.
If LCD_nPWREN is high, output is 2.4V which is not correct.
Fix 74LV OE gpio index. gpio index is wrong,
so gpio output will not have effect, since we
use wrong GPIO5_IO18, but not correct GPIO5_IO8.
And at the end of the initialization of 74lv init, should
keep OE voltage level at LOW to make 74lv output the correct
voltage.
LCD_PWR_EN controls the G pin of Q13 PMOS which needs low voltage to connect
D to S for outputting LCD 3.3V. If LCD_PWR_EN is high, we measured the LCD 3v3
is actually 1.2V.
Signed-off-by: Ye Li <ye.li@nxp.com>
Currently the LVDS backlight does not work in U-Boot after a “reboot” comand
in the kernel.
This problem occurs because the kernel uses this pin in PWM mode and U-Boot
does not configure the backlight pin as GPIO functionality.
So fix the problem by explicitly configuring the backlight pin as GPIO in
U-Boot.
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
If the usb controller is not running, no need to shutdown it,
otherwise `usb stop` complains about:
"EHCI failed to shut down host controller".
To i.MX7D SDB, there are two usb ports, one Host, one OTG.
If we only plug one udisk to the Host port and then `usb start`,
the OTG controller for OTG port does not run actually. Then,
if `usb stop`, the OTG controller for OTG port will also be
shutdown, but it is not running.
This patch adds a check to only shutdown the running controller.
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: "Stefan Brüns" <stefan.bruens@rwth-aachen.de>
Cc: Stephen Warren <swarren@nvidia.com>
For legacy usb storage driver, USB_MAX_STOR_DEV is defined as 7.
If we only have one usb disk on board, `usb dev 0` is ok.
But if `usb dev 1`, still ok, then `usb read xxx` will trigger
system fault and reboot.
So check if_type before using this device.
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Cc: Peng Fan <peng.fan@nxp.com>
The setjmp/longjmp implementation did not work on thumb1 implementations
because it used instruction encodings that don't exist on thumb1 yet.
This patch limits itself to thumb1 instruction set for 32bit arm and
removes a superfluous printf along the way.
enable basic DM/DTS support for the siemens am335x based boards.
add missing USB_MUSB_* and CONFIG_G_DNL_*
board configuration.
Enable FIT support for AM57xx platforms using the high-security (HS)
device variant.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
twister board was not updated after changing
SPL defines, resulting in a broken board.
I no longer have access to such a board
Signed-off-by: Thomas Lange <thomas@corelatus.se>
Remove redundant #if defined(CONFIG_SPL_OS_BOOT) statement around
getenv() calls in spl_load_image_ext_os().
The whole function is surrounded by #ifdef CONFIG_SPL_OS_BOOT.
No functional change.
Acked-by: Guillaume GARDET <guillaume.gardet@free.fr>
The comments in the source file are riddled with spelling mistakes. Be
a good citizen and take a stab at cleaning up some of the more obvious
ones.
Adds FIT support to the SPL and u-boot for AM437x HS devices.
Signed-off-by: Madan Srinivas <madans@ti.com>
Adds missing NAND option to CONFIG_SYS_EXTRA_OPTIONS for
AM437x HS EVMs. This syncs up the config options between
GP and HS EVMs.
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The value of 0 is fairly uncommon while 2 is one of the more common ones
so switch.
Add support for loading splash image from NAND Flash formatted with a (UBI) filesystem.
Signed-off-by: Eran Matityahu <eran.m@variscite.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
This patch is doing the following:
1. Implementing the errata for LS2080.
2. Adding fixup for fdt for LS2080.
Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
This errata a008751 is applied on Soc specific file currently.This will be
moved to a file where all the errata implementation will take place for usb
for fsl. This patch removes the errata workaround from soc specific file
for LS2080.
