2010-09-30p1022ds: Fix the DIU issue on RevB1 board2009.11-p1022ds-201004291116Dave Liu
DIU doesn't work on P1022DS RevB1 board in u-boot, it is because there are two code bugs in DIU code. 1) We must clear the PMUXCR[eLBC_DIU] bits before we set the eLBC_DIU=2'b01 for DIU mode. The PMUXCR[eLBC_DIU] POR value is 2'b10 in RevB1 board, however the eLBC_DIU is 2'b00 in RevA board due to design issue. 2) We must do dummy read to make sure the write FPGA PIXIS register be completed. Signed-off-by: Dave Liu <daveliu@freescale.com>
2010-09-29P1022DS: Enable ddr_sdram_cfg[hse] for the platformSrikanth Srinivasan
This patch enables DDR_SDRAM_CFG[HSE] for P1022DS. This is needed mainly for higher frequencies but can be left on for < 800MHz DDR frequency. Disabled DDR_SDRAM_CFG[2T_EN] for 800MHz operation. Also added debug prints for additional ddr registers. Tested with the Hynix HMT125U7BFR8C-H9 and ELPIDA EBJ21EE8BAFA-DJ-E, passed at 667MT/s or 800MT/s. Tested-by: Jiang Yutang <B14898@freescale.com> Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
2010-09-29Enabling ZQ calibration control for FSL DDR3 by defaultSrikanth Srinivasan
Enable ZQ calibration control by default for DDR3 for FSL DDRC driver. Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
2010-09-29DIU: change the I/O read/write code styleJerry Huang
For e500v2 toolchain, these IO read/write can't run rightly. These patch has been built with e500mc and e500v2 toolchain, DIU can work. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29p1022ds: disable the DDR ECCJerry Huang
2010-09-29p1022ds: add the support for automatic self refreshDave Liu
2010-09-29p1022ds: DIU (LVDS and DVI) supportJerry Huang
FSL DIU (including DVI and LVDS) support Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29p1022ds: get the env variable addressJerry Huang
Get the environment variable address Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29Add support for save environment variable to MMC/SD cardMingkai Hu
Whether booting from MMC/SD card or not, the environment variables can be saved on it, this patch add the operation support. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
2010-09-29Make mmc init come before env_relocateMingkai Hu
If the environment variables are saved on the MMC/SD card, env_relocat can't relocate env from MMC/SD card without mmc init. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
2010-09-29p1022ds: save env to eSDHC/eSPIJerry Huang
save the environment variable to eSDHC/eSPI Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29eSDHC: add the reset function to reset the eSDHC controllerJerry Huang
Reset the eSDHC controller first before initialize the eSDHC controller. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29p1022ds: pin mult setting for eSDHC bootJerry Huang
Enable the eLBC pads when booting from eSDHC Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29p1022ds: On-Chip ROM boot supportJerry Huang
Including boot from eSDHC and eSPI. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29eSPI and eSPI controller supportJerry Huang
This patch is from MPC8536, and fixed some hunk failed error. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Singed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29P1022DS: eSPI supportsJerry Huang
eSPI support for p1022ds Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29SDHCI: fixed the clock mask and the max clockJerry Huang
The max clock of MMC is 52MHz, and the clock mask is wrong. Therefore, fixed them. Signed-off-by: Jerry Huang <Changm-Ming.Huang@freescale.com>
2010-09-29P1022: Auto CMD12 support for eSDHC driver of p1022dsJerry Huang
Auto CMD12 command support for P1022DS eSDHC driver. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29SD/MMC: multiple block read supportLi Yang
Multiple block read support Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
2010-09-29NET: Base support for etsec2.0Sandeep Kumar
1. Modified the tsec_mdio structure to include the new regs 2. Modified the MDIO_BASE_ADDR so that it will handle both older version and new version of etsec. Signed-off-by: Sandeep Kumar <Sandeep.Kumar@freescale.com>
2010-09-29NET: Move MDIO regs out of TSEC SpaceSandeep Kumar
Moved the mdio regs out of the tsec structure,and provided different offsets for tsec base and mdio base so that provision for etsec2.0 can be provided. This patch helps in providing the support for etsec2.0 In etsec2.0, the MDIO register space and the etsec reg space are different. Also, moved the TSEC_BASE_ADDR and MDIO_BASE_ADDR definitons into platform specific files. Signed-off-by: Sandeep Kumar <Sandeep.Kumar@freescale.com>
2010-09-29esdhc errata workaroundSrikanth Srinivasan
In Rev 1.0 of P1022, in the esdhc Host Capabilities register the 1.8V bit is set; it should not be. So we exclude this setting in the driver. Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
2010-09-29fixed for sata errataSrikanth Srinivasan
On P1022, the data snoop bit (in the sata ip) is at bit 28. Account for this. Additionally, change the mode to enterprise mode since on reset, it is in legacy mode. Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
2010-09-29p1022ds supportSrikanth Srinivasan
This patch adds support for P1022DS to u-boot. The following items have been tested - DDR (spd-based), I2C, Flash, Vetsec1, 2, DIU, PEX 1,2,3. Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
2009-12-15Update CHANGELOG; prepare Prepare v2009.11v2009.11Wolfgang Denk
2009-12-15mpc85xx, mpc86xx: Fix gd->cpu pointer after relocationPeter Tyser
The gd->cpu pointer is set to an address located in flash when the probecpu() function is called while U-Boot is executing from flash. This pointer needs to be updated to point to an address in RAM after relocation has occurred otherwise Linux may not be able to boot due to "fdt board" crashing if flash has been erased or changed. This bug was introduced in commit a0e2066f392782730f0398095e583c87812d97f2. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Reported-by: Ed Swarthout <Ed.Swarthout@freescale.com> Tested-by: Kumar Gala <galak@kernel.crashing.org> Tested on MPC8527DS. Tested by: Ed Swarthout <Ed.Swarthout@freescale.com>
2009-12-14MVBLUE: Remove CONFIG_CMD_IRQPeter Tyser
Neither the MVBLUE nor its underlying architecture implement the do_irqinfo() function which is required when CONFIG_CMD_IRQ is defined. This change fixes the following MVBLUE compiler error: -> ./MAKEALL MVBLUE Configuring for MVBLUE board... common/libcommon.a(cmd_irq.o):(.u_boot_cmd+0x24): undefined reference to `do_irqinfo' make: *** [u-boot] Error 1 Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2009-12-14imx27lite: Reenable MTD support on NOR flash.Detlev Zundel
The support for this was silently dropped by a configuration split during the merge of the imx27lite board support in commit 864aa034f3a0e10ce710e8bbda171df3cab59414 (cmd_mtdparts: Move to common handling of FLASH devices via MTD layer). Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-12-11nand: Fix access to last block in NAND devicesStefan Roese
Currently, the last block of NAND devices can't be accessed. This patch fixes this issue by correcting the boundary checking (off-by-one error). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Wolfgang Denk <wd@denx.de>
2009-12-09mpc83xx: boot time regression, move LCRR setup back to cpu_init_fPeter Korsgaard
Commit c7190f02 (retain POR values of non-configured ACR, SPCR, SCCR, and LCRR bitfields) moved the LCRR assignment to after relocation to RAM because of the potential problem with changing the local bus clock while executing from flash. This change unfortunately adversely affects the boot time, as running all code up to cpu_init_r can cause significant slowdown. E.G. on a 8347 board a bootup time increase of ~600ms has been observed: 0.020 CPU: e300c1, MPC8347_PBGA_EA, Rev: 3.0 at 400 MHz, CSB: 266.667 MHz 0.168 RS: 232 0.172 I2C: ready 0.176 DRAM: 64 MB 1.236 FLASH: 32 MB Versus: 0.016 CPU: e300c1, MPC8347_PBGA_EA, Rev: 3.0 at 400 MHz, CSB: 266.667 MHz 0.092 RS: 232 0.092 I2C: ready 0.096 DRAM: 64 MB 0.644 FLASH: 32 MB So far no boards have needed the late LCRR setup, so simply revert it for now - If it is needed at a later time, those boards can either do their own final LCRR setup in board code (E.G. in board_early_init_r), or we can introduce a CONFIG_SYS_LCRR_LATE config option to only do the setup in cpu_init_r. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-12-08microblaze: Correct ffs regression for MicroblazeMichal Simek
We are using generic implementation of ffs. This should be part of Simon's commit 0413cfecea350000eab5e591a0965c3e3ee0ff00 Here is warning message which this patch removes. In file included from /tmp/u-boot-microblaze/include/common.h:38, from cmd_mtdparts.c:87: /tmp/u-boot-microblaze/include/linux/bitops.h:123:1: warning: "ffs" redefined In file included from /tmp/u-boot-microblaze/include/linux/bitops.h:110, from /tmp/u-boot-microblaze/include/common.h:38, from cmd_mtdparts.c:87: /tmp/u-boot-microblaze/include/asm/bitops.h:269:1: warning: this is the location of the previous definition Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-08microblaze: Stop stack clobbering in microblaze-generic.Graeme Smecher
A typo caused the stack and malloc regions to overlap, which prevented mem_malloc_init() from returning. This commit makes the memory layout match the example described in include/configs/microblaze-generic.h Signed-off-by: Graeme Smecher <graeme.smecher@mail.mcgill.ca> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-07Update CHANGELOG, prepare -rc2v2009.11-rc2Wolfgang Denk
2009-12-07MAKEALL: Fix return valuePeter Tyser
Previously MAKEALL would always return a value of 0, even if 1 or more boards did not compile. This change causes MAKEALL to return 0 if all boards were able to build, otherwise 1. This change also requires changing the script interpreter from sh to bash to support bash's PIPESTATUS variable. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-07tools/mkimage: Remove duplicate line of codePeter Tyser
Recent commits 1a99de2cb4d08eb3bf9fb3f60a9d533150de8c0e and 6a590c5f5fd12cdd27f3153522acfac3854590e7 both fixed the same bug in the same manner. Unfortunately git was "smart" enough to merge both changes which resulted in some duplicate code. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Reordered code and comment a bit. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-07i2c: fix dangling comment in do_i2c_mw()Heiko Schocher
commit bd3784df94bfeca43fbf34094df9cb1bd3ecca3b deleted some unused code in do_i2c_mw(), but missed to also remove the respective commment. This patch fixes this. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-0752xx, manroland: add fdt_fixup_memory() in ft_board_setup()Heiko Schocher
To update the real memory size in the memory node on the uc101 and mucmc52 boards call fdt_fixup_memory() in ft_board_setup(). Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-07Fix computation in nand_util.c:get_len_incl_badDaniel Hobi
Depending on offset, flash size and the number of bad blocks, get_len_incl_bad may return a too small value which may lead to: 1) If there are no bad blocks, nand_{read,write}_skip_bad chooses the bad block aware read/write code. This may hurt performance, but does not have any adverse effects. 2) If there are bad blocks, the nand_{read,write}_skip_bad may choose the bad block unaware read/write code (if len_incl_bad == *length) which leads to corrupted data. Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
2009-12-07nfs: NfsTimeout() updatesEvan Samanas
- NfsTimeout() does not correctly update the NFS timeout value which results in NfsTimeout() only being called once in certain situations. This can result in the 'nfs' command hanging indefinetly. For example, the command: nfs 192.168.0.1:/home/user/file will not exit until ctrl-c is pressed if 192.168.0.1 does not have an NFS server running. This issue is resolved by reinitializting the NFS timeout value inside NfsTimeout() when a timeout occurs. - Make the 'nfs' command print the 'T' character when a timeout occurs. Previously there was no indication that timeouts were occuring. - Mimic the 'tftpboot' command and when a download fails print "Retry count exceeded; starting again", and restart the download taking the 'netretry' environment variable into account. Signed-off-by: Evan Samanas <esamanas@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested on TQM8xxL. Tested by: Wolfgang Denk <wd@denx.de> Tested on MPC8527DS. Tested by: Ed Swarthout <Ed.Swarthout@freescale.com>
2009-12-07bootm: Fix help message's sub-command orderingPeter Tyser
The help message for the 'bootm' command listed the 'cmdline' and 'bdt' sub-commands in the wrong order which resulted in the error below when following the 'help' command's instructions: "Trying to execute a command out of order" Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-07help: Correct syntax of nandecc help output.Robert P. J. Day
"nandecc" help output should not reproduce the command name, nor have a trailing newline. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2009-12-07smc911x: update SMC911X related configuration descriptionMike Rapoport
Since commit 736fead8fdbf8a8407048bebc373cd551d01ec98 "Convert SMC911X Ethernet driver to CONFIG_NET_MULTI API" SMC911X configration options are called CONFIG_SMC911X rather than CONFIG_DRIVER_SMC911X. Update README to reflect that change. Signed-off-by: Mike Rapoport <mike@compulab.co.il>
2009-12-07smc911x: fix typo in smc911x_handle_mac_address nameMike Rapoport
2009-12-07fix nfs symlink name corruptionEd Swarthout
An off by one error may cause nfs readlink lookup fail if nfs_path_buff has non-zero data from a previous use. Loading: *** ERROR: File lookup fail Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2009-12-07at91sam9261ek.c: fix minor coding style issue.Wolfgang Denk
2009-12-07trab: fix warning: implicit declaration of function 'disable_vfd'Wolfgang Denk
2009-12-07zlib.c: avoid build conflicts for cradle boardWolfgang Denk
Commit dce3d79710 updated the zlib code to v0.95; this caused conflicts when building for the "cradle" board, because the (pretty generic) preprocessor variable "OFF" was used in multiple files. Make sure to avoid further conflicts by #undef'ing it in zlib.c before redefining it. Signed-off-by: Wolfgang Denk <wd@denx.de> cc: Giuseppe Condorelli <giuseppe.condorelli@st.com> cc: Angelo Castello <angelo.castello@st.com> cc: Alessandro Rubini <rubini-list@gnudd.com>
2009-12-06Fix out-of-tree building of "apollon" board.Wolfgang Denk
2009-12-05lzma: ignore unset filesizesMike Frysinger
The Linux kernel build system changed how it compresses things with LZMA such that the header no longer contains the filesize (it is instead set to all F's). So if we get a LZMA image that has -1 for the 64bit field, let's just assume that the decompressed size is unknown and continue on. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-05README: Rearrange paragraphs to regain linear arrangement.Detlev Zundel
Two later additions to the Configuration Option section unfortunately split the description of Show boot progress and the list of its call outs. Signed-off-by: Detlev Zundel <dzu@denx.de>
