2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Big header cleanup part 2, mostly PPC405 relatedStefan Roese
This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. As a part from this cleanup, the GPIO definitions for PPC405EP are corrected. The high and low parts of the registers (for example CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in the wrong order. This patch now fixes this issue by switching these xxxH and xxxL values. This brings the GPIO 405EP port in sync with all other PPC4xx ports. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Big header cleanup, mostly PPC440 relatedStefan Roese
This patch starts a bit PPC4xx header cleanup. First patch mostly touches PPC440 files. A later patch will touch the PPC405 files as well. This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Move gpio.h to ppc4xx-gpio.h since its ppc4xx specificStefan Roese
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Remove unreferenced file include/405_dimm.hStefan Roese
2010-09-21fsl: refactor MPC8610 and MPC5121 DIU code to use existing bitmap and logo ↵Timur Tabi
features The Freescale MPC8610 and MPC5121 DIU code had re-implement two features that already existed in U-Boot: bitmap drawing and top-of-screen logo (CONFIG_VIDEO_LOGO). So delete the 8610-specific code and use the built-in features instead. Signed-off-by: Timur Tabi <timur@freescale.com>
2010-09-21video: cfb_console: add support for 4bpp bitmaps with GDF_32BIT_X888RGBTimur Tabi
Add support for 4bpp bitmaps, currently only for GDF_32BIT_X888RGB frame buffer format. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-09-21logos: add Freescale logoTimur Tabi
Add the Freescale logo and update the Makefile to build it when building a Freescale board. Signed-off-by: Timur Tabi <timur@freescale.com>
2010-09-21silence config step commands display during MAKEALL buildsKim Phillips
[u-boot next]$ ./MAKEALL 83xx awk '(NF && $1 !~ /^#/) { print $1 ": " $1 "_config; $(MAKE)" }' boards.cfg > .boards.depend Configuring for ve8313 board... Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-21arm: Make jadecpu board use relocationMatthias Weisser
This patch modifies jadecpu board so that it is usable with the relocation patches by Heiko Schocher Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-09-21Merge branch 'next' of ../custodians into nextWolfgang Denk
2010-09-21Merge branch 'next' of git://git.denx.de/u-boot-usb into nextWolfgang Denk
2010-09-20USB-CDC: Fix coding style issuesVitaly Kuzmichev
Fixes most of checkpatch warnings and errors in USB gadget stack. The most frequently encountered problems are: 1) "(foo*)", "foo * bar", "foo* bar" 2) C99 // comments 3) No spaces before/after/around '?', ':', '=', '==', ',', '&', '(' 4) Spaces before '[' 5) Spaces between function names and '(' 6) Block braces in wrong places 7) Spaces before tabs 8) Macros with complex values not enclosed in parenthesis 9) Multiline comments start just after /* Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-09-20USB-CDC: called handle_interrupts inside usb_eth_sendStefano Babic
The patch removes an endless loop in the usb_eth_send if the tx_complete is not called before going in the loop. The driver interrupt routine is called allowing the driver to check if the TX is completed. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-09-20USB-CDC: correct wrong alignment in ether.cStefano Babic
The buffer for the status request must be word aligned because it is accessed with 32 bit pointer in the eth_status_complete function. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-09-20USB-CDC: change simple_strtol to simple_strtoulVitaly Kuzmichev
The patch is based on commit bb9496c6f7e853e5d4edd5397c9d45f1968d623c (done by Julia Lawall <julia@diku.dk>) from linux-2.6.git. Since num is unsigned, it would seem better to use simple_strtoul that simple_strtol. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-09-20USB-CDC: ethernet error path potential oops fixVitaly Kuzmichev
Fix potential oops on rare error path. The patch is based on commit e7b13ec9235b9fded90f826ceeb8c34548631351 (done by David Brownell <david-b@pacbell.net>) from linux-2.6.git. Description of the issue taken from linux kernel bugzilla: (https://bugzilla.kernel.org/show_bug.cgi?id=9594) The potential error can be tracked down as follows: (1) line 807: let the second conjunct on the "if" statment be false meaning "dev->status_ep" is null. This means the "if" evaluates to false. follow thru the code until... (2) line 808: usb_ep_disable(dev->status_ep) passes in a null argument, however "usb_ep_disable" cannot handle that: (from include/linux/usb/gadget.h) 191 static inline int 192 usb_ep_disable (struct usb_ep *ep) 193 { 194 return ep->ops->disable (ep); 195 } -- Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-09-20USB-CDC: Correct stat_req initializationVitaly Kuzmichev
Fix possible oops on stat_req->buf initialization and fix ep0 and status_ep confusion (last one is just intended for stat_req keeping). Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com> Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-09-20USB-CDC: Replace 'strcpy' by 'strlcpy'Vitaly Kuzmichev
Replace 'strcpy' by more safe 'strlcpy' that is implemented in ether.c Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-09-20USB-CDC: Correct freeing usb requestsVitaly Kuzmichev
Fix in_ep and out_ep confusion (rx_req was allocated from out_ep, not from in_ep) and add lost dev->req freeing. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-09-20USB-CDC: Use native debug printout macrosVitaly Kuzmichev
Replace Linux-like debug printout macros by native ones. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com> Applied after removing dead code like '#define DEBUG/#undef DEBUG'
2010-09-20USB-CDC: Add lost 'qmult' definitionVitaly Kuzmichev
Add lost 'qmult' definition for High Speed devices and make it configurable through CONFIG_USB_ETH_QMULT. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-09-20USB-CDC: Restuct USB gadget MakefileVitaly Kuzmichev
Prohibit simultaneous usage of both old and new gadget stacks and allow UDC drivers to be dependent on CONFIG_USB_ETHER. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-09-20Integrate USB gadget layer and USB CDC driver layerRemy Bohmer
Derived from Linux kernel 2.6.27 Signed-off-by: Thomas Smits <ts.smits@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-09-20usb: musb: stub out MUSB_TXCSR_MODE for Blackfin partsMike Frysinger
The MUSB_TXCSR_MODE register setting isn't supported on Blackfin musb parts, so stub it out to 0. This matches Linux behavior. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-20cfi_flash: Remove uneccessary #ifdef CONFIG_SYS_MAX_FLASH_BANKS_DETECTStefan Roese
Now that the defines are moved to header files we don't need this conditional compilation any more. Remove it. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-20cfi_flash: Simplify dynamic flash bank number detectionStefan Roese
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By moving these optional variables and defines into the common code, board specific code is minimized. Currently only the following board use this feature: APC405, IDS8247, TQM834x And IDS8247 doesn't seem to really need this feature, since its not updating the bank number variable at all. So this patch removes the definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port. This new framework will be used by the upcoming lwmon5 update as well. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-09-20cfi_flash: Add weak default for cfi_flash_bank_addr()Stefan Roese
cfi_flash_bank_addr(int bank_nr) returns the base addresses of the requested bank. Introducing this weak default enables boards to override this functions with a board specific version when required. This feature will be used in the lwmon5 board update, supporting runtime detection of 2 board revisions with different flash layouts. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-20cfi_flash: Simplify flash_get_info()Stefan Roese
This patch removes an unecessary check in the return statement. This is not needed, since "info" is initializes to NULL. And "info" will not be written to again, if the flash address is not found. Additionally "info" is not initialized to "0" but to "NULL". Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-19Remove spieval board supportWolfgang Denk
Recent changes caused that the spieval board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized. mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized. The board is orphaned. Drop support for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19Remove smmaco4 board supportWolfgang Denk
Recent changes caused that the smmaco4 board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized. The board is orphaned. Drop support for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19Remove HMI10 board supportWolfgang Denk
Recent changes caused that the HMI10 board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: ps2ser.c: In function 'ps2ser_init': ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function) ps2ser.c:155: error: (Each undeclared identifier is reported only once ps2ser.c:155: error: for each function it appears in.) ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function) ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function) ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function) ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function) ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function) ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function) ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_putc': ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_getc_hw': ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_interrupt': ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function) The board is orphaned, and AFAICT has reached EOL. Drop support for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19canmb board: Fix compiler warningsWolfgang Denk
Recent changes caused thatthe aev board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: canmb.c: In function 'initdram': canmb.c:109: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness canmb.c:111: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness canmb.c:137: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness canmb.c:140: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness Fix these. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19aev board: Fix compile problemsWolfgang Denk
Recent changes caused thatthe aev board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized. mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized. Fix it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19da8xx: fixup ARM relocation supportBen Gardiner
Split the existing dram_init for da8xx when ARM reloc is enabled, like the changes to arch/arm/cpu/arm926ejs/orion5x/dram.c in 0f234d263b17ccf1b8fd776eb8c15b7cdb27a887 by Heiko Schocher <hs@denx.de>. Without these changes gd->ram_size is '0' which leads to incorrect relocation when CONFIG_SYS_ARM_WITHOUT_RELOC is defined and the board does not boot. We use get_ram_size to dynamically calculate the available RAM because it runs on different board version with different ram, as suggested by Heiko in private communication. Tested on a da850evm with 128M of DDR2 installed; with both CONFIG_SYS_ARM_WITHOUT_RELOC defined and undefined. Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Reviewed-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com> CC: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for arm1176Heiko Schocher
Change the implementation for arm1176 to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for arm720tHeiko Schocher
Change the implementation for arm720t to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for arm_intcmHeiko Schocher
Change the implementation for arm_intcm to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for lh7a40xHeiko Schocher
Change the implementation for lh7a40x to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for s3c44b0Heiko Schocher
Change the implementation for s3c44b0 to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for sa1100Heiko Schocher
Change the implementation for sa1100 to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for ixpHeiko Schocher
Change the implementation for ixp to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for pxaHeiko Schocher
Change the implementation for pxa to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for ARM946Heiko Schocher
Change the implementation for arm946 to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for ARM925Heiko Schocher
Change the implementation for arm925 to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for ARM920Heiko Schocher
Change the implementation for arm920 to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19ARM: implement relocation for ARM926Heiko Schocher
Change the implementation for arm926 to relocate the code to an arbitrary address in RAM. Adapt the TX25 (i.MX25), magnesium board to test the changes. On the tx25 board TEXT_BASE is set to the final relocation address to prevent one more copying of u-boot code when relocating. More info see: doc/README.arm-relocation da850 board: Tested-by: Ben Gardiner <bengardiner@nanometrics.ca> Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca>
2010-09-19ARM: implement relocation for ARM V7 (OMAP)Heiko Schocher
Change the implementation for ARM V7 to relocate the code to an arbitrary address in RAM. Adapt the Beagle board (Cortex A8) to test the changes. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
