2006-09-03 | Fixed problems on PRS200 board caused by adding splash screen on MCC200 | Wolfgang Denk | |
2006-09-03 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2006-09-01 | Added David Updegraff as maintainer of CRAYL1 | Detlev Zundel | |
2006-09-01 | Added changelog entry for previous small commits and extended README on | Detlev Zundel | |
coding style. | |||
2006-09-01 | Added another example showing simple interrupt interception. | Detlev Zundel | |
2006-09-01 | Added simple_strtoul(), getenv() and setenv() to the exported functions. | Detlev Zundel | |
Also bumped up ABI version to reflect this change. | |||
2006-09-01 | Added interrupt handling capabilities for mpc5xxx processors. | Detlev Zundel | |
Also added Linux like BUG() macros. | |||
2006-08-31 | Coding Style cleanup. | Wolfgang Denk | |
Patch by Stefano Babic, 31 Aug 2006 | |||
2006-08-30 | Add splashscreen support for MCC200 board. | Wolfgang Denk | |
2006-08-30 | Make the serial driver framework work with CONFIG_SERIAL_MULTI enabled | Wolfgang Denk | |
2006-08-29 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
2006-08-29 | Fix typo. | Wolfgang Denk | |
2006-08-29 | PCIe endpoint support for AMCC Yucca 440SPe board | Stefan Roese | |
Patch by Tirumala R Marri, 26 Aug 2006 | |||
2006-08-29 | Improve DIMM detection for AMCC Yucca 440SPe board | Stefan Roese | |
Improved the memory DIMM detection for the Yucca 440SPe board for the case where a memory DIMM is falsely detected as present. This issue is seen on some AMCC Yucca 440SPe validation boards if only one 512MB memory DIMM is installed, i.e. DIMM slot 0 is populated and DIMM slot 1 is empty. In this case, U-Boot does not correctly detect that there is only one DIMM memory module installed and will falsely detect two DIMM memory modules are present and therefore U-Boot will not calculate the correct amount of total memory and u-boot will not booting up. Patch by Adam Graham, 24 Aug 2006 | |||
2006-08-27 | Code cleanup | Wolfgang Denk | |
2006-08-25 | Fix typo in MCC200/PRS200 configuration | Wolfgang Denk | |
2006-08-25 | Update for MCC200 / PRS200 boards: | Wolfgang Denk | |
- auto-adjust console device for Linux. - fix typos. | |||
2006-08-25 | Merge with /home/tur/proj/fo300/u-boot | Wolfgang Denk | |
2006-08-24 | Updates for MCC200 / PRS200 boards: | Wolfgang Denk | |
- support for configurations with SDRAM or DDR memory, - support for highboot and lowboot - adjusting environment definitions | |||
2006-08-22 | Add a fix for a buggy USB device on the FO300 board. | Bartlomiej Sieka | |
2006-08-18 | Minor cleanup | Wolfgang Denk | |
2006-08-18 | Add support for WTK FO300 board (TQM5200 based). | Marian Balakowicz | |
2006-08-18 | Merge with /home/raj/git/u-boot | Wolfgang Denk | |
2006-08-18 | Merge with git+ssh://fifi/home/wd/git/u-boot/master | Wolfgang Denk | |
2006-08-18 | Fix TQM834x hang. | Rafal Jaworowski | |
2006-08-17 | Cleanup debug code for yucca board. | Wolfgang Denk | |
2006-08-17 | MCC200: restrict addressable flash space to 32 MB | Wolfgang Denk | |
2006-08-17 | Add debug console on COM12 for MCC200 board | Wolfgang Denk | |
2006-08-14 | Update for SC520 board. | Wolfgang Denk | |
Patch by David Updegraff, 02 Dec 2005 | |||
2006-08-14 | Fixed common.h spelling error. | Wolfgang Denk | |
Patch by Cory Tusar, 30 Nov 2005 | |||
2006-08-14 | Fix typo. | Wolfgang Denk | |
Patch by Andreas Engel, 28 Nov 2005 | |||
2006-08-14 | Fix fatload command on FAT32 formatted partitions. | Wolfgang Denk | |
Patch by Joachim Jaeger, 18 Nov 2005 | |||
2006-08-14 | Fix drivers/dm9000.c when configured in 32 bit mode. | Wolfgang Denk | |
Patch by Eric Benard, 17 Nov 2005 | |||
2006-08-13 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
2006-08-11 | Merge with /home/raj/git/u-boot | Wolfgang Denk | |
2006-08-11 | Fix preboot message on TQM85xx after switching to hush parser. | Wolfgang Denk | |
2006-08-11 | Adapt TQM85xx ramdisk address to Linux kernel memory map | Wolfgang Denk | |
2006-08-11 | Fix PCI-Express on PPC440SPe rev. A. | Rafal Jaworowski | |
2006-08-10 | Merge with /home/raj/git/u-boot | Wolfgang Denk | |
2006-08-10 | Add support for PCI-Express on PPC440SPe (Yucca board). | Rafal Jaworowski | |
2006-08-10 | Fix compiler warning for TRAB board. | Wolfgang Denk | |
Patch by Martin Krause, 07 Aug 2006 | |||
2006-08-07 | Merge with /home/tur/proj/usb_sticks/u-boot | Wolfgang Denk | |
2006-08-07 | Fix control-c handing in CONFIG_CMDLINE_EDITING | Stefan Roese | |
Properly pass break code back from readline. Patch by Roger Blofeld, 31 Jul 2006 | |||
2006-08-07 | Add commandline history support to all AMCC eval boards | Stefan Roese | |
Patch by Stefan Roese, 07 Aug 2006 | |||
2006-08-07 | Add Macronix MXLV320T flash support for AMCC Bamboo | Stefan Roese | |
2006-08-07 | Change "mii info" to not print an error upon missing PHY at address | Stefan Roese | |
2006-08-03 | Prevent USB commands from working when USB is stopped. | Bartlomiej Sieka | |
2006-08-02 | Add rudimentary handling of alternate settings of USB interfaces - to fix | Bartlomiej Sieka | |
problems with some USB storage devices. Some code readability improvements. | |||
2006-07-28 | PPC440 DDR setup: Set SDRAM0_CFG0[PMU]=0 for best performance | Stefan Roese | |
AMCC suggested to set the PMU bit to 0 for best performace on the PPC440 DDR controller. Please see doc/README.440-DDR-performance for details. Patch by Stefan Roese, 28 Jul 2006 | |||
2006-07-27 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
