Convert the tools/env/Makefile to use the same host tool syntax as the
other tool subdirs.
Most tool subdirs do not rely on a configured tree, so move those targets
out of the config checks and unify them in the process.
Also add an easylogo target so people can easily build that.
Also add these new tool targets to the 'tools-all' target.
Merge the other significant source of board name duplication with the new
boards.cfg file. I cleaned up most targets, but the ARM and MIPS trees
are such a mess than I didn't bother. If those maintainers care, they can
take are of it.
While we're at it, we can be a bit more clever in the LIST_xxx handling
and avoid duplicating the list names too.
Reviewed-by: Ben Gardiner <bengardiner@nanometrics.ca>
Tested-by: Thomas Chou <thomas@wytron.com.tw>
The helpful shortcut for doing a board config + make was dropped recently
as it conflicted with some new build code. However, the reason for using
pattern targets originally was to avoid managing a duplicate list of
boards. Since we now have one centralized place for a list of boards (the
new boards.cfg), we don't need a pattern target -- we can generate the
exact list of boards on the fly. So do just that.
When cleaning things up, the top level gitignore file ignores all things
that end with ".depend", but the clean target only deletes files that are
named exactly ".depend". Keep these in sync by having the clean target
punt all files that match the pattern that gitignore is using.
Acked-by: Detlev Zundel <dzu@denx.de>
Motivation:
* Old environment code used a pessimizing implementation:
- variable lookup used linear search => slow
- changed/added variables were added at the end, i. e. most
frequently used variables had the slowest access times => slow
- each setenv() would calculate the CRC32 checksum over the whole
environment block => slow
* "redundant" envrionment was locked down to two copies
* No easy way to implement features like "reset to factory defaults",
or to select one out of several pre-defined (previously saved) sets
of environment settings ("profiles")
* No easy way to import or export environment settings
API Changes:
- Variable names starting with '#' are no longer allowed
I didn't find any such variable names being used; it is highly
recommended to follow standard conventions and start variable names
with an alphanumeric character
- "printenv" will now print a backslash at the end of all but the last
lines of a multi-line variable value.
Multi-line variables have never been formally defined, allthough
there is no reason not to use them. Now we define rules how to deal
with them, allowing for import and export.
- Function forceenv() and the related code in saveenv() was removed.
At the moment this is causing build problems for the only user of
this code (schmoogie - which has no entry in MAINTAINERS); may be
fixed later by implementing the "env set -f" feature.
Inconsistencies:
- "printenv" will '\\'-escape the '\n' in multi-line variables, while
"printenv var" will not do that.
Advantages:
- "printenv" output much better readable (sorted)
- faster!
- extendable (additional variable properties can be added)
- new, powerful features like "factory reset" or easy switching
between several different environment settings ("profiles")
Disadvantages:
- Image size grows by typically 5...7 KiB (might shrink a bit again on
systems with redundant environment with a following patch series)
Implemented:
- env command with subcommands:
- env print [arg ...]
same as "printenv": print environment
- env set [-f] name [arg ...]
same as "setenv": set (and delete) environment variables
["-f" - force setting even for read-only variables - not
implemented yet.]
- end delete [-f] name
not implemented yet
["-f" - force delete even for read-only variables]
- env save
same as "saveenv": save environment
- env export [-t | -b | -c] addr [size]
export internal representation (hash table) in formats usable for
persistent storage or processing:
-t: export as text format; if size is given, data will be
padded with '\0' bytes; if not, one terminating '\0'
will be added (which is included in the "filesize"
setting so you can for exmple copy this to flash and
keep the termination).
-b: export as binary format (name=value pairs separated by
'\0', list end marked by double "\0\0")
-c: export as checksum protected environment format as
used for example by "saveenv" command
addr: memory address where environment gets stored
size: size of output buffer
With "-c" and size is NOT given, then the export command will
format the data as currently used for the persistent storage,
i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and
prepend a valid CRC32 checksum and, in case of resundant
environment, a "current" redundancy flag. If size is given, this
value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32
checksum and redundancy flag will be inserted.
With "-b" and "-t", always only the real data (including a
terminating '\0' byte) will be written; here the optional size
argument will be used to make sure not to overflow the user
provided buffer; the command will abort if the size is not
sufficient. Any remainign space will be '\0' padded.
On successful return, the variable "filesize" will be set.
Note that filesize includes the trailing/terminating '\0'
byte(s).
Usage szenario: create a text snapshot/backup of the current
settings:
=> env export -t 100000
=> era ${backup_addr} +${filesize}
=> cp.b 100000 ${backup_addr} ${filesize}
Re-import this snapshot, deleting all other settings:
=> env import -d -t ${backup_addr}
- env import [-d] [-t | -b | -c] addr [size]
import external format (text or binary) into hash table,
optionally deleting existing values:
-d: delete existing environment before importing;
otherwise overwrite / append to existion definitions
-t: assume text format; either "size" must be given or the
text data must be '\0' terminated
-b: assume binary format ('\0' separated, "\0\0" terminated)
-c: assume checksum protected environment format
addr: memory address to read from
size: length of input data; if missing, proper '\0'
termination is mandatory
- env default -f
reset default environment: drop all environment settings and load
default environment
- env ask name [message] [size]
same as "askenv": ask for environment variable
- env edit name
same as "editenv": edit environment variable
- env run
same as "run": run commands in an environment variable
TODO:
- drop default env as implemented now; provide a text file based
initialization instead (eventually using several text files to
incrementally build it from common blocks) and a tool to convert it
into a binary blob / object file.
- It would be nice if we could add wildcard support for environment
variables; this is needed for variable name auto-completion,
but it would also be nice to be able to say "printenv ip*" or
"printenv *addr*"
- Some boards don't link any more due to the grown code size:
DU405, canyonlands, sequoia, socrates.
=> cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>,
Stefan Roese <sr@denx.de>,
Heiko Schocher <hs@denx.de>
- Dropping forceenv() causes build problems on schmoogie
=> cc: Sergey Kubushyn <ksi@koi8.net>
- Build tested on PPC and ARM only; runtime tested with NOR and NAND
flash only => needs testing!!
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>,
Cc: Stefan Roese <sr@denx.de>,
Cc: Sergey Kubushyn <ksi@koi8.net>
So far, getenv() would work before relocation is most cases, even
though it was not intended to be used that way. When switching to a
hash table based implementation, this would break a number of boards.
For convenience, we make getenv() check if it's running before
relocation and, if so, use getenv_f() internally.
Note that this is limited to simple cases, as we use a small static
buffer (32 bytes) in the global data for this purpose.
For this reason, it is also not a good idea to convert all current
uses of getenv_f() into getenv() - some of the existing use cases need
to be able to deal with longer variable values, so getenv_f() is still
needed and recommended for use before relocation.
This (undocumented) concept was only in use for the MVSMR and
davinci_schmoogie Sergey Kubushyn <ksi@koi8.net> boards.
Drop it for now. If really needed, it should be reimplemented
later in the context of the new environment command set.
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Sergey Kubushyn <ksi@koi8.net>
This implementation is based on code from uClibc-0.9.30.3 but was
modified and extended for use within U-Boot.
Major modifications and extensions:
* hsearch() [modified / extended]:
- While the standard version does not make any assumptions about
the type of the stored data objects at all, this implementation
works with NUL terminated strings only.
- Instead of storing just pointers to the original objects, we
create local copies so the caller does not need to care about the
data any more.
- The standard implementation does not provide a way to update an
existing entry. This version will create a new entry or update an
existing one when both "action == ENTER" and "item.data != NULL".
- hsearch_r(): Instead of returning 1 on success, we return the
index into the internal hash table, which is also guaranteed to be
positive. This allows us direct access to the found hash table
slot for example for functions like hdelete().
* hdelete() [added]:
- The standard implementation of hsearch(3) does not provide any way
to delete any entries from the hash table. We extend the code to
do that.
* hexport() [added]:
- Export the data stored in the hash table in linearized form:
Entries are exported as "name=value" strings, separated by an
arbitrary (non-NUL, of course) separator character. This allows to
use this function both when formatting the U-Boot environment for
external storage (using '\0' as separator), but also when using it
for the "printenv" command to print all variables, simply by using
as '\n" as separator. This can also be used for new features like
exporting the environment data as text file, including the option
for later re-import.
- The entries in the result list will be sorted by ascending key
values.
* himport() [added]:
- Import linearized data into hash table. This is the inverse
function to hexport(): it takes a linear list of "name=value"
pairs and creates hash table entries from it.
- Entries without "value", i. e. consisting of only "name" or
"name=", will cause this entry to be deleted from the hash table.
- The "flag" argument can be used to control the behaviour: when
the H_NOCLEAR bit is set, then an existing hash table will kept,
i. e. new data will be added to an existing hash table;
otherwise, old data will be discarded and a new hash table will
be created.
- The separator character for the "name=value" pairs can be
selected, so we both support importing from externally stored
environment data (separated by NUL characters) and from plain text
files (entries separated by newline characters).
- To allow for nicely formatted text input, leading white space
(sequences of SPACE and TAB chars) is ignored, and entries
starting (after removal of any leading white space) with a '#'
character are considered comments and ignored.
- NOTE: this means that a variable name cannot start with a '#'
character.
- When using a non-NUL separator character, backslash is used as
escape character in the value part, allowing for example fo
multi-line values.
- In theory, arbitrary separator characters can be used, but only
'\0' and '\n' have really been tested.
Code adapted from uClibc-0.9.30.3
Needed for hash table support; probably useful in a lot of other
places as well.
On some boards (canyonlands, luan, sequoia) we need more room for the
U-Boot image to allow for new features like the new environment code.
Shift TEXT_BASE as needed.
Increase malloc size,
enable command line editing and history,
enable hush shell.
Traditionally many boards used local definitions for SRAM base address
and size (like SRAM_BASE, SRAM_LEN and/or SRAM_SIZE), while the (now)
"official" names are CONFIG_SYS_SRAM_BASE and CONFIG_SYS_SRAM_SIZE.
The corresponding code in arch/powerpc/lib/board.c was board specific,
and has never actually been maintained well. Replace this by feature-
specific code and adapt the boards that actually use this.
NOTE: there is still a ton of boards using the old #defines, which
therefor contain incorrect values in bi_sramstart and bi_sramsize.
All respective board maintainers are requested to clean up their
respective configurations. Thanks.
Cc: Josef Wagner <Wagner@Microsys.de>
A number of boards define CONFIG_SYS_SRAM_BASE but fail to define
CONFIG_SYS_SRAM_SIZE which is needed when cleaning up the code that
prints this information with the bdinfo command.
Add the missing deinitions.
This patch is to save environment data to mmc card.
It uses interfaces defined in generic mmc.
Signed-off-by: Terry Lv <r65388@freescale.com>
We need more room for the U-Boot image.
Commit d2bf29e3 caused a number of compiler warnings:
mmc.c: In function 'mmc_bwrite':
mmc.c:97: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'long unsigned int'
mmc.c:97: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'lbaint_t'
mmc.c: In function 'mmc_bread':
mmc.c:229: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'long unsigned int'
mmc.c:229: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'lbaint_t'
Fix these.
Cc: Lei Wen <leiwen@marvell.com>
Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
In commit bd7b26f8 (Tools: set multiple variable with fw_setenv utility),
the option parsing was changed to getopt_long(3), but option "-n"
of fw_printenv was not included.
This leads to an error message "invalid option -- 'n'" on stderr,
although the output on stdout is correct.
This patch updates the mach-types.h based on the latest linux kernel
Signed-off-by: Thomas Weber <weber@corscience.de>
Signed-off-by: Lei Wen <leiwen@marvell.com>
Due to a register glitch (result code <4 might show up right after the
start-calculation-bit was set), make sure the ECC has really started.
See 1c3275b656045aff9a75bb2c9f3251af1043ebb3 in the kernel.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
use a union to cause necessary alignment per architecture
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
The SC520 CDP boards originally implemented by Daniel Engström are now
very broken. Attempts to contact Daniel via the email address on the
copyright notice have failed. Remove these boards from mainline
Commit 077e1958ca4afe12d88043b123ded058c51b89f7 broke the ability of the
x86 port to boot from a cold-reset by removing the initial IDT. Re-
instate the initial IDT to allow cold-booting of x86 boards
x86 failed to compile with a message "a case for this architecture does
not exist!" - Add do_bdinfo() for this arch
Commit 54841ab50c20d6fa6c9cc3eb826989da3a22d934 made the argv parameter
to do_go_exec() const but did not allow for the fact that argv[-1] is
set to point to the global data structure and relies on argv being non-
const.
With this patch, do_go_exec() creates a new copy of the argv array with
an extra element to store global data pointer rather than simply
clobbering an arbitrary memory location.
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
The Blackfin implementation of musb has a TXCOUNT register that needs to
be programmed when transmitting data.
Coding style cleanup.
commit 47e26b1b "cmd_usage(): simplify return code handling" caused
the following compile warnings:
bedbug_860.c: In function 'bedbug860_do_break':
bedbug_860.c:73: warning: 'return' with a value, in function returning void
bedbug_860.c:121: warning: 'return' with a value, in function returning void
Fix the return type.
Actually these files could need some cleanup - commands should
return proper error codes, and there are coding style issues.
=> To be fixed later.
Correctly set PAD1_FREF_CLK4_REQ and PAD0_FREF_CLK4_OUT to enable and
activate both LEDs while setting pad mux.
Since this increases the line length, this patch also adjusts the white
space in this section of code to allign the pad mux signal description
comments.
Signed-off-by: Ricardo Salveti de Araujo <ricardo.salveti@canonical.com>
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
An upcoming version of Overo uses a Wifi/BT module with 1.8V signaling,
eliminating the need for an external transceiver to handle the level
shifting. This patch detects whether an external transceiver is present
and adjusts the pinmux settings as appropriate.
This patch adds support for the Beagle xM. It uses the board ID
GPIO bits to recognize this revision and perform appropriate setup.
Future versions of these boards have options for POP memory with no NAND.
This option prevents display of error messages when no NAND is detected.
This printk was added recently and results in ugly output on systems
with no NAND:
NAND: nand_get_flash_type: unknown NAND device: Manufacturer ID: 0x00, Chip ID: 0x00 0 MiB
instead of:
NAND: 0 MiB
Acked-by: Scott Wood <scottwood@freescale.com>
Upcoming Beagle and Overo revisions use POP memory with 256MB or 512MB
per bank. This patches uses the SDRC settings from x-load or the config
header to set up timing properly.
Using the reset command on OMAP36XX/37XX and OMAP4 caused a hang. This
patch uses the reset bit appropriate for each CPU architecture.
The workarounds for errata 621766 and 725233 should only be applied
on affected Cortex-A8 revisions. Recent chips use r3px cores where
these have been fixed.
Signed-off-by: Mans Rullgard <mans@mansr.com>
This function consists entirely of inline asm statements, so writing
it directly in a .S file is simpler. Additionally, the inline asm is
not safe as is, since registers are not guaranteed to be preserved
between asm() statements.
On OMAP34xx ES1.0, the L2 enable bit can only be set in secure mode,
so an SMC call to the ROM monitor is required. On later versions,
and on newer devices, this bit is banked and we can set it directly.
The code checked only the ES revision of the chip, and hence incorrectly
used the ROM call on ES1.0 versions of other devices.
This patch adds a check for chip family as well as revision, and also
removes some code duplication between the enable and disable functions.
This patch configures clocks properly when a 36XX/37XX
processor is detected.
