2006-03-12 | Fix cleanup for netstart board.LABEL_2006_03_12_0025 | Wolfgang Denk | |
Remove build results from repository | |||
2006-03-11 | More GCC 4.x woes | Wolfgang Denk | |
2006-03-11 | More GCC 4.x code cleanup | Wolfgang Denk | |
2006-03-11 | Some code cleanup for GCC 4.x | Wolfgang Denk | |
2006-03-11 | Update CHANGELOG | Wolfgang Denk | |
2006-03-09 | Merge with http://www.denx.de/git/u-boot.git | Markus Klotzbücher | |
2006-03-08 | Merge with /home/tur/nand/u-boot | Wolfgang Denk | |
2006-03-08 | Merge /home/tur/nand/u-boot/ | Markus Klotzbücher | |
2006-03-08 | Fixed a bug in saveenv(). Credit: Markus Klotzbuecher. | Bartlomiej Sieka | |
> @@ -115,7 +115,7 @@ int saveenv(void) | |||
2006-03-08 | Enable simple (non-redundant) NAND environment on delta board. | Markus Klotzbücher | |
2006-03-08 | Some minor fixes to environment in NAND code. | Markus Klotzbuecher | |
2006-03-07 | Add support for Intel Monahans CPU on Zylonite and Delta boards | Wolfgang Denk | |
(This is Work in Progress!) | |||
2006-03-07 | Add support for TQM8260-AI boards. | Wolfgang Denk | |
2006-03-07 | Cleanup (get rid of debug code that sneaked in) | Wolfgang Denk | |
2006-03-06 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
Code cleanup. | |||
2006-03-06 | Turned on SDRAM scrubbing. | Markus Klotzbücher | |
2006-03-06 | Cleanup of NAND support of delta board using the Monahans Data Flash | Markus Klotzbücher | |
Controller. | |||
2006-03-06 | NAND finally working. Two bugs fixed: | Markus Klotzbücher | |
* For READ_STATUS and READID commands always 8 bytes need to be read from NDDB. Otherwise they stay there and get send to flash as the first data word when writing. * In nand_base.c the oob variable is not reset so this->oob_buf is overwritten what eventually screws up the bad block descriptor table. | |||
2006-03-06 | Minor code cleanup | Wolfgang Denk | |
2006-03-06 | Merge the new NAND code (testing-NAND brach); see doc/README.nand | Wolfgang Denk | |
Rewrite of NAND code based on what is in 2.6.12 Linux kernel Patch by Ladislav Michl, 29 Jun 2005 [Merge with /home/tur/nand/u-boot] | |||
2006-03-05 | Re-factoring the legacy NAND code (legacy NAND now only in board-specific | Bartlomiej Sieka | |
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards. | |||
2006-03-04 | Lots of new stuff: | Markus Klotzbücher | |
* Debug message can be turned on and off. * Waiting for events now times out. * Implemented RESET command. * Added appropriate nand_bbt_descriptor and nand_oobinfo. Remaining Problems: * Read Status still behaves weird an returns invalid stuff sometimes. * ECC Placement does not respect our scheme in nand_oobinfo. | |||
2006-03-04 | Add lowboot target to mcc200 board | Stefan Roese | |
Patch by Stefan Roese, 4 Mar 2006 | |||
2006-03-03 | Erasing works too now. The CS don't care causes problem with READSTATUS, | Markus Klotzbücher | |
don't ask me why. There are still bugs in the bad block logic. | |||
2006-03-03 | Write operation is working. Turned out that the READSTATUS hack was wrong | Markus Klotzbücher | |
after all. | |||
2006-03-03 | Writing is working, but there's still a bug that causes the data written to | Markus Klotzbücher | |
start at an offset of 4 bytes from the start of the page. | |||
2006-03-03 | Implemented writing, not working yet. | Markus Klotzbücher | |
2006-03-02 | Moved the waiting loop for "Read Data Request" RDDREQ into the | Markus Klotzbücher | |
delta_cmdfunc function, because this bit is only set once after a command is sent and this allows read functions to be called multiple times. | |||
2006-03-02 | Merge with /home/sr/git/u-boot/cfi-flash-fix | Wolfgang Denk | |
2006-03-02 | Read bug fixed. Now "nand bad" list the badblocks correctly (i hope, since | Markus Klotzbücher | |
there are 0) | |||
2006-03-02 | Make CFG_NO_FLASH work on ARM systems | Wolfgang Denk | |
Patch by Markus Klotzbuecher, 27 Feb 2006 | |||
2006-03-01 | Further NAND stuff implemented. Basic read commands seem to work. | Markus Klotzbücher | |
2006-03-01 | Fix problem with flash_get_size() from CFI driver update | Stefan Roese | |
Patch by Stefan Roese, 1 Mar 2006 | |||
2006-02-28 | All subsystem clocks not immediately need are turned at reset. | Markus Klotzbücher | |
2006-02-28 | Added GPIO initialization of DF signal. Still not working. | Markus Klotzbücher | |
2006-02-28 | Update mcc200 config: Disable PCI and DoC, use 133 MHz IPB clock, | Wolfgang Denk | |
use hush shell. | |||
2006-02-28 | First steps implementing NAND support. Not working, fails to read ID. | Markus Klotzbücher | |
2006-02-28 | Merge with Stefan Roese's branch with CFI driver fixes | Wolfgang Denk | |
2006-02-28 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2006-02-28 | Convert mcc200 to use common CFI flash driver | Stefan Roese | |
Patch by Stefan Roese, 28 Feb 2006 | |||
2006-02-28 | Major CFI-FLASH driver update: | Stefan Roese | |
* Add env-variable "unlock" to handle initial state of sectors (locked/unlocked). Only the U-Boot image and it's environment is protected, all other sectors are unprotected (unlocked) if flash hardware protection is used (CFG_FLASH_PROTECTION) and the environment variable "unlock" is set to "yes". Patch by Stefan Roese, 28 Feb 2006 * Update drivers/cfi_flash.c: - find_sector() called in both versions of flash_write_cfiword() Patch by Peter Pearse, 27th Feb 2006 * CFI support for a x8/x16 AMD/Spansion flash configured in x8 mode Patch by Jose Maria Lopez, 16 Jan 2006 * Add support for AMD/Spansion Flashes in flash_write_cfibuffer Patch by Alex Bastos and Thomas Schaefer, 2005-08-29 * Changes/fixes for drivers/cfi_flash.c: We *should* check if there are any error bits if the previous call returned ERR_OK (Otherwise we will have output an error message in flash_status_check() already.) The original code would only check for error bits if flash_status_check() returns ERR_TIMEOUT. Patch by Marcus Hall, 23 Aug 2005 * Changes/fixes for drivers/cfi_flash.c: - Add CFG_FLASH_PROTECT_CLEAR on drivers/cfi_flash.c - Prohibit buffer write when buffer_size is 1 on drivers/cfi_flash.c Patch by Sangmoon Kim, 19 Aug 2005 * Fixes for drivers/cfi_flash.c: - Fix wrong timeout value usage in flash_status_check() - Round write_tout up when converting to msec in flash_get_size() - Remove clearing flash status at the end of flash_write_cfibuffer() which sets Intel 28F640J3 flash back to command mode on CSB472 Patch by Tolunay Orkun, 02 July 2005 | |||
2006-02-24 | Merge /home/tur/nand/u-boot/ | Markus Klotzbücher | |
This is a first version of the testing-NAND branch merged back to main. | |||
2006-02-24 | Merge branch 'master' of http://www.denx.de/git/u-boot | Markus Klotzbücher | |
2006-02-24 | Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling. | Bartlomiej Sieka | |
2006-02-24 | Cleanup MCC200 board. | Wolfgang Denk | |
2006-02-22 | SDRAM now working. | Markus Klotzbücher | |
2006-02-22 | SDRAM now working for delta board, but there are still aliasing problems, | Markus Klotzbücher | |
we only see 64MB. | |||
2006-02-22 | Rename SMMACO4 board into smmaco4 for consistency with Linux. | Wolfgang Denk | |
2006-02-22 | Disable CMD_BSP for SMMACO4 board. | Wolfgang Denk | |
2006-02-22 | Merge with /home/hs/PanDacom/u-boot-dev | Wolfgang Denk | |
