Several board/<...>/config.mk files include dynamically built (by
the Makefile) config files but used the wrong file name of
$(TOPDIR)/board/$(BOARDDIR)/config.tmp
instead if the correct
$(OBJTREE)/board/$(BOARDDIR)/config.tmp
The bug is nasty because the build result is correct for the (normal)
in-tree builds, and because 'sinclude' is used no errors get raised
even for out-of-tree build tests. But out-of-tree builds use an
incomplete and thus usually incorrect configuration...
Canyonlands has a file ddr2_fixed.c which needs special treatment when
building in separate directory. It has to be linked to build directory
otherwise it is not seen.
This reverts commit 55774b512fdf63c0516d441cc5da7c54bbffb7f2
which broke many PowerPC boards.
This reverts commit 1b5605ca57fbb364f4d78eeee28b974ed875e888
which breaks building on all PPC boards that don't use a log buffer.
Calculation of tail was incorrect when size % 4 == 0.
New code removes the conditional and does the same thing but with arithmetic
Signed-off-by: Nick Spence <nick.spence@freescale.com>
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93
which is known to break booting from dataflash and NAND.
When using dhcp/bootp the "netmask" environment variable is not set
because CONFIG_BOOTP_SUBNETMASK is not defined. But usually this is
desireable, so the following patch adds this this option to the board
config.
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
This patch reworks the default environment on Makalu. Now "net_nfs" for
example uses the device-tree style booting formerly know as "net_nfs_fdt".
Also the addresses in RAM were changed because of the new image booting
support, which check for image overwriting. So the addresses needed to
get adjusted.
map_physmem currently generates a warning when CONFIG_PHYS_64BIT is
enabled. This quiets the warning.
Signed-off-by: Becky Bruce <Becky.Bruce@freescale.com>
Physical addrs need to be represented by phys_addr_t, not
unsigned long. Otherwise, systems that use CONFIG_PHYS_64BIT
are going to fail mightily.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This patch enables legacy multi-type images containing only a Linux kernel
and root file system to be loaded, maintaining compatibility with previous
versions of u-boot.
This is required when using old image files such as a Linux 2.4 kernel /
filesystem.
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
When applying the AT91CAP9 patches upstream, something transformed
the '@' character into the ' <at> ' sequence.
The patch below restores the original form in all the places where
it has been modified (the AT91CAP9 files, the AT91SAM9260 files which
were copied from AT91CAP9, and a couple of other files where the
' <at> ' sequence was present).
Signed-off-by: Stelian Pop <stelian@popies.net>
When doing the AT91CAP9/AT91SAM9 port, a number of header files were
copied from the Linux kernel sources. This patch explicitly specifies
this origin for all the copied headers, and for those missing copyright
information, adds it.
Additionaly, the header file 'at91sam926x_mc.h' has been superceeded
in the latest kernel sources by 'at91sam9_smc.h'.
The copyright information has been confirmed by the AT91 Linux kernel
maintainer, Andrew Victor <avictor.za@gmail.com>.
When Ulf did the dataflash.c cleanup, he didn't add his copyright on
the new created files. This patch fixes the problem.
According to schematics and to RedBoot sources, the MX31ADS uses a 32768Hz
oscillator as a SKIL source. Fix previously wrongly assumed 32000Hz value.
Also fix a typo when verifying a jumper configuration. While at it, make
two needlessly global functions static.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Add logbuffer to reserved LMB areas to prevent initrd allocation
from overlaping with it.
Make sure to use correct logbuffer base address.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Removed duplicated effective memory size calculation code.
Recent modifcations to LOGBUFFER handling code were incorrecly
introduced to fit_check_kernel() routine during
"Merge branch 'new-image' of git://www.denx.de/git/u-boot-testing",
commit 27f33e9f45ef7f9685cbdc65066a1828e85dde4f.
This patch cleans up this merge issue.
Changed implementation such that fw_printenv returns failure status
when one or more specified variables do not exist or when incorrect
command syntax is used.
This aids scripting fw_printenv such that the script can key of the
return status rather than relying on standard error "scraping".
Signed-off-by: Grant Erickson <gerickson@nuovations.com>
In the current top-of-tree, 1.3.3.-rc2, the optional tool
'tools/env/fw_printenv' fails to compile for two reasons:
1) The header watchdog.h cannot be found.
2) The header zlib.h is picked up from the tool chain rather than the
project causing a prototype conflict for crc32.
This patch addresses both of these issues.
Platforms Tested On:
- AMCC "Kilauea"
When CONFIG_CMDLINE_EDITING is enabled, readline_into_buffer() doesn't
work before relocating to RAM because command history is written into
a global array that is not writable before relocation. This patch
defers to the no-editing and no-history code in readline_into_buffer()
if it is called before relocation.
Signed-off-by: James Yang <James.Yang@freescale.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: Vlad Lungu <vlad.lungu@windrvier.com>
Removed the second include, with all the #ifdef around as suggested by Wolfgang.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
This patch fixes three typos.
The first is a repetition of CONFIG_CMD_BSP.
The second makes the #endif comment match its #if.
The third is a spelling error.
Signed-off-by: Adrian Filipi <adrian.filipi@eurotech.com>
Add support for the recognition of 'powerpc' as an alias for the PowerPC
architecture type since Linux is already trending in that direction,
preferring 'powerpc' to 'ppc'.
The 7610 and related parts have an L2IP bit in the L2CR that is
monitored to signal when the L2 cache invalidate is complete whereas the
7450 and related parts utilize L2I for this purpose. However, the
current code does not account for this difference. Additionally the 86xx
L2 cache invalidate code used an "andi" instruction where an "andis"
instruction should have been used.
This patch addresses both of these bugs.
Signed-off-by: Travis Wheatley <travis.wheatley@freescale.com>
Acked-By: Jon Loeliger <jdl@freescale.com>
Fix a bogus circular dependency that caused an infinite loop of
"Generating include/autoconf.mk" again and again.
This patch adds fdt (flattened device tree) support to all remaining AMCC
eval boards. Most newer boards already support device tree. With this patch,
all AMCC boards now enable device tree passing from U-Boot to Linux
arch/powerpc kernels.
This patch adds a default ft_board_setup() routine to the 4xx fdt code.
This routine is defined as weak and can be overwritten by a board specific
one if needed.
This patch adds fdt (flattened device tree) support to the AMCC
Acadia eval board. This increases the image size and it doesn't
fit anymore into 256kByte. Since we didn't want to remove features
from the configuration, we decided to increase the U-Boot image size
(add one flash sector).
Also changed the default environment definition to make it
independent of such changes.
Add support for booting with a device tree blob. This is needed to boot
ARCH=powerpc kernels. Also add support for setting the eth0 mac address
via the ethaddr variable.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
Corrected two typos in the 460GT/EX FBDV array.
Signed-off-by: Dave Mitchell <dmitchell@amcc.com>
Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
