2009-03-13MPC5200 FEC MII speed registerJon Smirl
Set a non-zero speed in the MII register so that MII commands will work. Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
2009-03-10Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-03-10Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-03-09tsec: report when there is no vendor specific PHY supportPaul Gortmaker
Commit af1c2b84 added a generic phy support, with an ID of zero and a 32 bit mask; meaning that it will match on any PHY ID. The problem is that there is a test that checked if a matching PHY was found, and if not, it printed the non-matching ID. But since there will always be a match (on the generic PHY, worst case), this test will never trip. In the case of a misconfigured PHY address, or of a PHY that isn't explicitly supported outside of the generic support, you will never see the ID of 0xffffffff, or the ID of the real (but unsupported) chip. It will silently fall through onto the generic support. This change makes that test useful again, and ensures that the selection of generic PHY support doesn't happen without some sort of notice. It also makes it explicitly clear that the generic PHY must be last in the PHY table. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Andy Fleming <afleming@freescale.com>
2009-03-09SIMPC8313 board: fix out of tree building.Wolfgang Denk
Fix typo in makefile which broke out of tree builds. Also use expolicit "rm" instead of "ln -sf" which is known to be unreliable. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-09Add eTSEC 1/2 IO override control (corrected)ksi@koi8.net
This adds tsec12ioovcr to include/asm-ppc/immap_85xx.h (was reserved.) Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
2009-03-09fsl: Remove unnecessary debug printfsAndy Fleming
These were left in accidentally, and are not really useful unless the code is as broken as it was when it was being developed. Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-03-09Fix mpc85xx ddr-gen3 ddr_sdram_cfg.Ed Swarthout
Commit e1be0d25, "32bit BUg fix for DDR2 on 8572" prevented other sdram_cfg bits (such as ecc and self_refresh_in_sleep) from being set. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2009-03-09Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
Conflicts: lib_ppc/board.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-058360, kmeter1: added bootcount feature.Heiko Schocher
add CONFIG_BOOTCOUNT_LIMIT feature for 8360 CPU. The bootcounter uses 8 bytes from the muram, because no other memory was found on this CPU for the bootcount feature. So we must correct the muram size in DTS before booting Linux. This feature is actual only implemented for MPC8360, because not all 83xx CPU have qe, and therefore no muram, which this feature uses. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx, kmeter: QE_ENET10 errata for Silicon Revision 2.1Heiko Schocher
old code implemented the QE_ENET10 errata only for Silicon Revision 2.0. New code reads now the Silicon Revision register and sets dependend on the Silicon Revision the values as advised in the QE_ENET10 errata. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx, kmeter1: updates for 2009.03Heiko Schocher
- HRCW update HRCWH_BOOTSEQ_DISABLE not HRCWH_BOOTSEQ_NORMAL HRCWH_LALE_EARLY added - DDR-SDRAM settings modified. This solves sporadically problems with this memory. - CS1 now 128 MB window size - CS3 now 512 MB window size - PRAM activated - MTDPARTS_DEFAULT defined - CONFIG_HOSTNAME added - MONITOR_LEN now 384 KB Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx, kmeter1: autodetect size of DDR II RAMHeiko Schocher
it is possible that some board variants have different DDR II RAM sizes. So we autodetect the size of the assembled RAM. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx, i2c: add mux support for fsl_i2cHeiko Schocher
This patch adds I2C mux support for the fsl_i2c driver. This allows you to add "new" i2c busses, which are reached over i2c muxes. For more infos, please look in the README and search for CONFIG_I2C_MUX. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx, kmeter1: add I2C, dtt, eeprom supportHeiko Schocher
This patch adds I2C support for the Keymile kmeter1 board. It uses the First I2C Controller from the CPU, for accessing 4 temperature sensors, an eeprom with IVM data and the booteeprom over a pca9547 mux. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-05i2c, dtt: move dtt_init () to board_init_r ()Heiko Schocher
In case where a board not uses CONFIG_POST, it is not necessary to init the DTTs when running from flash. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx: Fix some bugs in spd sdram codeDave Liu
1. RD_TO_PRE missed to add the AL, and need min 2 clocks for tRTP according to DDR2 JEDEC spec. 2. WRTORD - tWTR need min 2 clocks according to DDR2 JEDEC spec. 3. add the support of DDR2-533,667,800 DIMMs 4. cpo 5. make the AL to min to gain better performance. The Micron MT9HTF6472CHY-667D1 DIMMs test passed on MPC837xEMDS platform at 266MHz/333MHz/400MHz data rate. items 1, 2 and 5: Acked-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Reported-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-05MPC8349ITX: several config issues fixedValeriy Glushkov
The previous version rebooted forever with DDR bigger than 256MB. Access the DS1339 RTC chip is on I2C1 bus. Allow DHCP. Signed-off-by: Valeriy Glushkov <gvv@lstec.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-05mpc83xx: MPC837XEMDS: Initialize SerDes before negating PCIE reset signalAnton Vorontsov
The SerDes initialization should be finished before negating the reset signal according to the reference manual. This isn't an issue on real hardware, but we'd better stick to the specifications anyway. Suggested-by: Liu Dave <DaveLiu@freescale.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-02i2c, dtt: move dtt_init () to board_init_r ()Heiko Schocher
it is not necessary to init the DTTs so early, so move this init to board_init_r (). Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-25lcd: Fix compilation warning in common/lcd.cAnatolij Gustschin
Fix following warning while compilation for mcc200 board: lcd.c: In function 'lcd_display_bitmap': lcd.c:625: warning: unused variable 'cmap' Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-02-25Moved SC520 Files (fix commit 407976185e0dda2c90e89027121a1071b9c77bfb)Graeme Russ
Fixes commit 407976185e0dda2c90e89027121a1071b9c77bfb Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-02-25smc911x: split out useful defines/functions into local headerMike Frysinger
The smc911x driver has a lot of useful defines/functions which can be used by pieces of code (such as example eeprom programmers). Rather than forcing each place to duplicate these defines/functions, split them out of the smdc911x driver into a local header. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Guennadi Liakhovetski <lg@denx.de> CC: Magnus Lilja <lilja.magnus@gmail.com> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-24Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2009-02-24Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-02-24ARM: add an "eet" variant of the imx31_phycore boardGuennadi Liakhovetski
The "eet" variant of the imx31_phycore board has an OLED display, using a s6e63d6 display controller on the first SPI interface, using GPIO57 as a chip-select for it. With this configuration you can display 256 colour BMP images in 16-bit RGB (RGB565) LCD mode. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-24video: add an i.MX31 framebuffer driverGuennadi Liakhovetski
Add a driver for the Synchronous Display Controller and the Display Interface on i.MX31, using IPU for DMA channel setup. So far only displaying of bitmaps is supported, no text output. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2009-02-24LCD: support 8bpp BMPs on 16bpp displaysGuennadi Liakhovetski
This patch also simplifies some ifdefs in lcd.c, introduces a generic vidinfo_t, which new drivers are encouraged to use and old drivers to switch over to. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2009-02-24Add 16bpp BMP supportMark Jackson
This patch adds 16bpp BMP support to the common lcd code. Use CONFIG_BMP_16BPP and set LCD_BPP to LCD_COLOR16 to enable the code. At the moment it's only been tested on the MIMC200 AVR32 board, but extending this to other platforms should be a simple task !! Signed-off-by: Mark Jackson <mpfj@mimc.co.uk> Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2009-02-24A driver for the S6E63D6 SPI display controller from SamsungGuennadi Liakhovetski
This is a driver for the S6E63D6 SPI OLED display controller from Samsung. It only provides access to controller's registers so the client can freely configure it. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2009-02-24i.MX31: support GPIO as a chip-select in the mxc_spi driverGuennadi Liakhovetski
Some SPI devices have special requirements on chip-select handling. With this patch we can use a GPIO as a chip-select and strictly follow the SPI_XFER_BEGIN and SPI_XFER_END flags. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-24i.MX31: add a simple gpio driverGuennadi Liakhovetski
This is a minimal driver, so far only managing output. It will be used by the mxc_spi.c driver. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-24i.MX31: fix SPI driver for shorter than 32 bitGuennadi Liakhovetski
Fix setting the SPI Control register, 8 and 16-bit transfers and a wrong pointer in the free routine in the mxc_spi driver. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-23mpc83xx: MPC837XERDB: Add PCIe supportAnton Vorontsov
On MPC8377E-RDB and MPC8378E-RDB boards we have PCIe and mini-PCIe slots. Let's support them. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-23mpc83xx: PCI: Fix hard-coded first_busno valueAnton Vorontsov
We should use pci_last_busno() in pci_init_bus(), otherwise we'll erroneously re-use PCI0's first_busno for PCI1 hoses. NOTE: The patch is untested. All MPC83xx FSL boards I have have PCI1 in miniPCI form, for which I don't have any cards handy. But looking in cpu/mpc85xx/pci.c: ... #ifdef CONFIG_MPC85XX_PCI2 hose = &pci_hose[1]; hose->first_busno = pci_hose[0].last_busno + 1; And considering that we do the same for MPC83xx PCI-E support, I think this patch is correct. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-23mpc83xx: PCI: Fix bus-range fdt fixups for PCI1 controllersAnton Vorontsov
This patch fixes copy-paste issue: pci_hose[0]'s first and last busnos were used to fixup pci1's nodes. We don't see this bug triggering only because Linux reenumerate buses anyway. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-23mpc83xx: PCIe: Fix CONFIG_PCI_SCAN_SHOW reporting bogus valuesAnton Vorontsov
This patch fixes an issue in config space read accessors: we should fill-in the value even if we fail (e.g. skipping devices), otherwise CONFIG_PCI_SCAN_SHOW reports bogus values during boot up. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-23mpc83xx: PCIe: Don't start bus enumeration at 0Anton Vorontsov
Currently we assign first_busno = 0 for the first PCIe hose, but this scheme won't work if we have ordinary PCI hose already registered (its first_busno value is 0 too). The old code worked fine only because we have PCI disabled on MPC837XEMDS boards in stand-alone mode (see commit 00f7bbae92e3b13f2b3 "mpc83xx: fix PCI scan hang on the standalone MPC837xE-MDS boards"). But on MPC837XERDB boards we have PCI and PCIe, so the bug actually triggers. So, to fix the issue, we should use pci_last_busno() + 1 for the first_busno (i.e. last available busno). Reported-by: Huang Changming <Chang-Ming.Huang@freescale.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-23PCI: Add pci_last_busno() helperAnton Vorontsov
This is just a handy routine that reports last PCI busno: we walk down all the hoses and return last hose's last_busno. Will be used by PCI/PCIe initialization code. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-23MPC86xx: set CONFIG_MAX_MEM_MAPPED to 2G by defaultBecky Bruce
Currently, we get 256MB as the default, but since all the 86xx board configs define a 2G BAT mapping for RAM, raise default to 2G. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2009-02-23mpc8641hpcn: Indicate 36-bit addr map in boot messagesBecky Bruce
If 36-bit addressing is enabled, print a message on the console when we boot. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-23Merge branch 'master' of git://git.denx.de/u-bootKim Phillips
2009-02-22netloop: speed up NetLoopHeiko Schocher
NetLoop polls every cycle with getenv some environment variables. This is horribly slow, especially when the environment is big. This patch reads only the environment variables in NetLoop, when they were changed. Also moved the init part of the NetLoop function in a seperate function. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-22smc911x_eeprom: new example app for managing newer SMC partsMike Frysinger
A forward port of the last version to work with the newer smc911x driver. I only have a board with a LAN9218 part on it, so that is the only one I've tested. But there isn't anything in this that would make it terribly chip specific afaik. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Guennadi Liakhovetski <lg@denx.de> CC: Magnus Lilja <lilja.magnus@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-22Added Vitesse VSC8211 definitions to TSEC driverPieter Henning
Added the struct containing PHY settings for the Vitesse VSC8211 phy to the phy_info list in tsec.c Signed-off-by: Pieter Henning <phenning@vastech.co.za> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-23Update CHANGELOG; Prepare 2009.03-rc1v2009.03-rc1Wolfgang Denk
2009-02-22ARM: synchronize mach-types.h with linux v2.6.29-rc5-315-g683fdc5Wolfgang Denk
The file was generated from building versatile_defconfig. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-22Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2009-02-22Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
