2004-08-01* Fix NSCU config; add ethernet wakeup code.wdenk
* Add link for preloader for Motorola Coldfire to RAEDME.m68k
2004-07-15Patch by Stefan Roese, 15 Jul 2004stroese
2004-07-15cpu/ppc4xx/sdram.c rewritten now using get_ram_size()stroese
2004-07-12Patch by Michael Bendzick, 12 Jul 2004:wdenk
fix output formatting in drivers/cfi_flash.c
2004-07-12Patch by Mark Jonas, 02 Jul 2004:wdenk
Fix lowboot (again) on MPC5xxx
2004-07-11Add cerf250 to MAINTAINERS and READMEwdenk
2004-07-11Patch by Curt Brune, 07 Jul 2004:wdenk
relocate exception vectors on arm720t if needed
2004-07-11* Patch by George G. Davis, 06 Jul 2004:wdenk
- update mach-types.h to latest arm.linux.org.uk master list - Set correct OMAP1610 bi_arch_number for build target * Patch by Curt Brune, 06 Jul 2004: evb4510: add support for timer interrupt; cleanup
2004-07-11* Patch by Dan Poirot, 06 Jul 2004:wdenk
Fix sbc8260 environment variables * Cleanup redundand "console" environment variable
2004-07-11* Cleanupwdenk
* Patch by Mark Jonas, 05 Jul 2004: add support for the Total5100's and Total5200's LCD screen * Patches by Dan Eisenhut, 01 Jul 2004: - README fixes. - Move doc2000.h include to prevent compiler warning on some boards
2004-07-11Patch by Mark Jonas, 01 Jul 2004:wdenk
Added support for Total5100 and Total5200 (Rev.1 and Rev.2) MGT5100 and MPC5200 based Freescale platforms.
2004-07-11* Patch by Philippe Robin, 01 Jul 2004:wdenk
Add initialization for Integrator and versatile board files. * Patch by Hinko Kocevar, 01 Jun 2004: Fix VFD FB allocation, add LCD FB allocation on ARM
2004-07-11* Patch by Martin Krause, 30 Jun 2004:wdenk
Add support for TQM5200 board * Patch by Martin Krause, 29 Jun 2004: Add loopw command: infinite write loop on address range
2004-07-10Patches by Yasushi Shoji, 29 Jun 2004:wdenk
- add empty include/asm-microblaze/processor.h - add to CREDITS and MAINTAINERS - add gd initialization - add MicroBlaze and SUZAKU board to MAKEALL script - add reset support for SUZAKU - add flush_cache() for MicroBlaze - add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed size flash memory on SUZAKU
2004-07-10* Patch by Prakash Kumar, 27 Jun 2004:wdenk
Add support for the PXA250 based Intrinsyc Cerf board. * Patch by Yasushi Shoji, 27 Jun 2004: fix comment in include/common.h
2004-07-10Fix swapped config files.wdenk
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
2004-07-10* Patch by Fred Klatt, 25 Jun 2004:wdenk
Add support for WindRiver's SBC8560 board * Patch by Nicolas Lacressonniere, 24 Jun 2004 Small Bugs fixes for "at91rm9200dk" board: - Timing modifications for SPI DataFlash access - Fix NAND flash detection bug * Patch by Nicolas Lacressonniere, 24 Jun 2004: Add Support for Flash AT49BV6416 for AT91RM9200DK board
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
2004-07-09* Patch by Yuli Barcohen, 16 Jun 2004:wdenk
Remove obsolete AdderII port which was superseded by unified AdderII/Adder87x port * Patch by Ladislav Michl, 16 Jun 2004: Fix gcc-3.3.3 warnings for smc91111.c
2004-07-02Patch by Stefan Roese, 02 Jul 2004stroese
2004-07-02Fix problem in 405 i2c driver; don't try to print without console!stroese
2004-07-02Fix bug in 405 ethernet driver; allocated data not cleared!stroese
2004-07-01Patch by Paul Ruhland, 11 Jun 2004:wdenk
Remove debug code from 'board/lpd7a40x/flash.c'
2004-07-01Patch by Andrea Marson, 11 Jun 2004:wdenk
Update for PPChameleon board: - support for SysClk @ 25MHz - support for Silicon Motion SM712 VGA controller - some clean ups
2004-07-01* Patches by Richard Woodruff, 10 Jun 2004:wdenk
- fix problems with examples/stubs.c for GCC >= 3.4 - fix problems with gd initialization * Enable FAT filesystem support for HMI10 board
2004-07-01* Code cleanup (ARM mostly)wdenk
* Patch by Curt Brune, 17 May 2004: - Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC) - Add support for ESPD-Inc. EVB4510 Board
2004-06-30* Fix "cls" command when used with splash screenLABEL_2004_07_01_1200wdenk
* Increase NFS download timeout (now 1 min - 10 sec is to short for a slow download of a big image)
2004-06-25Add "cls" function to MPC823 LCD driver so we can reinitialize thewdenk
display even after showing a bitmap
2004-06-24Add MicroSys maintainer.LABEL_2004_06_24_1800wdenk
2004-06-19Patch by Josef Wagner, 04 Jun 2004:wdenk
- DDR Ram support for PM520 (MPC5200) - support for different flash types (PM520) - USB / IDE / CF-Card / DiskOnChip support for PM520 - 8 bit boot rom support for PM520/CE520 - Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245) - I2C and RTC support for CPC45 - support of new flash type (28F160C3T) for CPC45
2004-06-17* Fix flash parameters passed to Linux for PPChameleon boardwdenk
* Remove eth_init() from lib_arm/board.c; it's done in net.net.c.
2004-06-10* Patch by Paul Ruhland, 10 Jun 2004:wdenk
fix support for Logic SDK-LH7A404 board and clean up the LH7A404 register macros. * Patch by Matthew McClintock, 10 Jun 2004: Modify code to select correct serial clock on Sandpoint8245
2004-06-10* Patch by Robert Schwebel, 10 Jun 2004:wdenk
Add support for Intel K3 strata flash. * Some cleanup * Patch by Thomas Brand, 10 Jun 2004: Fix "loads" command on DK1S10 board
2004-06-09Remove duplicate entrywdenk
2004-06-09Patch by Yuli Barcohen, 09 Jun 2004:wdenk
Add support for 8MB flash SIMM and JFFS2 file system on Motorola FADS board and its derivatives (MPC86xADS, MPC885ADS).
2004-06-09* Patch by Yuli Barcohen, 09 Jun 2004:wdenk
Add support for Analogue&Micro Adder87x and the older AdderII board. * Patch by Ming-Len Wu, 09 Jun 2004: Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
2004-06-09Patch by Sam Song, 09 Jun 2004:wdenk
- Add support for RPXlite_DW board - Update FLASH driver for 4*AM29DL323DB90VI - Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
2004-06-09* Patch by Mark Jonas, 08 June 2004:wdenk
- Make MPC5200 boards evaluate the SVR to print processor name and version in checkcpu() (cpu/mpc5xxx/cpu.c). * Patch by Kai-Uwe Bloem, 06 May 2004: Fix endianess problem in cramfs code
2004-06-09* Patch by Tom Armistead, 04 Jun 2004:wdenk
Add support for MAX6900 RTC * Patches by Ladislav Michl, 03 Jun 2004: - fix cfi_flash.c on LE systems - let 'make mrproper' delete u-boot.img as well - turn printf into debug in cfi_flash.c
2004-06-09Patch by Kurt Stremerch, 28 May 2004:wdenk
Add support for Exys XSEngine board Some code cleanup.
2004-06-09* Patch by Martin Krause, 27 May 2004:wdenk
Fix a MPC5xxx I2C timing issue in i2c_probe(). * Patch by Leif Lindholm, 27 May 2004: Fix board_init_f() for dbau1x00 board.
2004-06-09* Patch by Imre Deak, 26 May 2004:wdenk
On OMAP1610 platforms check if booting from RAM(CS0) or flash(CS3). Set flash base accordingly, and decide whether to do or skip board specific setup steps. * Patch by Josef Baumgartner, 26 May 2004: Add missing define in include/asm-m68k/global_data.h
2004-06-09* Patch by Josef Baumgartner, 25 May 2004:wdenk
Add missing functions get_ticks() and get_tbclk() in lib_m68k/time.c * Patch by Paul Ruhland, 24 May 2004: fix SDRAM initialization for LPD7A400 board.
2004-06-09Patch by Jian Zhang, 20 May 2004:wdenk
add support for environment in NAND flash
2004-06-09Patch by Yuli Barcohen, 20 May 2004:wdenk
Add support for Interphase iSPAN boards.
2004-06-09* Patch by Paul Ruhland, 17 May 2004:wdenk
- Add support for the Logic Zoom LH7A40x based SDK board(s), specifically the LPD7A400. * Patches by Robert Schwebel, 15 May 2004: - call MAC address reading code also for SMSC91C111; - make SMSC91C111 timeout configurable, remove duplicate code - fix get_timer() for PXA - update doc/README.JFFS2 - use "bootfile" env variable also for jffs2
2004-06-09Patch by Tolunay Orkun, 14 May 2004:wdenk
Add support for Cogent CSB472 board (8MB Flash Rev)
2004-06-09Patch by Thomas Viehweger, 14 May 2004:wdenk
- flash.h: more flash types added - immap_8260.h: some bits added (useful for RMII) - cmd_coninfo.c: typo corrected, printf -> puts - reduced size by replacing spaces with tab
2004-06-09Patch by Robert Schwebel, 13 May 2004:wdenk
Add 'imgextract' command: extract one part of a multi file image.
