Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Since commit 41623c91b09a0c865fab41acdaff30f060f29ad6 u-boot running in qemu is
crashing in function do_omap3_emu_romcode_call(). RX-51 board uses this function
for Cortex-A8 errata 430973 workaround (Set IBE bit in ACR) which is needed only
on real secure device and not in qemu.
This board patch just disable calling secure PPA routine on non secure devices.
Qemu implements GP device and with this patch u-boot is working in qemu again.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Add Peter Tyser as the maintainer of Extreme Engineering Solutions products.
Convert Extreme Engineering Solutions products to use generic board
support.
Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
- "string" type for SYS_* is defined in arch/Kconfig
- SYS_CPU "armv7" has been replaced with "select CPU_V7"
- SYS_SOC "tegra124" is already defined in tegra124/Kconfig
Acked-by: Bo Shen <voice.shen@atmel.com>
Commit 1e4ad74b875f (beagle_x15: add board support for Beagle x15)
missed to add board/ti/beagle_x15/MAINTAINERS.
Cc: Felipe Balbi <balbi@ti.com>
This commit fixes warnings reported by tools/genboardscfg.py.
Cc: Vikas Manocha <vikas.manocha@st.com>
Acked-by: Vikas Manocha <vikas.manocha@st.com>
Signed-off-by: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net>
When CONFIG_TRACE is disabled, linking fails with:
common/built-in.o:(.data.init_sequence_f+0x8): undefined reference to `trace_early_init'
To fix, wrap trace init calls with #ifdef CONFIG_TRACE.
While at it, remove the static inline version of the init call from
trace.h as suggested by Simon Glass, since it doesnt work.
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The two error checks for image_boot_mode_id and image_nand_ecc_mode_id where
wrong and would never fail, fix that!
This was detected by Apple's clang compiler:
---8<---
HOSTCC tools/kwbimage.o
tools/kwbimage.c:553:20: warning: comparison of unsigned expression < 0 is always false [-Wtautological-compare]
if (el->bootfrom < 0) {
tools/kwbimage.c:571:23: warning: comparison of unsigned expression < 0 is always false [-Wtautological-compare]
if (el->nandeccmode < 0) {
2 warnings generated.
--->8---
Acked-By: Jeroen Hofstee <jeroen@myspectrum.nl>
Remove unused vsync parameter, and correct the include file.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Correct the LCD pixel clock, remove unused vsync parameter,
and also correct the include file.
When building with my toolchain (4.8.2):
CROSS_COMPILE=/home/lukma/work/ptxdist/toolchains/arm/OSELAS.Toolchain-2013.12.0/arm-v7a-linux-gnueabi/gcc-4.8.2-glibc-2.18-binutils-2.24-kernel-3.12-sanitized/bin/arm-v7a-linux-gnueabi-
I see following WARNING:
tools/kwbimage.c: In function "kwbimage_set_header":
tools/kwbimage.c:803:8: warning: "headersz" may be used uninitialized in this function [-Wmaybe-uninitialized]
memcpy(ptr, image, headersz);
This fix aims to suppress it.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Heiko Schocher <hs@denx.de>
MetaWare debugger (MDB) is still used as a primary tool for interaction
with target via JTAG. Moreover some very advanced features are not yet
implemented in GDB for ARC (and not sure if they will be implemnted
sometime soon given complexity and rare need for those features for
common user).
So if we're talking about development process when U-Boot is loaded in
target memory not by low-level boot-loader but manually through JTAG
chances are high developer uses MDB for it.
But MDB doesn't support PIE (position-independent executable) - it will
refuse to even start - that means no chance to load elf contents on
target.
Then the only way to load U-Boot in MDB is to fake it by:
1. Reset PIE flag in ELF header
This is simpe - on attempt to open elf MDB checks header and if it
doesn't match its expectation refuces to use provided elf.
2. Strip all debug information from elf
If (1) is done then MDB will open elf but on parsing of elf's debug
info it will refuse to process due to debug info it cannot understand
(symbols with PIE relocation).
Even though it could be done manually (I got it documented quite a while
ago here http://www.denx.de/wiki/U-Boot/ARCNotes) having this automated
way is very convenient. User may build U-Boot that will be loaded on
target via MDB saying "make mdbtrick".
Then if we now apply the manipulation MDB will happily start and will
load all required sections into the target.
Indeed there will be no source-level debug info available. But still MDB
will do its work on showing disassembly, global symbols, registers,
accessing low-level debug facilities etc.
As a summary - this is a pretty dirty hack but it simplifies life a lot
for us ARc developers.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Currently, "nand scrub" runs chip->scan_bbt at the end of
nand_erase_opts() even if NAND_SKIP_BBTSCAN flag is set.
It violates the intention of NAND_SKIP_BBTSCAN.
Move NAND_SKIP_BBTSCAN flag check to nand_block_checkbad() so that
chip->scan_bbt() is never run if NAND_SKIP_BBTSCAN is set.
Also, unset NAND_BBT_SCANNED flag instead of running chip->scan_bbt()
right after scrub. We can be lazier here because the BBT is scanned
at the next call of nand_block_checkbad().
Cc: Scott Wood <scottwood@freescale.com>
Commit 35c204d8a9d0 (nand: reinstate lazy bad block scanning)
broke NAND_BBT_USE_FLASH feature.
Its git-log claimed that it reinstated the change as by commit
fb49454b1b6c ("nand: reinstate lazy bad block scanning"), but it moved
"chip->options |= NAND_BBT_SCANNED" below "chip->scan_bbt(mtd);".
It causes recursion if scan_bbt does not find a flash based BBT
and tries to write one, and the attempt to erase the BBT area
causes a bad block check.
Reinstate commit ff49ea8977b5 (NAND: Mark the BBT as scanned prior to
calling scan_bbt.).
Cc: Rostislav Lisovy <lisovy@merica.cz>
Since commit ff94bc40af34 (mtd, ubi, ubifs: resync with Linux-3.14),
the "nand scrub" command has not been working.
Boot from SD-card (and probably also from NAND) was broken since
commit d6d07a9bec ("arm: vf610: add NAND support for vf610twr").
It looks like the increased size of U-Boot lead to a situation
where the boot ROM overwrote its own stack/heap while loading
U-Boot from the SD-card to the SRAM. However, U-Boot worked fine
when loaded through USB serial loader directly into SRAM. It
looks like loading from SD-card uses other stack/heap location
then the serial loader (or maybe no stack or heap at all).
This fix moves U-Boot to gfxRAM, which is 512kB in size and is not
used by the boot ROM nor the SD-card loader of it.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Acked-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
Resynchronize memcpy/memset with kernel 3.17 and build them in
Thumb2 mode (unified syntax). Those assembler files can be built
and linked in ARM mode too, however when calling them from Thumb2
built code, the stack got corrupted and the copy did not succeed
(the exact details have not been traced back). However, the Linux
kernel builds those files in Thumb2 mode. Hence U-Boot should
build them in Thumb2 mode too when CONFIG_SYS_THUMB_BUILD is set.
To build the files without warning, some assembler instructions
had to be replaced with their UAL compliant variant (thanks
Jeroen for this input).
To build the file in Thumb2 mode the implicit-it=always option need
to be set to generate Thumb2 compliant IT instructions where needed.
We add this option to the general AFLAGS when building for Thumb2.
Since commit 3ff46cc42b9d73d0 ("arm: relocate the exception vectors") mx25pdk
hangs like this:
CPU: Freescale i.MX25 rev1.2 at 399 MHz
Reset cause: WDOG
Board: MX25PDK
I2C: ready
DRAM: 64 MiB
(hangs)
Add a specific relocate_vectors macro that skips the vector relocation, as the
i.MX25 SoC does not provide RAM at the high vectors address (0xFFFF0000), and
(0x00000000) maps to ROM.
This allows mx25 to boot again.
Acked-By: Bill Pringlemeir <bpringlemeir@nbsps.com>
Add CONFIG_SYS_FSL_QSPI_AHB in header file to enable AHB in driver.
In order to count the time, add CONFIG_CMD_TIME.
Using AHB read can improve the the read speed about 30%.
AHB read:
=> time sf read 0x8f800000 0 100000
SF: 1048576 bytes @ 0x0 Read: OK
time: 0.174 seconds
=> time sf read 0x8f800000 1000000 100000
SF: 1048576 bytes @ 0x1000000 Read: OK
time: 0.174 seconds
IP read:
time: 0.227 seconds
time: 0.227 seconds
Note:
Quad read is not supported in driver, now. In my side, using AHB and Quad read
can achieve about 16MB/s. Anyway, I have plan to reimplement the driver using
DTB and DM, then make the code cleaner and more feature can be added.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
The QSPI controller in i.MX 6SoloX and Vybrid supports reading data using
IP register and AHB bus.
The original driver only supports reading data from IP interface. The IC
team suggests to use AHB read which is faster then IP read. Using AHB read,
we can directly memcpy, a "missed" access to the buffer will cause the
controller to clear the buffer and use the SEQID stored in bfgencr register
to initiate a read from flash device.
Since AHB bus is 64 bit width, we can not set MCR register using 32bit. In
order to minimize code change, redefine QSPI_MCR_END_CFD_LE to 64bit Little
endian but not 32bit Little endia.
Introduce a new configuration option CONFIG_SYS_FSL_QSPI_AHB. If want to
use AHB read, just define CONFIG_SYS_FSL_QSPI_AHB. If not, just ignore it.
Actually if Vybrid is migrated to use AHB read, this option can be removed and
IP read function can be discared. The reason to introduce this option
is that only i.MX SOC is tested in my side, no Vybrid platform for me.
In spi_setup_slave, the original piece code to set AHB is deleted, since
Vybrid platform does not use this to intiate AHB read. Instead, add
qspi_init_ahb_read function if defined CONFIG_SYS_FSL_QSPI_AHB.
Fix several spelling errors and replace the invalid word
"architectured" with "designed".
Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com>
Currently there is an unneeded empty line after printing the reset cause:
U-Boot 2015.01-rc4-00080-g0551a93 (Jan 06 2015 - 13:04:19)
Reset cause: POR
Board: MX25PDK
I2C: ready
DRAM: 64 MiB
MMC: FSL_SDHC: 0
Remove the extra "\n" when printing the reset cause.
We should not hardcode array size of i2c_data to 3. To CONFIG_FSL_LSCH3,
there are 4 i2c interface, but not 3. So the size of i2c_data array should
be calculated using "ARRAY_SIZE(i2c_bases)".
To avoid compile error, move i2c_bases before sram_data structure which
contains i2c_data array.
Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
CC: Prafulla Wadaskar <prafulla@marvell.com>
CC: Wolfgang Denk <wd@denx.de>
According to the UEFI Spec (Table 16, section 5.2.3 of the version 2.4 Errata
B), the protective MBR partition record size must be set to the size of the
disk minus one, in LBAs.
However, the current code was setting the size as the total number of LBAs on
the disk, resulting in an off-by-one error.
This confused the AM335x ROM code, and will probably confuse other tools as
well.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Commit 73c25753 fixed the common issue that binutil packages (tool/organization
that packaged or built the bin-utils) are included in brackets and this may
falsely be recognized as a version. However, some tools do not provide a
'package' and previously we add the 'Gnu assembler..' to the version.
Strip out the '(package version text)' and then look for a ##.## string.
Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
