Add writebcb command which creates a NAND Boot Configuration Block
(BCB) at the beginning of the active flash device. The BCB stores
the information for the SoC internal boot ROM where the application
with a valid IVT header can be found on the NAND device. The first
two argument of the command need an offset of the NAND device where
the primary and secondary application can be found.
Typically, U-Boot is the application which gets loaded by the boot
ROM. Hence, the offset address need to be the address where U-Boot
(u-boot.imx along with a 0x400 long prefix) is stored on the device.
At least one location is mandatory.
Currently only the FCB (Firmware Configuration Block) is written to
the device. The DBBT (Discovered Bad Block Table) is optional and
not created by writebcb currently.
The MTD subsystem now uses mtd_to_nand to get to the struct
nand_chip pointer. Use mtd_to_nand in mxs_nand_get_ecc_strength
too.
Modification taken from imx-kobs-5.3.
Should have "&" to access the register address, otherwise uboot will hang.
Signed-off-by: Ye Li <ye.li@nxp.com>
This patch is a porting of
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_4.1.15_1.0.0_ga&id=e4dacc44d22e9474ec456cb330df525cd805ea38
i.MX6QP and i.MX7D BCH module integrated a new feature to detect the
bitflip number for erased NAND page. So for these two platform, set the
erase threshold to gf/2 and if bitflip detected, GPMI driver will
correct the data to all 0xFF.
Also updated the imx6qp dts file to ditinguish the GPMI module for i.MX6Q
with the one for i.MX6QP.
In this patch, i.MX6UL is added and threshold changed to use ecc_strength.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
This patch is porting from linux:
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_4.1.15_1.0.0_ga&id=3d42fcece496224fde59f9343763fb2dfc5b0768
We may meet the bitflips in reading an erased page(contains all 0xFF),
this may causes the UBIFS corrupt, please see the log from Elie:
[ 3.831323] UBI warning: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read only 16384 bytes, retry
[ 3.845026] UBI warning: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read only 16384 bytes, retry
[ 3.858710] UBI warning: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read only 16384 bytes, retry
[ 3.872408] UBI error: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read 16384 bytes
[ 4.011529] UBIFS error (pid 36): ubifs_recover_leb: corrupt empty space LEB 27:237568, corruption starts at 9815
[ 4.021897] UBIFS error (pid 36): ubifs_scanned_corruption: corruption at LEB 27:247383
[ 4.030000] UBIFS error (pid 36): ubifs_scanned_corruption: first 6569 bytes from LEB 27:247383
This patch does a check for the uncorrectable failure in the following steps:
[0] set the threshold.
The threshold is set based on the truth:
"A single 0 bit will lead to gf_len(13 or 14) bits 0 after the BCH
do the ECC."
For the sake of safe, we will set the threshold with half the gf_len, and
do not make it bigger the ECC strength.
[1] count the bitflips of the current ECC chunk, assume it is N.
[2] if the (N <= threshold) is true, we continue to read out the page with
ECC disabled. and we count the bitflips again, assume it is N2.
(We read out the whole page, not just a chunk, this makes the check
more strictly, and make the code more simple.)
[3] if the (N2 <= threshold) is true again, we can regard this is a erased
page. This is because a real erased page is full of 0xFF(maybe also has
several bitflips), while a page contains the 0xFF data will definitely
has many bitflips in the ECC parity areas.
[4] if the [3] fails, we can regard this is a page filled with the '0xFF'
data.
provide one config "CONFIG_NAND_MXS_BCH_LEGACY_GEO" to keep using legacy
bch geometry.
NOTICE: the feature must be enabled/disabled in both u-boot and kernel.
Signed-off-by: Han Xu <han.xu@nxp.com>
(cherry picked from commit 0abc9c182c24f88522bd74fa1b53cd2fa3477184)
The cod change updated the NAND driver BCH ECC layout algorithm to
support large oob size NAND chips(oob > 1024 bytes).
Current implementation requires each chunk size larger than oob size so
the bad block marker (BBM) can be guaranteed located in data chunk. The
ECC layout always using the unbalanced layout(Ecc for both meta and
Data0 chunk), but for the NAND chips with oob larger than 1k, the driver
cannot support because BCH doesn’t support GF 15 for 2K chunk.
The change keeps the data chunk no larger than 1k and adjust the ECC
strength or ECC layout to locate the BBM in data chunk. General idea for
large oob NAND chips is
1.Try all ECC strength from the minimum value required by NAND spec to
the maximum one that works, any ECC makes the BBM locate in data chunk
can be chosen.
2.If none of them works, using separate ECC for meta, which will add one
extra ecc with the same ECC strength as other data chunks. This extra
ECC can guarantee BBM located in data chunk, of course, we need to check
if oob can afford it.
Signed-off-by: Han Xu <b45815@freescale.com>
Use two separate partitions for the two firmware instances. Also
resize them to be of the same size which also makes the start of
the UBI partition nicely aligned to 0x400000.
In order to detect the new MTD layout and whether we run a U-Boot
with the new BCB format or not, introduce a variable called
"updlevel" which we can use in update/upgrade scripts.
The CAAM driver of the downstream i.MX 7 Linux kernel seems not to
work well when booting in non-secure:
caam 30900000.caam: Entropy delay = 3200
caam 30900000.caam: failed to acquire DECO 0
caam 30900000.caam: Entropy delay = 3600
caam: probe of 30900000.caam failed with error -11
Unable to handle kernel NULL pointer dereference at virtual address 00000004
Default booting in secure mode. If non-secure is preferred (e.g.
required for virtualization on a mainline kernel) one can use
setenv bootm_boot_mode nonsec
Use the proper config option to guard the USB Download Function
fixup callback.
(cherry picked from commit beaf40688ba7303e9db50558b3852c79437eecad)
Limit memory used for relocation of FDT or initrd. This is
required to make sure that relocated artifacts are within lowmem.
If fdt_high or initrd_high are not set, U-Boot automatically
relocates artifacts to the end of memory. But this area won't
be part of lowmem and hence will not be accessible by the kernel
during early boot.
With VM split set to 2G/2G (i.MX default), only the 2GB Apalis
iMX6 is affected by that issue. With VM split set to 3G/1G (ARM
default) also modules with 1GB of memory are affected. With the
latter the amount of lowmem will be 760MiB.
The value must also not exceed available memory! Use a safe value
of 512MiB for Apalis and 256MiB for Colibri.
Introduce USB Gadget config option. This allows to combine Makefile
entries for SPL_USBETH_SUPPORT and SPL_DFU_SUPPORT.
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Ravi Babu <ravibabu@ti.com>
(cherry picked from commit e94793c844a40606252f2e3f6428063e057b3fd2)
The DFU Kconfig menu entries should be part of the SPL
Kconfig file. Also avoid using the top level Makefile by
moving the config dependent build artifacts to the driver/
and driver/usb/gadget/ Makfiles.
With that, DFU can be built again in SPL if
CONFIG_SPL_DFU_SUPPORT is enabled.
Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now")
(cherry picked from commit 5991703e88f320767d9390d64a6a9bd62560696b)
Some devices (e.g. dra7xx) support loading to RAM using DFU without
having direct boot from RAM support. Make sure the linker list
does not contain BOOT_DEVICE_RAM if CONFIG_SPL_RAM_DEVICE is not
enabled.
Fixes: 98136b2f26fa ("spl: Convert spl_ram_load_image() to use linker list")
(cherry picked from commit 34ee947ac3be7a79b89fa8bb690379651cc9598a)
All modules use the common g_dnl_bind_fixup implementaton which
calculates the PID according to product id (read from the config
block) plus offset of 0x4000. In case there is no config block
support (e.g. SPL) or in case the config block is not readable,
fall back to a generic product id (product id 0, which can be
interpreted as "Unknown Module").
Specify standard padding for payload to 68KB. This is derived from
the maximum header size plus maximum SPL size. It matches the
already defined offset for SD/eMMC devices (69KB) too. This allows
to use the u-boot-with-spl.imx build target to generate a directly
flashable image which can be flashed using:
dd if=u-boot-with-spl.imx of=/dev/mmcblk0 bs=512 skip=2
While the patch has been created with SD/eMMC in mind, this also
works with other boot media. The board file needs to configure the
media specific (absolute) payload offset accordingly. Especially
the IVT offset is boot media specific and can be retrieved from the
reference manual (Table 8-25. Image Vector Table Offset and Initial
Load Region Size). For NAND boot a define like this should do the
job:
#define CONFIG_SYS_NAND_U_BOOT_OFFS (SPL_PAD_TO + 0x400)
(cherry picked from commit 0405092bd21a44f5af22f17aeb0b82a0a11e1252)
Add an additional target which prepends the u-boot.imx image with
0x400 padding bytes. On Vybrid and i.MX 7, this is required for
NAND boot devices. The configuration CONFIG_IMX_NAND enables this
image for a board.
[ported to v2016.11]
Actually make use of that shiny new CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK.
Introduce CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK to disable the external clock
loopback and use the internal one on SDMMC3 as per the SDMMC_VENDOR_MISC_CNTRL_0
register's SDMMC_SPARE1 bits being set to 0xfffd according to the TRM.
Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in
include/configs/tegra-common-post.h unchanged.
This patch adds board support for the Toradex Apalis TK1 a computer on
module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot, environment storage and Toradex factory config block
- Gigabit Ethernet
- MMC/SD cards (both MMC1 as well as SD1 slot)
- USB client/host (dual role OTG port as client e.g. for DFU/UMS or host,
other two ports as host)
This adds board support for the Toradex module family Colibri iMX6.
The familiy consists of a module with i.MX6 DualLite, i.MX6 Solo, both
with a version for commercial and industrial temperature range.
(cherry picked from commit a02d517b0182f83771565eba1329fb323674ec58)
This adds board support for the Toradex module family Apalis iMX6.
The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with
(cherry picked from commit 592f4aed6db765172e21f228800b49f9a27ff201)
If the module is in serial downloader mode, we do no longer read the
environment from eMMC. Therefor, the eMMC is unitialized when trying
to read the config block. Use mmc_init to initialize the selected
MMC device before using it.
Note: In case the MMC has already been initialized, the mmc_init
detects that and returns immediately.
board/toradex/common/configblock.c
The ipu has two display interfaces. Make the used one a parameter
in struct display_info_t instead of using unconditionally DI0.
DI0 is the default setting.
Reviewed-by: Eric Nelson <eric@nelint.com>
(cherry picked from commit 15fde0fc11f93f19f40c9cda36e7c8d4848d9c75)
If CONFIG_SPL_LIBCOMMON_SUPPORT is not defined there is a lone case statement
at the end of the switch leading to a compile error.
Remove the offending case statement.
| common/spl/spl_mmc.c:339:7: error: label at end of compound statement
(cherry picked from commit c8d7647f639813cff08a4a7de62db815829ec72b)
Currently a divider of 6 has been used, leading to following NAND
Flash Controller (NFC) clocks:
VF61: 27.7 MHz (166.7MHz bus clock)
VF50: 22 MHz (132MHz bus clock)
The NAND Flash Memory used on VF50 allows to use clock speed of
up to 33MHz, while the Flash Memory of VF61 allows 50MHz. We can
use the same divider of 4 on both modules to configure the maximal
possible clock speeds:
VF61: 41.7 MHz
VF50: 33 MHz
(cherry picked from commit 0eba4c41ca18f8f009126dcacc647927accaa63d)
Use the same preprocessor define to enable clocks as we use to
enable the driver. Make sure that the necessary PLL's are on
(they get enabled by boot ROM by default, so this is more for
completness).
(cherry picked from commit 9e73c1b7d11611d51f0026d375731f0316dd26e8)
Use device-tree fixup to communicate the MTD partitions to the
kernel. U-Boot's mtdparts environment variable will be used as
partition source for the device-tree based partition table too.
(cherry picked from commit 6119b0f764eb8b68d6148d4c017cbd343408c2d8)
The config block support currently uses the ft_board_setup function
to patch the device tree with config block information. However, this
does not allow to patch the device tree with board specific information.
Rename the common setup function to ft_common_board_setup and use the
call it from the board files directly.
(cherry picked from commit 37fa41256bd756f3652e7479b976982092a4f9bc)
Commit 35c204d8a9d0 ("nand: reinstate lazy bad block scanning")
introduced lazy BBT scanning. However, some controller do parts
of the initialization (mxs_nand.c) during scan_bbt, hence for
those controllers the BBT must be scanned at initialization time.
In most situation the U-Boot environment gets read first, and
the U-Boot environment code checks for bad blocks first. Checking
for bad blocks will ask for scan_bbt before reading the first page,
hence in most situation the issue does not appear in practice.
However, when there is no environment configured, other code might
access NAND first which does not explicitly checks for bad blocks,
in those cases ECC reads will fail always.
Cc: Rostislav Lisovy <lisovy@gmail.com>
Add serial platform data to board file.
Enable driver model for PXA serial driver.
(cherry picked from commit 136179bec19f4bc84227cba138214ea392a723ea)
With em humble DM and Kconfig migraters U-Boot binary size keeps
increasing. Drop a bunch of less needed stuff to save another precious
20+ KB.
(cherry picked from commit fc127d184aea293ec415dd66e3282dba0b66c5f3)
Optional driver model handling integration.
(cherry picked from commit cbfa67a16b345cfb94840a41ee2fa0f728be296a)
Migrate the PXA serial driver to be configured via Kconfig.
(cherry picked from commit d804a5e1c369e59f23723cd21e1e422b7702a0ac)
remove now unused CONFIG_TRDX_PID_XXX
(cherry picked from commit 877ea607a8e07a9ed308e44a58e8e2b9028f01f2)
Now with the config block handling in place move the U-Boot environment
location before the config block at the end of 1st "boot sector" as
deployed during production using our downstream BSP.
(cherry picked from commit 74b19ad1c180fe32a01bccc35b0be1425132d927)
With our common code in place actually make use of it across all our
modules.
(cherry picked from commit b891d01038abcc8b25f12e1b91ff889b06eb07a2)
Add Toradex factory configuration block handling. The config block is a
data structure which gets stored to flash during production testing. The
structure holds such information as board resp. hardware revision,
product ID and serial number which is used as the NIC part of the
Ethernet MAC address as well. The config block will be read upon boot by
the show_board_info() function, displayed as part of the board
information and passed to Linux via device tree or ATAGs.
(cherry picked from commit a2777ecb9d11882dba696035defa35c70dd26733)
Deactivate CONFIG_DISPLAY_BOARDINFO in favour of
CONFIG_DISPLAY_BOARDINFO_LATE which also displays on the LCD.
(cherry picked from commit b05d6806cd6a95d46c22036a684a09501fdb2264)
Make show_board_info() a weak function which allows for custom board
specific implementations thereof.
(cherry picked from commit f7637cc01414b9c87b6b0f861f34d83c19bfaaaf)
Drop CONFIG_CUSTOM_BOARDINFO as it is not Kconfig compliant and anyway
not really used anywhere plus the upcoming weak show_board_info()
approach seems much superior.
This reverts commit a9ad18c9d5fe2554753b0f9a52adfd5ebce61147.
(cherry picked from commit 62e7a5c5f85c8dd37500571da9607ef68203af12)
Ian has not had any time for sunxi for some time now and I'm
in the same situation now, so I'm stepping down as sunxi
custodian and marking the sunxi support as Orphan.
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Compiling the 'bmp' command with DM and having one of the following macros
enabled:
CONFIG_BMP_16BPP, CONFIG_BMP_24BPP ONFIG_BMP_32BPP
generates this error:
drivers/video/video_bmp.c: In function ‘video_bmp_display’:
drivers/video/video_bmp.c:315:22: error: ‘lcd_line_length’ undeclared (first use in this function)
fb -= width * 2 + lcd_line_length;
This patch moves to using the correct variable instead and enables the
'bmp' command for DM again.
If mac-address is changed using "setenv ethaddr ...." command the new
mac-adress also must be written into the responsible ethernet driver.
This fixes the legacy ethernet handling.
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Fix the divider calculation logic to choose a value so that the
resulting baudrate is either equal to or closest possible baudrate less
than the requested value. While at that, cleanup ti_spi_set_speed().
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
