2005-01-12 | * Some Cleanup. | wdenk | |
* Patch by Richard Woodruff, 10 Jan 2005: Update support for OMAP2420 (ARM11) and H4 board: o clean up and add new types to H4 memory probe code. o fix to work with internal boot. o added PRCM config III operation. o fix marginal flash timings. o add revison ATAG usage. o enable voltage scaling at power chip. o fix compile error for i2c. * Fix network problem (error when receiving multiple ARP packets) | |||
2005-01-10 | Coding Style cleanup | wdenk | |
2005-01-09 | * Patch by Daniel Poirot, 10 Oct 2004: | wdenk | |
Add support for Wind River sbc405 board * Patch by Rainer Brestan, 12 Oct 2004: Make examples/Makefile more robust | |||
2005-01-09 | * Patch by Sam Song, 11 October 2004: | wdenk | |
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board - Adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz * Patch by Sam Song, 10 Oct 2004: Fix a parameter error in run_command() in main.c | |||
2005-01-09 | * Patches by Richard Woodruff, 01 Oct 2004: | wdenk | |
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs. | |||
2005-01-09 | * Patch by Leif Lindholm, 23 Sep 2004: | wdenk | |
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi | |||
2005-01-09 | Patches by David Snowdon, 07 Sep 2004: | wdenk | |
- add u-boot.hex target in the top level Makefile - add support for the UNSW/NICTA PLEB 2 board (pleb2) - use -mtune=xscale and -march=armv5 options for PXA | |||
2005-01-09 | Patch by Florian Schlote, 08 Sep 2004: | wdenk | |
Add support for SenTec-COBRA5272-board (Coldfire). | |||
2005-01-09 | * Patch by Gleb Natapov, 07 Sep 2004: | wdenk | |
mpc824x: set PCI latency timer to a sane value (is 0 after reset). * Patch by Kurt Stremerch, 03 Sep 2004: Add bitstream configuration option for fpga command (Xilinx only). | |||
2005-01-09 | * Patch by Kurt Stremerch, 03 Sep 2004: | wdenk | |
Add Xilinx Spartan2E family FPGA support * Patch by Jeff Angielski, 02 Sep 2004: Add Added support for H2 revision of the EP8260 board. Fixed formatting for some of the EP8260 related source files. | |||
2005-01-09 | * Patch by Jon Loeliger, 02 Sep 2004: | wdenk | |
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c | |||
2005-01-02 | Release U-Boot 1.1.2U-Boot-1_1_2 | wdenk | |
2004-12-31 | * Code cleanup, mostly for GCC-3.3.x | wdenk | |
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board. | |||
2004-12-20 | Fix problems with CMC_PU2 flash driver.LABEL_2004_12_20_1220 | wdenk | |
2004-12-19 | * Fix problems with CMC_PU2 flash driver.LABEL_2004_12_19_2240 | wdenk | |
* Adjust INKA 4x0 default settings | |||
2004-12-19 | Renamed UC100 => uc100LABEL_2004_12_19_1100 | wdenk | |
2004-12-19 | Cleanup: avoid trigraph warning in fs/ext2/ext2fs.c; rename UC100 -> uc100 | wdenk | |
2004-12-18 | Add support for UC100 boardLABEL_2004_12_18_2335 | wdenk | |
2004-12-17 | One more code cleanup. | stroese | |
2004-12-16 | Code cleanup. | wdenk | |
2004-12-16 | PCI405 board update | stroese | |
2004-12-16 | AR405 board update | stroese | |
2004-12-16 | Patch by Stefan Roese, 16 Dez 2004 | stroese | |
2004-12-16 | CONFIG_MX_CYCLIC description added | stroese | |
2004-12-16 | some new esd boards added | stroese | |
2004-12-16 | esd common update | stroese | |
2004-12-16 | VOH405 board update | stroese | |
2004-12-16 | PMC405 board update | stroese | |
2004-12-16 | PLU405 board update | stroese | |
2004-12-16 | OCRTC board update | stroese | |
2004-12-16 | HUB405 board update | stroese | |
2004-12-16 | DU405 board update | stroese | |
2004-12-16 | DP405 board update | stroese | |
2004-12-16 | CPCIISER4 board update | stroese | |
2004-12-16 | CPCI440 board update | stroese | |
2004-12-16 | CANBT board update | stroese | |
2004-12-16 | ASH405 board update | stroese | |
2004-12-16 | ADCIOP board update | stroese | |
2004-12-16 | CPCI405 board update | stroese | |
2004-12-16 | WUH405 board support added | stroese | |
2004-12-16 | VOM405 board support added | stroese | |
2004-12-16 | TASREG board support added | stroese | |
2004-12-16 | HH405 board support added | stroese | |
2004-12-16 | CPCI750 board support added | stroese | |
2004-12-16 | APC405 board support added | stroese | |
2004-12-16 | G2000 board support added | stroese | |
2004-12-16 | PMC405 board support added | stroese | |
2004-12-16 | CPU speed calculation updated (fixed a rounding problem) | stroese | |
