path: root/.travis.yml
2020-05-19Nokia RX-51: Add automated test for running RX-51 build in qemuPali Rohár
This patch contains test/nokia_rx51_test.sh script which automatically download and compile all needed tools in local temporary directory to generate a simple MTD images for booting Maemo kernel image by U-Boot from RAM, eMMC and OneNAND. MTD images are then run in virtual n900 machine provided by qemu-linaro project. This script does not need any special privileges, so it can be run as non-root nobody user. It can be used to check that U-Boot for Nokia N900 is not broken and can be successfully booted in emulator. Script is registered to .azure-pipelines.yml, .gitlab-ci.yml and .travis.yml so it would be automatically run on those CI services. Signed-off-by: Pali Rohár <pali@kernel.org>
2020-04-27travis: Switch over to using LLVM-10Tom Rini
At this point LLVM-7 is rather old. Switch over to LLVM-10 to enable some amount of CI coverage with newer compilers. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-27travis: Update ARC toolchain to 2019.09Tom Rini
Per Alexey Brodkin, this is the current toolchain we should use when building for ARC, update. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-24travis: Correct error checking when building boardsSimon Glass
At present if buildman reports an error, the travis build still succeeds. This is because the travis script does not stop when it sees errors; nor does it automatically return the exit code. Also the current error checking never triggers since 'ret' is not set. Fix this by setting 'ret' correctly. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2020-04-16travis: add packages for UEFI secure boot testAKASHI Takahiro
Pytest for UEFI secure boot will use several host commands. In particular, Test setup relies on efitools, whose version must be v1.5.2 or later. So fetch a new version of deb package directly. Please note it has a dependency on mtools, which must also be installed along wih efitools. In addition, the path, '/sbin', is added to PATH for use of sgdisk and mkfs. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis/gitlab/azure: Run cppcheck in parallelSimon Glass
This takes ages to run single-threaded. Adjust it to use all available processors. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-10travis/gitlab/azure: Drop repeated buildman call with test.pySimon Glass
It does not seem to be necessary to run buildman again to show errors, since any errors can be shown by the first invocation and there is only a single board being built. Update this to simplify the code, using the -e flag to make sure errors are shown. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis/gitlab/azure: Simplify the exit code for test.pySimon Glass
It seems unnecessary to read the exit code and then check it again. Drop this and just let the test.py provide the exit code directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis/gitlab/azure: Enable test_handoffSimon Glass
Ensure that this SPL test runs on gitlab. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis/gitlab/azure: Use -W to avoid warnings checkSimon Glass
We can use the -W flag to tell buildman to ignore warnings. Since we also have -E defined, compiler warnings are promoted to errors, so they will still cause a failure. But migration warnings of the form: ===================== WARNING ====================== This board does not use CONFIG_DM. CONFIG_DM will be compulsory starting with the v2020.01 release. Failure to update may result in board removal. See doc/driver-model/migration.rst for more info. will now be ignored. Signed-off-by: Simon Glass <sjg@chromium.org> Fixes: 329f5ef51d2 (travis.yml: run buildman with option -E) Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis/gitlab/azure: Use bash to avoid a_test_which_does_not_existSimon Glass
Bash allows for variables to expand only if non-empty: $ var=test $ echo ${var:+"$var"} test $ echo ${var:+"-k $var"} -k test $ var= $ echo ${var:+"-k $var"} Use this feature to avoid the workaround. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis/gitlab/azure: Drop the buildman -d flagSimon Glass
This has no effect since -S is not given also. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis/gitlab/azure: Drop BUILDMAN variable with test.pySimon Glass
This is not needed in the test.py part of the config, now since we use the same name as the pytests. Drop BUILDMAN, retaining it only for the 'build' parts of the config, i.e. where we build multiple boards and don't run any tests. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis/gitlab/azure: Use --board buildman flag with test.pySimon Glass
The current method of selecting the board to build with test.py is a bit error-prone, e.g. with "^sandbox$" it actually builds 5 boards (all of those in the sandbox architecture). Use the (newish) --board flag instead, to get the same result. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis: Split the building into two partsSimon Glass
Buildman is used in two ways: - to build a selection of boards (with no testing) - to build a single board (and run pytest) The gitlab and azure scrips do this in separate places, but travis does not. To aid the refactoring process and keep the following patches in sync across all three environments, split the code out in travis as well. Use the buildman -w option for the single board. It is easier to understand since it specifies the output directory directly. Also it avoids needing to look at the internal .bm-work directory. This initially creates some duplicate code, but by the end of the series we have two completely different build paths with different arguments. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis: Don't copy files into .bm-work/Simon Glass
At present if TEST_PY_BD is empty the script copies various files into a directory, to no purpose. This happens because UBOOT_TRAVIS_BUILD_DIR is set before TEST_PY_BD is tested. Move the 'if' to fix this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10travis: Switch to gcc 9.2.0Bin Meng
Use gcc 9.2.0 to do the build testing. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10azure/gitlab/travis: Add RISC-V SPL testingBin Meng
This adds QEMU RISC-V 32/64 SPL testing. Unlike QEMU RISC-V 32/64, we test SPL running in M-mode and U-Boot proper running in S-mode, with a 4-core SMP configuration. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-04-10azure/gitlab/travis: Add qemu-riscv32 testingBin Meng
This adds the qemu-riscv32_defconfig test configuration. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-04-10travis: Build GRUB image for RISC-V 32-bit and 64-bitBin Meng
This adds the GRUB image build for RISC-V 32-bit and 64-bit. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-04-10travis: Replace pre-built ARM/ARM64 GRUB images with the one built from sourceBin Meng
As of today travis uses the pre-built GRUB ARM/ARM64 images from opensuse. But azure/gitlab are using images built from GRUB 2.04 source. This updates travis to build GRUB ARM/ARM64 UEFI targets from source, to keep in sync with azure/gitlab. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-04-07Merge tag 'xilinx-for-v2020.07' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next Xilinx changes for v2020.07 common: - Align ENV_FAT_INTERFACE - Fix MAC address source print log - Improve based autodetection code xilinx: - Enable netconsole Microblaze: - Setup default ENV_OFFSET/ENV_SECT_SIZE Zynq: - Multiple DT updates/fixes - Use DEVICE_TREE environment variable for DTB selection - Switch to single zynq configuration - Enable NOR flash via DM - Minor SPL print removal - Enable i2c mux driver ZynqMP: - Print multiboot register - Enable cache commands in mini mtest - Multiple DT updates/fixes - Fix firmware probing when driver is not enabled - Specify 3rd backup RAM boot mode in SPL - Add SPL support for zcu102 v1.1 and zcu111 revA - Redesign debug uart enabling and psu_init delay - Enable full u-boot run from EL3 - Enable u-boot.itb generation without ATF with U-Boot in EL3 Versal: - Enable distro default - Enable others SPI flashes - Enable systems without DDR Drivers: - Gem: - Flush memory after freeing - Handle mdio bus separately - Watchdog: - Get rid of unused global data pointer - Enable window watchdog timer - Serial: - Change reinitialization logic in zynq serial driver Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-06ARM: zynq: Switch to single zynq configurationsMichal Simek
There are a lot of zynq configurations which can be merged together and use only one for all. The similar change has been done for ZynqMP by commit be1b6c32d940 ("arm64: zynqmp: Use zynqmp_virt platform") Build SPL with u-boot.img for zc706 like this. export DEVICE_TREE=zynq-zc706 && make xilinx_zynq_virt_defconfig && make -j8 u-boot.img is generic for all boards. Tested on Zybo, zc702, zc706, zc770-xm011-x16, cc108 and microzed. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-03-16Azure / GitLab / Travis: Add Kconfig unit tests to a jobTom Rini
The Kconfig language provides a unit test that can be run. As these require pytest to be installed and run very quickly, bundle them in to an existing CI job. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-03-09Azure/Travis: Re-sync jobs and clarify exclusionsTom Rini
We keep both of these jobs in sync as much as possible even when the primary motivation is to keep Travis from exceeding the build time limit there. With that in mind: - Use "rk" not "rockchip" to get all Rockchip SoC platforms in one job, rather than just all Rockchip vendor platforms. - The NXP LX216* SoCs have their own job, exclude them from the AArch64 generic job. - SoCFPGA SoCs have their own job, exclude them from the AArch64 generic job. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-02-25travis: build HTML docsHeinrich Schuchardt
Several patches delivered incorrect restructured text as documentation. We should be able to discover this in Travis CI. Provide a build step for 'make htmldocs'. Add required package graphviz. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-02-25travis: Add python3-sphinx to the package listTom Rini
In order to build htmldocs we need sphinx-build which comes from python3-sphinx. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-02-13travis/gitlab/azure: Ensure we use python3 alwaysTom Rini
When running our tests there are some cases where as part of the Python 2.7 to Python 3.6 migration we didn't force Python 3.6 to be used as everything wasn't yet migrated. Now that everything is, make sure to tell virtualenv to use python3. In the case of Travis this is best done by making the tools test happen after the main tests so that it will already have been run in all cases, TEST_PY_TOOLS is a subset of TEST_PY_BD. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-02-05sandbox: sdl: Move to use SDL2Simon Glass
Sandbox currently uses SDL1.2. SDL2 has been around for quite a while and is widely supported. It has a number of useful features. It seems appropriate to move sandbox over. Update the code to use SDL2 instead of SDL1.2. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-11travis: Switch to QEMU v4.2.0 globallyTom Rini
Given our tests in GitLab / Azure we can use QEMU v4.2.0 for all platforms now. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-23travis: rework NXP layerscape jobsHeiko Schocher
remove from NXP arm32 all layerscape boards and build them instead in already existing layerscape jobs (which now not only build aarch64 boards) Signed-off-by: Heiko Schocher <hs@denx.de>
2019-11-23travis: move orangepi to vendor jobHeiko Schocher
move orangepi builds into a new job, and exclude orangepi builds from sunxi and rockchip jobs. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-06travis: Fix the clang-7 testTom Rini
When using the OVERRIDE variable we need to pass -O to buildman as well to use the "override" option to buildman. Fixed: e9500f49ea35 ("travis: Use buildman for building with clang") Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-05travis: Rework how we write the ~/.buildman fileTom Rini
With python3 we're now tripping over a long-standing problem with how we add to the buildman file with some toolchains. We cannot have multiple toolchain-alias sections as that leads to a parse error. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-30gitlab/travis: Rework how and when we use virtualenv in order to use python3Tom Rini
As things stand today, we have tools that CI requires where "python" must be "python2". We need to use a virtualenv and pip in order to ensure that our pytest tests can be run. Rework things slightly so that: - On Travis-CI, we install python-pyelftools for the platforms that require pyelftools to be installed. - On GitLab-CI, we move to a newer base image that includes python3-pip and continue to use a virtualenv per job that needs it, for the correct set of packages. Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> [on sandbox] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-30test/py: Fix pytest4 deprecation warningsMarek Vasut
Fix the following spit from pytest: u-boot/test/py/conftest.py:438: RemovedInPytest4Warning: MarkInfo objects are deprecated as they contain merged marks which are hard to deal with correctly. Please use node.get_closest_marker(name) or node.iter_markers(name). Docs: https://docs.pytest.org/en/latest/mark.html#updating-code for board in mark.args: In both cases, the later suggestion is applicable. Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Igor Opaniuk <igor.opaniuk@gmail.com> [trini: Update for current file with a few more cases, un-pin pytest in CI] Tested-by: Simon Glass <sjg@chromium.org> [on sandbox] Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-29.travis.yml: Remove the unneeded '&' for ls20xx buildmanBin Meng
2019-10-16travis: Split and rename xilinx ARM in to two jobsTom Rini
Split the ARMv7 and AArch64 platforms into separate jobs, to avoid them taking too long to build overall. Also rename them from "Xilinx" to "Zynq*" to reflect slightly better what is being built and to pull in a few more board matches. Reviewed-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-16travis: Split sun8i in to two jobsTom Rini
Split the 32bit and 64bit platforms into separate jobs, to avoid them taking too long to build overall. Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-16travis: Split i.MX jobs a bit moreTom Rini
- Split "tqc" and "technexion" out into their own jobs and exclude them from the catch-all jobs - Clarify the job labels a little more. Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefano Babic <sbabic@denx.de>
2019-10-16arm: remove the H2200 boardHeinrich Schuchardt
U-Boot cannot be built for h2200_defconfig with CONFIG_DM=y. The maintainer Lukasz Dalek suggested to remove the board. https://lists.denx.de/pipermail/u-boot/2019-August/380685.html Cc: Lukasz Dalek <luk0104@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [trini: As this is the last non-toradex PXA board, update travis too] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-13travis: Exclude MIPS from the bcm jobTom Rini
We don't need to pull in anything from the MIPS job so exclude that from the new bcm job and make it clear it's building only ARM. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-09travis: Move keystone 3 (k3) boards into the k2 jobTom Rini
Build the keystone 3 platforms with the keystone 2 platforms, in order to get back more room in the "catch-all" build jobs. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-09travis: Split bcm SoCs into their own build jobTom Rini
As both "catch-all" ARM jobs are nearing their time limit, move all of the bcm SoC boards into a single job. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-08travis.yml: Switch to bionic for the host distributionTom Rini
To match what we're doing in GitLab, move to 'bionic' for these builds as well. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-09-24ci: add envtools supportPierre-Jean Texier
This commit add envtools suppport to CI to verify if there is no build issues. Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-09-19travis.yml: change Ubuntu version to xenialRamon Fried
trusty is getting old, move to xenial (16.04) to get updated gcc and other tools. Signed-off-by: Ramon Fried <rfried.dev@gmail.com>
2019-08-02travis.yml: run Python tests on qemu-riscv64_defconfigHeinrich Schuchardt
Run the Python tests on the RISC-V architecture too. https://github.com/swarren/uboot-test-hooks has already been updated. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-07-24binman: Convert to use ArgumentParserSimon Glass
This class is the new way to handle arguments in Python. Convert binman over to use it. At the same time, introduce commands so that we can separate out the different parts of binman functionality. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-24binman: Add a utility library for coreboot CBFSSimon Glass
Coreboot uses a simple flash-based filesystem called Coreboot Filesystem (CBFS) to organise files used during boot. This allows files to be named and their position in the flash to be set. It has special features for dealing with x86 devices which typically memory-map their SPI flash to the top of 32-bit address space and need a 'boot block' ending there. Create a library to help create and read CBFS files. This includes a writer class, a reader class and associated other helpers. Only a subset of features are currently supported. Signed-off-by: Simon Glass <sjg@chromium.org>
