path: root/.travis.yml
2019-01-24travis: Wire Xilinx Versal Virt platformMichal Simek
Test Xilinx Versal Virt platform running on the v3.1.0 Qemu. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-22.travis.yml: Support nds32 prebuilt toolchainRick Chen
Download nds32 prebuild toolchain from github which is base on gcc 8.0.1 version for regression. Signed-off-by: Rick Chen <rick@andestech.com> Cc: Greentime Hu <greentime@andestech.com>
2019-01-18travis: Switch QEMU to 3.1.0 versionMichal Simek
Vexpress ca15_tc2 is failing with 3.1.0 because of QEMU issue. When this patch is applied https://patchwork.kernel.org/patch/10754401/ Vexpress can be also turn to newer QEMU version. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-18travis: Setup QEMU_VERSION as variableMichal Simek
This change enables setting up specific Qemu version or sha1 for new targets which are added after (current) v3.0.0 version. This changes is preparation step for adding new Xilinx Versal Virt platform which was merge after v3.0.0. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-18travis: Break up the NXP Layerscape jobs moreTom Rini
The single job for all Layerscape 10xx platforms is close to, and sometimes exceeds the time limit for a single job configuration. Break this down into jobs for LS101x, LS104x and LS108x instead. While in here, in the name portion of these jobs, refer to them as NXP for ARM and not Freescale as they've been NXP for quite some time. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-14travis: Use buildman for building with clangSimon Glass
Now that buildman supports clang, use it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-15tools: add a generic config for native tools buildingOtavio Salvador
The motivation for this is to allow distributions to distribute all possible tools in a generic way, avoiding the need of specific tools building for each machine. Especially on OpenEmbedded / Yocto Project ecosystem, it is very common each BSP to end providing their specific tools when they need to generate images for some SoC (e.g MX23 / MX28 in meta-freescale case). Using this, we can package the tools doing: $: make tools-only_defconfig $: make tools-only Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> [trini: Add MAINTAINERS entry for myself, add to .travis.yml, make U-Boot itself buildable to not trip up other frameworks] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-10travis: Add check for configs without MAINTAINERS entriesTom Rini
The genboardscfg.py script will emit a WARNING message if we have new defconfig files that are not listed in a MAINTAINERS file. Make new cases of this a failure we catch in Travis-CI. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-07travis: Bump ARC tools to arc-2018.09Alexey Brodkin
Build tested in Travis, see: https://travis-ci.org/abrodkin/u-boot/jobs/462808237 Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-11-15travis: Ensure we use pytest 2.8.7Tom Rini
The latest version of pytest (4.0.0) makes some of the code we have in test/py/conftest.py a fatal error that needs to be migrated. Unfortunately this in turn requires changes that don't exist in older versions of pytest such as 2.8.7 that ships with Ubuntu 16.04. Force travis to use this older version of pytest. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-10-23travis: Rework Freescale ARM jobs a bitTom Rini
- Split the AArch64 LS10xx and LS20xx builds into their own jobs, and then exclude only ls1/ls2 from the catch-all. This moves the S32V234 job (and future i.MX8*) to the catch-all. - Split spear out from arm926ejs and exclude freescale, not mx from that job. The older Freescale i.MX boards are caught by the catch-all job for Freescale but now we build the non-Freescale older i.MX platforms. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-10-22travis: Add qemu-x86_64 target for test.py testingBin Meng
Add qemu-x86_64 to the list of targets we use for test.py runs. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-22travis: Update to use QEMU 3.0.0 for testingBin Meng
This updates travis-ci to use QEMU 3.0.0 for testing. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-22travis: Generate grub_x64.efi for qemu-x86_64Bin Meng
grub_x86.efi is for 32-bit QEMU. Generate the 64-bit one. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-19travis: Add sandbox/clang-7 supportTom Rini
To make testing with clang support easier, add sandbox/clang-7 combination to our testing matrix. To facilitate this, switch to using the "sources" method that the travis.yml file supports to list additional repositories and add the official one for llvm-7. Due to buildman not supporting using clang at this time add logic to manually build a single sandbox configuration in the expected output directory so that we can still invoke all of our tests. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-19travis: Switch to i386 version toolchain for x86Bin Meng
Currently this uses x86_64 version toolchain for x86 build in travis-ci. Change it to i386 version to avoid updating the buildman toolchain path every time when the toolchain version number is changed, eg: from 7.3.0 to 8.1.0. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-19travis: Remove or32 toolchain infoBin Meng
or32 is not supported by U-Boot anymore. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-08binman: Run tests concurrentlySimon Glass
At present the tests run one after the other using a single CPU. This is not very efficient. Bring in the concurrencytest module and run the tests concurrently, using one process for each CPU by default. A -P option allows this to be overridden, which is necessary for code-coverage to function correctly. This requires fixing a few tests which are currently not fully independent. At some point we might consider doing this across all pytests in U-Boot. There is a pytest version that supports specifying the number of processes to use, but it did not work for me. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-29binman: Support compressed entriesSimon Glass
Add support for compressing blob entries. This can help reduce image sizes for many types of data. It requires that the firmware be able to decompress the data at run-time. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-10.travis.yml: Fix typo in sun7i job descriptionTuomas Tynkkynen
'builman' -> 'buildman' Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2018-09-05travis: Use kernel.org pre-built toolchain for riscvBin Meng
This updates travis configuration to use kernel.org pre-built toolchain for riscv. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-08-10travis: give every job a nameStephen Warren
Travis CI now supports giving jobs an explicit name. Do this for all jobs. This allows more direct control over jobs names than the previous automatic or implicit naming based on the environment variables or script text. Signed-off-by: Stephen Warren <swarren@nvidia.com> [trini: Update names for jobs added/changed since posting] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-31.travis.yml: Exclude openrd platformsTom Rini
The openrd platforms are currently orphaned, and are constantly on-edge or overflowing their binary limit. Exclude them from travis for now. Cc: Vagrant Cascadian <vagrant@debian.org> Cc: Chris Packham <judge.packham@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-31.travis.yml: Exclude kirkwood machines from the arm926ejs jobTom Rini
We have a specific job for kirkwood platforms so exclude them from this job. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-02board/aries: RemoveTom Rini
The various Aries Embedded boards have been orphaned for a year and no one has come forward to take care of them. Remove. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-30travis.yml: Support RISC-V 64-bitRick Chen
Fix riscv: ax25-ae350 build fail problem https://travis-ci.org/trini/u-boot/jobs/385147373 ... Building current source for 1 boards (1 thread, 2 jobs per thread) riscv: + ax25-ae350 +arch/riscv/cpu/ax25/start.S: Assembler messages: +arch/riscv/cpu/ax25/start.S:48: Error: unrecognized opcode `sd a2,0(t0)' +arch/riscv/cpu/ax25/start.S:112: Error: unrecognized opcode `ld t5,0(t0)' ... After apply the commit configs: ax25-ae350: Set 64-bit as default configuration Toolchain shall be also setuped with 64-bit in .travis.yml. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Reviewed-by: Chih-Mao Chen <cmchen@andestech.com> Cc: Greentime Hu <green.hu@gmail.com>
2018-05-22.travis.yml: Further optimizationsTom Rini
- Xilinx aarch64 is caught in the general xilinx arm job, exclude from the general aarch64 job. - Give the generic aarch64 job a better name - Re-sort the PowerPC jobs so that we can complete them a bit quicker. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-22buildman: support newer gcc versions from kernel.orgDaniel Schwierzeck
Add support for gcc versions 7.3.0, 6.4.0 and 4.9.4. Also use a regex for matching the tarball names. Some gcc versions use '-ARCH-' instead of '_ARCH-'. As part of this, we switch TravisCI to also using these toolchains for all platforms. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-02ARC: Bump ARC tools used in TravisCI to the most recent release arc-2017.09Alexey Brodkin
2018-03-14.travis.yml: Add lzopTom Rini
We need lzop now in order to make some FIT images that use LZO compression on the contents. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13.travis.yml: test xtensa xtfpga board in QEMUMax Filippov
This allows running tests on emulated KC705 board with DC233C xtensa core. It expects to find conf.xtfpga_qemu in the uboot-test-hooks. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2018-02-13.travis.yml: download xtensa prebuilt toolchainMax Filippov
xtensa toolchains are core-specific, so give full toolchain name and download corresponding prebuilt toolchain from the github release. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2018-02-04travis.yml: run buildman with option -EDaniel Schwierzeck
This forces all compiler warnings to be treated as errors. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-02-04travis.yml: fix 'set +e' in build scriptDaniel Schwierzeck
The build script should not manipulate shell flags (especially '-e'). A non-zero exit value can also be catched with 'cmd || ret=$?'. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-22Revert "travis-ci: Add qemu-x86_64 target"Tom Rini
This reverts commit 998ae28799c79c6bc796aea182ae6acf13d18284. This continues to fail in travis itself, so remove for now. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22travis-ci: Add qemu-x86_64 targetTom Rini
Add qemu-x86_64 to the list of targets we use for test.py runs. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-19Travis-CI: Add job for running test.py on qemu_arm64Tuomas Tynkkynen
The corresponding changes in the uboot-test-hooks repo are: https://github.com/swarren/uboot-test-hooks/pull/15 Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-19Travis-CI: Download ARM64 version of GRUB as wellTuomas Tynkkynen
For preparation of adding AArch64 test.py jobs. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-15travis.yml: Run tests for toolsSimon Glass
Run tests for the Python tools used by U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-12travis.yml: Support RISC-VRick Chen
Enable travis-ci support with a link having built. Signed-off-by: Chih-Mao Chen <cmchen@andestech.com> Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
2018-01-10Travis-CI: Split 't208xrdb t4qds t102*'-job into separate jobsPhilipp Tomsich
The 't208xrdb t4qds t102*' job is close to the time limit and sometimes fails, so this splits it into 3 separate jobs. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-10-07Travis-CI: Fix microblaze and xilinx jobsTom Rini
Given how we handle the ARM toolchain we can't easily combine these two jobs, so don't. Give xilinx/ARM a separate build. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06Travis-CI: Split out more vendors from the catch-all ARM jobTom Rini
- Move SoCFPGA and K2 boards to their own job - Expand the microblaze job to cover ARM boards from Xilinx as well. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06Travis-CI: Move Boundary and Engicam devices to their own jobsTom Rini
The i.MX6 job can still be close to the time limit, move a few more devices out. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06Travis-CI: Move Toradex into its own jobTom Rini
A few of the big jobs are getting close to the time limit again, split a few more things out. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06travis.yml: Add job for running test.py in qemu_armTuomas Tynkkynen
Note that this commit requires https://github.com/swarren/uboot-test-hooks/pull/14 to go in first. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-24dtc: Switch to building and using our own dtc unless providedTom Rini
This makes us act like the Linux Kernel does and allow for dtc to be provided externally but otherwise we use the version of dtc that is included in the sources. This in turn means that we can drop the checkdtc logic. We select DTC in the cases where we will need the dtc tool provided. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-22Travis-CI: Checkout only v1.4.3 of dtcTom Rini
Our minimum DTC version is 1.4.3, so check that out. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-15Travis-CI: Switch back to using the top of tree dtcTom Rini
In a0f3e3df4adc we switched to using the Ubuntu-provided dtc as travis was having a problem with the number of warnings that were generated by the newer dtc. This is no longer a concern as we now have the same logic as Linux to enable/disable additional more stringent warnings. Go back to building dtc from source. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested on travis-ci: Tested-by: Simon Glass <sjg@chromium.org>
