path: root/.travis.yml
2018-05-22.travis.yml: Further optimizationsTom Rini
- Xilinx aarch64 is caught in the general xilinx arm job, exclude from the general aarch64 job. - Give the generic aarch64 job a better name - Re-sort the PowerPC jobs so that we can complete them a bit quicker. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-22buildman: support newer gcc versions from kernel.orgDaniel Schwierzeck
Add support for gcc versions 7.3.0, 6.4.0 and 4.9.4. Also use a regex for matching the tarball names. Some gcc versions use '-ARCH-' instead of '_ARCH-'. As part of this, we switch TravisCI to also using these toolchains for all platforms. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-02ARC: Bump ARC tools used in TravisCI to the most recent release arc-2017.09Alexey Brodkin
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-03-14.travis.yml: Add lzopTom Rini
We need lzop now in order to make some FIT images that use LZO compression on the contents. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13.travis.yml: test xtensa xtfpga board in QEMUMax Filippov
This allows running tests on emulated KC705 board with DC233C xtensa core. It expects to find conf.xtfpga_qemu in the uboot-test-hooks. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2018-02-13.travis.yml: download xtensa prebuilt toolchainMax Filippov
xtensa toolchains are core-specific, so give full toolchain name and download corresponding prebuilt toolchain from the github release. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2018-02-04travis.yml: run buildman with option -EDaniel Schwierzeck
This forces all compiler warnings to be treated as errors. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-02-04travis.yml: fix 'set +e' in build scriptDaniel Schwierzeck
The build script should not manipulate shell flags (especially '-e'). A non-zero exit value can also be catched with 'cmd || ret=$?'. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-22Revert "travis-ci: Add qemu-x86_64 target"Tom Rini
This reverts commit 998ae28799c79c6bc796aea182ae6acf13d18284. This continues to fail in travis itself, so remove for now. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22travis-ci: Add qemu-x86_64 targetTom Rini
Add qemu-x86_64 to the list of targets we use for test.py runs. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-19Travis-CI: Add job for running test.py on qemu_arm64Tuomas Tynkkynen
The corresponding changes in the uboot-test-hooks repo are: https://github.com/swarren/uboot-test-hooks/pull/15 Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-19Travis-CI: Download ARM64 version of GRUB as wellTuomas Tynkkynen
For preparation of adding AArch64 test.py jobs. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-15travis.yml: Run tests for toolsSimon Glass
Run tests for the Python tools used by U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-12travis.yml: Support RISC-VRick Chen
Enable travis-ci support with a link having built. Signed-off-by: Chih-Mao Chen <cmchen@andestech.com> Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
2018-01-10Travis-CI: Split 't208xrdb t4qds t102*'-job into separate jobsPhilipp Tomsich
The 't208xrdb t4qds t102*' job is close to the time limit and sometimes fails, so this splits it into 3 separate jobs. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-10-07Travis-CI: Fix microblaze and xilinx jobsTom Rini
Given how we handle the ARM toolchain we can't easily combine these two jobs, so don't. Give xilinx/ARM a separate build. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06Travis-CI: Split out more vendors from the catch-all ARM jobTom Rini
- Move SoCFPGA and K2 boards to their own job - Expand the microblaze job to cover ARM boards from Xilinx as well. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06Travis-CI: Move Boundary and Engicam devices to their own jobsTom Rini
The i.MX6 job can still be close to the time limit, move a few more devices out. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06Travis-CI: Move Toradex into its own jobTom Rini
A few of the big jobs are getting close to the time limit again, split a few more things out. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06travis.yml: Add job for running test.py in qemu_armTuomas Tynkkynen
Note that this commit requires https://github.com/swarren/uboot-test-hooks/pull/14 to go in first. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-24dtc: Switch to building and using our own dtc unless providedTom Rini
This makes us act like the Linux Kernel does and allow for dtc to be provided externally but otherwise we use the version of dtc that is included in the sources. This in turn means that we can drop the checkdtc logic. We select DTC in the cases where we will need the dtc tool provided. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-22Travis-CI: Checkout only v1.4.3 of dtcTom Rini
Our minimum DTC version is 1.4.3, so check that out. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-15Travis-CI: Switch back to using the top of tree dtcTom Rini
In a0f3e3df4adc we switched to using the Ubuntu-provided dtc as travis was having a problem with the number of warnings that were generated by the newer dtc. This is no longer a concern as we now have the same logic as Linux to enable/disable additional more stringent warnings. Go back to building dtc from source. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested on travis-ci: Tested-by: Simon Glass <sjg@chromium.org>
2017-09-12Travis-CI: Update PATHTom Rini
We now can no longer re-use the provided path and need to give the full PATH we want used now. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11travis-ci: Emulate 'make tests'Tom Rini
The 'tests' target will run sandbox, sandbox_spl and sandbox_flattree in test.py and in the case of sandbox_spl ensure that we just run the specific tests for that build. Update our matrix to perform similar test.py runs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-08powerpc, 8xx: Add support for MCR3000 board from CSSIChristophe Leroy
CS Systemes d'Information (CSSI) manufactures two boards, named MCR3000 and CMPC885 which are respectively based on MPC866 and MPC885 processors. This patch adds support for the first board. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-06-29.travis.yml: All DENX boards are now under AriesTom Rini
DENX hardware is now under Aries Embedded, update the job. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8260: remove support for mpc8260Heiko Schocher
There was for long time no activity in the 8260 area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8260, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-04-27travisci: Add support for ARCAlexey Brodkin
Finally adding support for ARC boards in TravisCI. To build for ARC boards we need to install Synopsys prebuilt toolchain which we do here. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-18travis-ci: Switch over to Linaro gcc-6.3.1 toolchains for ARMTom Rini
Linaro provides a number of pre-built GCC toolchains for both 32 and 64bit ARM. Switch to their 2017.02 release of gcc-6.3.1 for both. Cc: Koen Kooi <koen.kooi@linaro.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-10travis-ci: OrangePi PC2 only links with gcc-5.x or laterTom Rini
We disable this specific board as it does not link with the gcc-4.9.x that we use today in travis-ci. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-20travis-ci: Re-work i.MX6 jobs, clarify Freescale and AArch64Tom Rini
- The catch-all i.MX6 job has been exceeding the time limit again so split this up further. We now have an i.MX6 job and an everything-else job. - The logic we use to say "Freescale and AArch64" can be more clearly expressed with '&' rather than excluding various other things, so clear that up. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-26travis-ci: Temporarily disable using a newer device tree compilerTom Rini
For a long while dtc has warned about various constructs. This is now leading to log file size being exceeded in travis, and as the majority of these errors need to be fixed in the kernel, switch to using the stock device-tree-compiler package. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-24travis-ci: Add swig and libpython-dev to the package listTom Rini
As part of 1905c8fc711a we introduced failures depending on if swig and libpython-dev are installed or not. To provide coverage for this are of code in the future ensure we have these packages installed. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-01-21travis-ci: Split p1_p2_rdb_pc and p1010rdb into separate jobsTom Rini
On occasion the job that does these two build types will hit the time limit so split this in two. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-14travis-ci: Add zynq_zc702 target supportMichal Simek
It depends on qemu v2.8.0-rc3 which includes device loader property. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-12-09travis-ci: Switch to building QEMUTom Rini
First, there are a number of features in newer QEMU that will allow us to test a wider range of platforms, so we want to use at least v2.8.0. Second, making use of a PPA for QEMU fails from time to time. So we change to checking out and building a copy of QEMU when we know that we are going to use test.py and need QEMU to be installed. This adds around 4 minutes per test.py job that we run. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-09Revert "Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze"Tom Rini
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
2016-12-08travis-ci: Add zynq_zc702 target supportMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Use embded option because of qemu Use my repo till Stephen merge it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-12-05travis-ci: Build mvebu boards (arm & aarch64) in separate jobStefan Roese
Its easier to watch the output of the build process when the platforms specific boards are grouped in a separate job. This patch adds a job for all mvebu boards (arm and aarch64). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-30travis.yml: Split Freescale ARM job up moreTom Rini
In order to avoid running into the time limit, split the 32bit and 64bit Freescale boards into separate jobs. We could either pass "freescale & armv8" to buildman or exclude all of the 32bit CPUs. While the former is shorter I fear the amount of possible escaping required would make things less readable. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-29travis.yml: Add samsung and rockchip buildsTom Rini
The catch-all job is failing due to time limits depending on factors out of our control, so move Samsung and Rockchip boards into their own jobs and then exclude them from the general ARM and AArch64 jobs. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-27travis: Add efi_loader grub2 testAlexander Graf
We have all the building blocks now to run arbitrary efi applications in travis. The most important one out there is grub2, so let's add a simple test to verify that grub2 still comes up. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-27Travis: Remove sleep test from integratorcp_cm926ejs-qemu testAlexander Graf
Most of the time when running the sleep test in Travis for the integratorcp_cm926ejs target I get errors like this: E assert 2.999901056289673 >= 3 The deviation is tiny, but fails the overall build result. Since the sleep test is not terribly important as gate keeper for travis tests, let's just exclude it for this board. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-26travis: Add python path for environmentsAlexander Graf
When running in travis-ci, we want to pass environment configuration to the tests. These reside in a path available through PYTHONPATH, so let's define that one to point to the unit test repo. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
