path: root/.travis.yml
2016-10-24travis-ci: Add test.py for various qemu platformsTom Rini
- Add a PPA for a more recent qemu (required for PowerPC to work) - Add tests to run test.py for various QEMU platforms. This relies on swarren's uboot-test-hooks repository to provide the abstractions. Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-24travis-ci: Drop 'TEST_CMD'Tom Rini
We don't need to use TEST_CMD in order to run tests. We need a BUILDMAN and TOOLCHAIN variable to avoid having to duplicate logic or write some wrapper function. But this makes the tests harder as we add more complex examples. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-10-24travis-ci: Add more architecturesTom Rini
We can now build for microblaze, sh4 and xtensa. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-10-24travis-ci: Update toolchain and buildman usageTom Rini
- Drop the 'cache' line, travis-ci says to not cache apt packages (and does not). - Get the Ubuntu provided toolchain for ARM and PowerPC. - Add more toolchain options that buildman can fetch. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-10-24travis-ci: Do not make buildman warnings fatalTom Rini
We currently will always see a number of warnings due to device tree issues. These (and other warnings) should not make the build be marked as failure so catch exit status 129 specifically and return 0 in that case. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-10-24travis-ci: Use a git URI for dtc.gitTom Rini
Currently we fail to fetch the dtc.git tree due to an SSL issue within the travis-ci environment. The easiest fix here is to switch to a git URI. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-10-24travis-ci: Switch to Ubuntu 14.04 'Trusty Tahr'Tom Rini
In order to make other various improvements, update to the latest environment travis-ci supports. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-02-15Enable test/py for sandbox in Travis CIStephen Warren
This provides runtime test coverage in Travis, in addition to the existing build coverage. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Roger Meier <r.meier@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-08.travis.yml: explicitly request sudoStephen Warren
Without this, builds default to using new Travis CI infra-structure which does no allow sudo. The builds need sudo in order to install the ELDK compilers. Consequently, almost all builds fail without this. I suspect that existing Travis CI users have not noticed this because their accounts or builds have been grand-fathered into backwards- compatible default settings, whereas I just set up a new build from scratch and received new default settings. Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Andreas Färber <afaerber@suse.de> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Heiko Schocher <hs@denx.de>
2016-02-01.travis.yml: rework according to new travis-ci infraRoger Meier
- install using addons.apt - remove MAKEALL - split mpc85xx boards - remove TEST_CONFIG_CMD, just info - fetch mips toolchain via buildman - remove --list-error-boards param - conditional script - use TOOLCHAIN instead of INSTALL_TOOLCHAIN - add aarch64 - enable notifications via email Signed-off-by: Roger Meier <r.meier@siemens.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Andreas Färber <afaerber@suse.de> Tested-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-17travis.yml: add more targets to build on travisHeiko Schocher
- add more targets for building with buildman: - avr32 - m68k and while at it, sort the list alphabetical Reviewed-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Heiko Schocher <hs@denx.de>
2015-03-05travis.yml: some adaptionsHeiko Schocher
- adapt to build with eldk-5.4 - add more targets for building with buildman: - freescale -x arm,m68k,aarch64 - arm1136 - arm1176 - arm720t - arm920t - davinci - kirkwood Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Roger Meier <r.meier@siemens.com>
2015-02-16.travis.yml: remove 824x buildsHeiko Schocher
remove powerpc 824x build, as this architecture not longer exists. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-01-14.travis.yml: build u-boot on travis-ciMeier, Roger
Goal: - building all variants of U-Boot with multiple configurations - code quality checks and metrics - https://travis-ci.org/u-boot/u-boot/builds
