There is one issue with Heinrich xypron.glpk@gmx.de <xypron.glpk@gmx.de>
record which should be specifically grouped with his name.
Based on looking at top contributors it was seen that top statistics from
top contributors don't include all contributions from different email
addresses. That's why I checked all top contributors are checked it.
git shortlog -n $START..$END -e -s
The patch is adding mapping for Bin Meng, Marek Vasut, Masahiro Yamada,
Michal Simek, Tom Rini, Wolfgang Denk.
And also use mapping for Stefan Roese and Wolfgang Denk to be properly
counted.
Acked-by: Bin Meng <bmeng.cn@gmail.com>
Both have left Western Digital.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Add a mailmap entry for me.
https://source.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2022.01-rc1
zynq:
- Enable capsule update for qspi and mmc
- Update zed DT qspi compatible string
zynqmp:
- Add missing modeboot for EMMC
- Add missing nand DT properties
- List all eeproms for SC on vck190
- Add vck190 SC psu_init
clk:
- Handle only GATE type clock for Versal
watchdog:
- Update versal driver to handle system reset
The @suse.de address doesn't exist anymore. Update it to something not
dependent on my workplace.
Signed-off-by: Nicolas Saenz Julienne <nsaenz@kernel.org>
Signed-off-by: Matthias Brugger <mbrugger@suse.com>
Old address doesn't exist anymore. Map it to new one.
Signed-off-by: Jernej Skrabec <jernej.skrabec@gmail.com>
Acked-by: Andre Przywara <andre.przywara@arm.com>
My address at Toradex doesn't exist anymore, map this address
to my personal email.
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Add our new email address dedicated for upstream activities.
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
Freescale mail addresses are not valid anymore.
Reported-by: Fabio Estevam <festevam@gmail.com>
My address at Linaro doesn't exist anymore, so people
keep getting mail delivery error responses. Map this address
to the actual one.
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Boris' email address has changed. Copy two entries from the Linux .mailmap
file.
Boris confirmed the new email address:
https://lists.denx.de/pipermail/u-boot/2019-December/393774.html
Cc: Boris Brezillon <bbrezillon@kernel.org>
Update my email address from gmail to my domain.
Signed-off-by: Ricardo Ribalda Delgado <ricardo@ribalda.com>
Looking at the contents of file .mailmap it seems that some editors assumed
that translation is done by entering multiple lines into the file and the
last one replaces the others. This is not how it works. The translation
occurs according to entries in single lines as described in the
git-check-mailmap man-page.
Add a description of the file format.
Add an entry for Alexander Graf as his old email address is not valid
anymore.
Update my e-mail address from samsung.com to denx.de
Signed-off-by: Lukasz Majewski <lukma@denx.de>
The patch
"tools/mkimage: Fix DTC run command to handle file names with space"
(sha1: a6e9810495bc929b6beafb88f557cdaadf87fc83) contains comma in name
which is confusing patman. Fix it by defining Mirza's email in mailmap.
MIPS is no longer a part of Imagination Technologies, and as such my
@imgtec.com email address will soon cease to function. This patch
updates occurrances of it with my new @mips.com email address, and adds
an entry in .mailmap such that git (& tools such as get_maintainer.pl
when examining history) will use the new address.
Signed-off-by: Paul Burton <paul.burton@mips.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: u-boot@lists.denx.de
I'll switch my mails to my own server, so drop all gmail references.
Commit df48b23428e9 (".mailmap: Add all the mail alias for Ricardo
Ribalda") assigned two different proper names for the email address
"ricardo.ribalda@uam.es". This is a completely wrong usage as the
mailmap feature exists for coalescing together commits by the same
person whose name is sometimes spelled differently.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Reviewed-by: Michal Simek <michal.simek@xilinx.com>
Update my email address to the NXP account.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Change from yorksun@freescale.com to york.sun@nxp.com.
Signed-off-by: York Sun <york.sun@nxp.com>
Used quite different name's and e-mail address, all of
them mapped to standard name and e-mail address.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
Add more entries to .mailmap for the canonical names with
50 commits or more.
This commit was generated by the following command:
scripts/mailmapper > tmp; mv tmp .mailmap
This is the first version of .mailmap created by hand.
Please see "man git-shortlog" for what this commit is trying to do.
Without this file, for example, "git shortlog -n -s" shows as follows:
2693 Wolfgang Denk <------
1002 Stefan Roese <------
811 wdenk <------
808 Mike Frysinger
806 Simon Glass
[snip]
177 Matthias Fuchs
154 stroese <------
153 Timur Tabi
And then, with this file, it shows as follows:
3504 Wolfgang Denk <------
1156 Stefan Roese <------
808 Mike Frysinger
806 Simon Glass
Cc: Stefan Roese <sr@denx.de>
