This lets patman run all of its tests, rather than skipping quite a few.
Run SPL unit tests in all test environments.
Add SH4 R2Dplus machine configured to test various U-Boot PCI ethernet
options -- RTL8139, EEPRO100, AMD PCnet, DEC Tulip.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
- New base snapshot
- Fix for high UID/GID numbers on a toolchain
- New bionic snapshot
- Updated sbsigntool
- Include SH4 in qemu
At present we use --test to indicate that tests should be run. It is
better to use a subcommand for list, like binman. Change it and adjust
the existing code to fit under a 'send' subcommand, the default.
Give this subcommand the same default arguments as the others.
- Fix SiFive HiFive Unleashed board booting failure problem.
- Enable SiFive fu540 PWM driver.
- Support SiFive fu540: SPI boot.
- Update OpenSBI used for RISC-V CI testing.
- Revert "riscv: Allow use of reset drivers".
- Revert "Revert "riscv: sifive: fu540: Add gpio-restart support"".
- sysreset: syscon:
- Don't assume default value for offset and mask property.
- Support value property.
- qemu: Add syscon reboot and poweroff support.
- Fix SIFIVE debug serial dependency.
- Fix linking error when building u-boot-spl with no SMP support.
- AE350 use fdtdec_get_addr_size_auto_noparent to parse smc reg.
- Make memory node available to SPL in hifive-unleashed-a00-u-boot.dtsi
- SiFive fu540 avoid using hardcoded ram base and size.
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing
changes made to 56d37f1c564107e27d873181d838571b7d7860e7.
Unfortunately this is causing CI failures:
https://travis-ci.org/github/trini/u-boot/jobs/711313649
Change to use OpenSBI release v0.8 generic platform images for QEMU
RISC-V CI testing for azure, gitlab and travis-ci.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
The GRUB binaries are expected in $UBOOT_TRAVIS_BUILD_DIR.
Call pytest3 with argument -ra to display the reason why Python tests are
skipped.
The -r flag displays a test summary info for each test. -ra eliminates
this info for passed tests.
Pros an cons were discussed in:
https://lists.denx.de/pipermail/u-boot/2020-June/417090.html
Add Qemu tests for the MIPS Malta machine as a replacement for
the deprecated generic MIPS machine.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
- Add guestfstools, efitools
- Latest Ubuntu/bionic snapshot
This patch contains test/nokia_rx51_test.sh script which automatically
download and compile all needed tools in local temporary directory to
generate a simple MTD images for booting Maemo kernel image by U-Boot from
RAM, eMMC and OneNAND. MTD images are then run in virtual n900 machine
provided by qemu-linaro project.
This script does not need any special privileges, so it can be run as
non-root nobody user.
It can be used to check that U-Boot for Nokia N900 is not broken and can be
successfully booted in emulator.
Script is registered to .azure-pipelines.yml, .gitlab-ci.yml and
.travis.yml so it would be automatically run on those CI services.
Signed-off-by: Pali Rohár <pali@kernel.org>
At this point LLVM-7 is rather old. Switch over to LLVM-10 to enable
some amount of CI coverage with newer compilers.
This provides a newer ARC toolchain along with being based on a newer
Ubuntu bionic tag.
This takes ages to run single-threaded. Adjust it to use all available
processors.
It does not seem to be necessary to run buildman again to show errors,
since any errors can be shown by the first invocation and there is only
a single board being built. Update this to simplify the code, using the
-e flag to make sure errors are shown.
It seems unnecessary to read the exit code and then check it again. Drop
this and just let the test.py provide the exit code directly.
Ensure that this SPL test runs on gitlab.
We can use the -W flag to tell buildman to ignore warnings. Since we also
have -E defined, compiler warnings are promoted to errors, so they will
still cause a failure. But migration warnings of the form:
===================== WARNING ======================
This board does not use CONFIG_DM. CONFIG_DM will be
compulsory starting with the v2020.01 release.
Failure to update may result in board removal.
See doc/driver-model/migration.rst for more info.
will now be ignored.
Fixes: 329f5ef51d2 (travis.yml: run buildman with option -E)
Bash allows for variables to expand only if non-empty:
$ var=test
$ echo ${var:+"$var"}
test
$ echo ${var:+"-k $var"}
-k test
$ var=
Use this feature to avoid the workaround.
Avoid needing to know about the internal .bm-work directory, by passing
the -w flag to buildman.
This is not needed on travis since the -w flag is already used (from a
previous patch).
Drop the -P flag since this has no effect if -w is used.
Since TEST_PY_BD is always defined we can drop this check.
This does not affect travis since it has a single, unified script.
This has no effect since -S is not given also. Drop it.
This is not needed in the test.py part of the config, now since we use the
same name as the pytests.
Drop BUILDMAN, retaining it only for the 'build' parts of the config, i.e.
where we build multiple boards and don't run any tests.
The current method of selecting the board to build with test.py is a bit
error-prone, e.g. with "^sandbox$" it actually builds 5 boards (all of
those in the sandbox architecture).
Use the (newish) --board flag instead, to get the same result.
This does not affect travis since the previous commit already used the -w
flag.
This adds QEMU RISC-V 32/64 SPL testing. Unlike QEMU RISC-V 32/64,
we test SPL running in M-mode and U-Boot proper running in S-mode,
with a 4-core SMP configuration.
This adds the qemu-riscv32_defconfig test configuration.
- Based on newer 'bionic' snapshot
- GCC 9.0
- RISCV GRUB binaries
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2020.07
common:
- Align ENV_FAT_INTERFACE
- Fix MAC address source print log
- Improve based autodetection code
xilinx:
- Enable netconsole
Microblaze:
- Setup default ENV_OFFSET/ENV_SECT_SIZE
Zynq:
- Multiple DT updates/fixes
- Use DEVICE_TREE environment variable for DTB selection
- Switch to single zynq configuration
- Enable NOR flash via DM
- Minor SPL print removal
- Enable i2c mux driver
ZynqMP:
- Print multiboot register
- Enable cache commands in mini mtest
- Fix firmware probing when driver is not enabled
- Specify 3rd backup RAM boot mode in SPL
- Add SPL support for zcu102 v1.1 and zcu111 revA
- Redesign debug uart enabling and psu_init delay
- Enable full u-boot run from EL3
- Enable u-boot.itb generation without ATF with U-Boot in EL3
Versal:
- Enable distro default
- Enable others SPI flashes
- Enable systems without DDR
Drivers:
- Gem:
- Flush memory after freeing
- Handle mdio bus separately
- Watchdog:
- Get rid of unused global data pointer
- Enable window watchdog timer
- Serial:
- Change reinitialization logic in zynq serial driver
There are a lot of zynq configurations which can be merged together and use
only one for all. The similar change has been done for ZynqMP by commit
be1b6c32d940 ("arm64: zynqmp: Use zynqmp_virt platform")
Build SPL with u-boot.img for zc706 like this.
export DEVICE_TREE=zynq-zc706 && make xilinx_zynq_virt_defconfig && make -j8
u-boot.img is generic for all boards.
Tested on Zybo, zc702, zc706, zc770-xm011-x16, cc108 and microzed.
The Kconfig language provides a unit test that can be run. As these
require pytest to be installed and run very quickly, bundle them in to
an existing CI job.
Several patches delivered incorrect restructured text as documentation. We
should be able to discover this in Gitlab CI.
Provide a build step for 'make htmldocs'.
Bring in a newer Docker image to build on that has everything required
for running 'make htmldocs'.
When running our tests there are some cases where as part of the Python
2.7 to Python 3.6 migration we didn't force Python 3.6 to be used as
everything wasn't yet migrated. Now that everything is, make sure to
tell virtualenv to use python3. In the case of Travis this is best done
by making the tools test happen after the main tests so that it will
already have been run in all cases, TEST_PY_TOOLS is a subset of
TEST_PY_BD.
This is not needed now that we have SDL2 in the docker image. It causes
test failures for tests which need video to work.
This reverts commit af800722eb718bec51c5943cfb69231acf15178f.
sandbox conversion to SDL2
TPM TEE driver
Various minor sandbox video enhancements
New driver model core utility functions
Update to a newer Docker image that contains SDL2 libraries as required
by recent Sandbox changes.
Up to now we have been relying on openSUSE repositories for GRUB on arm and
arm64 though we have included GRUB in our Docker image.
Use the GRUB included in our Docker image.
I am not sure how to add libsdl2-dev to the gitlab image, so disable
building sandbox with SDL for now.
- Based on bionic-20200112 tag from Ubuntu
- Add graphviz (Heinrich)
- Updated base snapshot
- QEMU v4.2.0
Now that we have again fixed the problems that building with clang
exposes, enable these tests on Azure and GitLab-CI as well.
As things stand today, we have tools that CI requires where "python"
must be "python2". We need to use a virtualenv and pip in order to
ensure that our pytest tests can be run. Rework things slightly so
that:
- On Travis-CI, we install python-pyelftools for the platforms that
require pyelftools to be installed.
- On GitLab-CI, we move to a newer base image that includes python3-pip
and continue to use a virtualenv per job that needs it, for the
correct set of packages.
Tested-by: Simon Glass <sjg@chromium.org> [on sandbox]
Fix the following spit from pytest:
u-boot/test/py/conftest.py:438: RemovedInPytest4Warning: MarkInfo objects are deprecated as they contain merged marks which are hard to deal with correctly.
Please use node.get_closest_marker(name) or node.iter_markers(name).
Docs: https://docs.pytest.org/en/latest/mark.html#updating-code
for board in mark.args:
In both cases, the later suggestion is applicable.
Cc: Igor Opaniuk <igor.opaniuk@gmail.com>
[trini: Update for current file with a few more cases, un-pin pytest in CI]
Currently we set the entire PATH rather than prepend the new paths that
we need to have searched. This however breaks parts of the "virtualenv"
that was have set up and need to use as that also will be modifying
PATH. To fix this, prepend our new locations instead.
In a number of our stanzas we had multi-line commands that were one
space short of alignment, correct this.
