path: root/.gitignore
2013-07-30Add additional MLO images to .gitignoreJustin Waters
This rule catches images such as MLO.byteswap Signed-off-by: Justin Waters <justin.waters@timesys.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-17.gitignore: add GNU GLOBAL filesMasahiro Yamada
2013-05-06arm: mxs: Preprocess u-boot.bd so they contain full pathMarek Vasut
The u-boot-imx23.bd and u-boot-imx28.bd need to be preprocessed, otherwise they have issues with out-of-tree build where elftosb tool couldn't sometimes find the u-boot.bin and spl/u-boot-spl.bin . Preprocess these .bd files with sed and insert full path to u-boot.bin and spl/u-boot-spl.bin to prevent this issue. Moreover, to avoid adding more churn into main Makefile, move all this preprocessing and u-boot.sb generation into CPU directory instead. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-12imx: Add u-boot-with-nand-spl.imx make targetBenoît Thébaudeau
This image combines the SPL with the i.MX header, the FCB and U-Boot. For i.MX25/35/51, the FCB is ignored by the boot ROM, so this image is just useful because it can be programmed on a NAND Flash page boundary. For i.MX53, the FCB is required by the boot ROM. This does not support i.MX6 so far because its FCB is more complicated. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12imx: Add u-boot-with-spl.imx make targetBenoît Thébaudeau
This image combines the SPL with the i.MX header and U-Boot. This is a convenient way of having a single image to program on some boot devices. The i.MX header has to be added to the SPL before appending U-Boot, so that the boot ROM loads only the SPL. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12.gitignore: Add /SPLBenoît Thébaudeau
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-01-22imximage.cfg: run files through C preprocessorTroy Kisky
The '#' used as comments in the files cause the preprocessor trouble, so change to /* */. The mkimage command which uses this preprocessor output was moved to arch/arm/imx-common/Makefile .gitignore was updated to ignore .cfgtmp files. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-12-06add include/u-boot.lst to .gitignoreLuka Perkov
u-boot.lst is located in include directory. Update .gitignore file accordingly. Signed-off-by: Luka Perkov <luka@openwrt.org>
2012-10-22common: Add symbol handling for generic lists into MakefileMarek Vasut
This patch adds essential components for generation of the contents of the linker section that is used by the linker-generated array. All of the contents is held in a separate file, u-boot.lst, which is generated at runtime just before U-Boot is linked. The purpose of this code is to especially generate the appropriate boundary symbols around each subsection in the section carrying the linker-generated arrays. Obviously, the interim linker code for actual placement of the variables into the section is generated too. The generated file, u-boot.lst, is included into u-boot.lds via the linker INCLUDE directive in u-boot.lds . Adjustments are made in the Makefile and spl/Makefile so that the u-boot.lds and u-boot-spl.lds depend on their respective .lst files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-18IPL: Remove remains of OneNAND IPLMarek Vasut
After removing the Apollon board, remove the OneNAND IPL too. There are no users for it any more. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Minkyu Kang <promsoft@gmail.com> Cc: Tom Rini <trini@ti.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01hawkboard/omapl-138: Add support for generating ais image for hawkboardSughosh Ganu
Parameters used for configuring certain SoC peripherals are parsed from the cfg file and appended as part of the ais image's header. The u-boot-spl.ais generated is flashed separately to the nand, so do not delete the file after generation of u-boot.ais. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
2012-08-09Build: Ignore build tree and IDE control fileTimo Ketola
Signed-off-by: Timo Ketola <timo@exertus.fi>
2012-03-26.gitignore: Add .su filesTom Rini
The '-fstack-usage' option to gcc will generate .su files, ignore them. Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-24arm, davinci: Add support for generating AIS images to the MakefileChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2011-11-11iMX28: Add u-boot.sb target to MakefileMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-10-26fdt: Add support for a separate device tree (CONFIG_OF_SEPARATE)Simon Glass
This adds support for an FDT to be build as a separate binary file called u-boot.dtb. This can be concatenated with the U-Boot binary to provide a device tree located at run-time by U-Boot. The Makefile is modified to provide this file in u-boot-dtb.bin. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17Adjust dependency rules to permit per-file flagsSimon Glass
The dependency rules are currently done in a shell 'for' loop. This does not permit Makefile variables to adjust preprocessor flags as is done with normal compile flags, using the CFLAGS_path/file.o syntax. This change moves the dependency generation into the Makefile itself, and permits a CPPFLAGS_path/file.o to adjust preprocessor flags on a file or directory basis. The CPPFLAGS_... variable is also folded into CFLAGS during the build. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-06Tell git to ignore asm-offsets.sLaurence Withers
The generated file asm-offsets.s may be found at various depths in the arch subdirectories, so simply ignore it throughout the tree. Signed-off-by: Laurence Withers <lwithers@guralp.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-30omap4_panda: Ignore omap4 SPL called MLOJoe Hershberger
Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-21ignore soc asm-offsets.sMike Frysinger
Recent commit a4814a69d3bca6ee05f4bfc4 cleaned up generation of asm-offsets.s for SoC dirs, but missed adding it to the ignore list which makes it show up in `git status`. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-05-22.gitignore: update list of u-boot.* files and add *.binecc
This patch adds additional u-boot.* files mentioned in Makefile, and adds *.bin since these are deleted as part of "make clean". Signed-off-by: Eric Cooper <ecc@cmu.edu>
2011-01-17.gitignore: ignore generated u-boot.imxStefano Babic
2010-10-26include/asm-offsets.h: automatically generate assembler constantsWolfgang Denk
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc. To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files. In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree. We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well. We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-23.gitignore: ignore generated u-boot.ldsMike Frysinger
2009-07-21Add "tags" to .gitignore file.Po-Yu Chuang
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-05ignore .gdb_history filesMike Frysinger
When using gdb, history files will often get generated. So ignore them. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-09gitignore: add tags files and Vim swap fileMarkus Heidelberg
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
2008-08-06Fix merge problemsStefan Roese
2008-04-18gitignore: udpate stgit generated and .patch fileJean-Christophe PLAGNIOL-VILLARD
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14Add *~ to .gitignoreNiklaus Giger
One should never add a backup file ending in with ~ to the git repository. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-04generate u-boot.ldr for Blackfin targetsMike Frysinger
2008-01-09Add missing file in gitignore and commentsJean-Christophe PLAGNIOL-VILLARD
based on Linux source tree's .gitignore files Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-15Add .gitignore filesGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kim Phillips <kim.phillips@freescale.com>
