path: root/.gitignore
2011-05-22.gitignore: update list of u-boot.* files and add *.binecc
This patch adds additional u-boot.* files mentioned in Makefile, and adds *.bin since these are deleted as part of "make clean". Signed-off-by: Eric Cooper <ecc@cmu.edu>
2011-01-17.gitignore: ignore generated u-boot.imxStefano Babic
2010-10-26include/asm-offsets.h: automatically generate assembler constantsWolfgang Denk
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc. To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files. In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree. We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well. We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-23.gitignore: ignore generated u-boot.ldsMike Frysinger
2009-07-21Add "tags" to .gitignore file.Po-Yu Chuang
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-05ignore .gdb_history filesMike Frysinger
When using gdb, history files will often get generated. So ignore them. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-09gitignore: add tags files and Vim swap fileMarkus Heidelberg
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
2008-08-06Fix merge problemsStefan Roese
2008-04-18gitignore: udpate stgit generated and .patch fileJean-Christophe PLAGNIOL-VILLARD
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14Add *~ to .gitignoreNiklaus Giger
One should never add a backup file ending in with ~ to the git repository. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-04generate u-boot.ldr for Blackfin targetsMike Frysinger
2008-01-09Add missing file in gitignore and commentsJean-Christophe PLAGNIOL-VILLARD
based on Linux source tree's .gitignore files Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-15Add .gitignore filesGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kim Phillips <kim.phillips@freescale.com>
