path: root/.github
2020-07-15github: azure: Update our GitHub template to note for CITom Rini
While the general policy of not taking changes to the project via pull requests directly on GitHub has not changed, it can be useful to submit a PR there in order to trigger a CI run on Azure. These are run automatically and the results are populated back to GitHub. Add a note to the template to reflect this. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-09Add a github template telling people to not use pull requests thereTom Rini
On our mirror account on github we have gotten a handful of pull requests. At this time github does not allow you to disable pull requests on a project. The generally suggested work-around is to add a pull request template that tells people to not use that workflow. Add one here that points to the wiki page on submitted patches. Signed-off-by: Tom Rini <trini@konsulko.com>
