path: root/.azure-pipelines.yml
2022-02-11tools: mkeficapsule: allow for specifying GUID explicitlyAKASHI Takahiro
The existing options, "--fit" and "--raw," are only used to put a proper GUID in a capsule header, where GUID identifies a particular FMP (Firmware Management Protocol) driver which then would handle the firmware binary in a capsule. In fact, mkeficapsule does the exact same job in creating a capsule file whatever the firmware binary type is. To prepare for the future extension, the command syntax will be a bit modified to allow users to specify arbitrary GUID for their own FMP driver. OLD: [--fit <image> | --raw <image>] <capsule file> NEW: [--fit | --raw | --guid <guid-string>] <image> <capsule file> Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-02-11tools: mkeficapsule: add firmware image signingAKASHI Takahiro
With this enhancement, mkeficapsule will be able to sign a capsule file when it is created. A signature added will be used later in the verification at FMP's SetImage() call. To do that, we need specify additional command parameters: -monotonic-cout <count> : monotonic count -private-key <private key file> : private key file -certificate <certificate file> : certificate file Only when all of those parameters are given, a signature will be added to a capsule file. Users are expected to maintain and increment the monotonic count at every time of the update for each firmware image. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
2022-02-11CI: enforce packages upgrade for Msys2 on WindowsAKASHI Takahiro
We need to install libgnutls-devel package to build the host tool, mkeficapsule, and as of now, there seems to be a depencency conflict in the current msys2 installer; :: installing libp11-kit (0.24.1-1) breaks dependency \ 'libp11-kit=0.23.22' required by p11-kit To resolve this conflict, however, the initial "pacman -Syyuu" in 'tools_only_windows' job is not enough. Another "pacman -Su" will enforce all the out-of-date packages being upgraded. (Probably the first "-Syyuu" can be changed to "-Syu".) See the installation steps in https://www.msys2.org/ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2022-02-03Dockfile, CI: Update to latest focal tag and buildTom Rini
- Latest focal tag - Add libgnutls to image Signed-off-by: Tom Rini <trini@konsulko.com>
2022-01-28gitlab/azure: x86: Add a coreboot testSimon Glass
Coreboot supports U-Boot as a payload and this recently got a bit of a facelist. Add a test for this. For now this uses a binary build of coreboot (v4.15). Future work could potentially build it from source, but we need to figure out the toolchain problems first, since coreboot uses its own toolchain. It turns out that this is tricky, because coreboot fails to build with a vanilla gcc. This needs some changes to the hooks scripts as well. An example build is at https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/359687 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2022-01-12CI, Dockerfile: Update to latest "focal" tagTom Rini
Bring us to the focal-20220105 tag and rebuild our images on top of this. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-01-12ci: azure: Update to use stagesTom Rini
Follow what we do in GitLab CI where we break the jobs up in to stages such that if earlier and often quicker sanity tests fail we don't run everything else. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-27CI: Test for unmigrated CONFIG symbols in board config.h filesTom Rini
Now that all symbols that exist in Kconfig no longer also have boards setting them in the board config.h file, add a CI test to catch new instances of this, and fail. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-11-14Dockerfile, CI: Update to latest "focal" tagTom Rini
2021-11-11Azure: Move to windows-2019Tom Rini
As per https://github.com/actions/virtual-environments/issues/4312 the Windows-2016 environments are scheduled for deprecation and removal in early 2022. Move to windows-2019 now to avoid this (Visual Studio 2019 is included here, hence the tag naming scheme change). Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2021-10-21CI: Switch running the nokia_rx51 test with in-container toolchainTom Rini
Instead of fetching an arm toolchain to use, run the test with the one that's already in the container image. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2021-10-14CI: Update to LLVM-13Tom Rini
- Switch sources and CI scripts to install and use LLVM-13 - Update to latest "focal" tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-09-30Azure/GitLab CI: Update docker imageTom Rini
Rebuild our current docker image so that ca-certificates will be updated and Let's Encrypt issued certificates will work again. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-09-24ARM: vexpress_ca9x4: Reintroduce board in order to use with QEMU.Kristian Amlie
vexpress_ca9x4 is seemingly the only board except for qemu_arm which is able to run U-Boot correctly, using the `-M vexpress-a9` option to QEMU. Building for qemu_arm and running qemu-system-arm with the `-M virt` argument has a number of downsides, most importantly that it only supports virtio storage drivers. This significantly reduces its usefulness in testing memory card and Flash solutions, especially when the tested images are from a third party source. So therefore we reintroduce the vexpress_ca9x4 board in this commit, with the explicit goal of using it with QEMU. A number of differences to note from the original: * Since the board was apparently unmaintained, I have now set myself as the maintainer. * The board has been converted to use the driver model, which was the reason it was removed in the first place. * The vexpress_ca15_tc2 and vexpress_ca5x2 boards, which were removed in the same commit, are not necessary for the QEMU use case, and have been omitted. * An `mmc0` alias was introduced in the dts file. The mmc is not detected correctly without this, now that it's based on the device tree instead of the board's init function. * A couple of other nodes were removed because they were problematic when trying to run the UEFI bootmgr. Once again, the primary use case here is QEMU, and these nodes are not needed for that to work. * Unnecessary board init code has been removed, thanks to driver model and device tree. * `CONFIG_OF_EMBED` has been enabled. I know this goes against recommended practice, but there doesn't seem to be any other way to pass the dtb to U-Boot in the QEMU scenario. Using the -dtb argument does not work, I suppose because U-Boot doesn't use the same mechanics as the kernel when it's booting. * Load addresses have been changed to fit QEMU use case. People wanting to get a more detailed, yet somewhat isolated, diff between this and the original, can run this command: git diff c6c26a05b89f25a06e7562f8c2071b60fd0c9eac~1 -- \ $( git diff-tree --diff-filter=A -r --name-only HEAD~1 HEAD) (Make sure to either check out this commit first, or replace HEAD with the commit ID of this commit) Signed-off-by: Kristian Amlie <kristian.amlie@northern.tech>
2021-09-11CI: Update to latest container imagesTom Rini
- Current Ubuntu/Focal tag - QEMU 6.1.0 - genimage tool added Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-09-11azure/gitlab: Add tests for SiFive Unleashed boardBin Meng
This adds CI tests for SiFive Unleashed board. QEMU supports booting exact the same images as used on the real hardware out of the box, that U-Boot SPL loads U-Boot proper from either an SD card or the SPI NOR flash, hence we can easily set up CI to cover these 2 boot flows of SiFive Unleashed board. With this, now we can have regression testing of mmc-spi-slot and sifive spi drivers, as well as mmc and spi-nor subsystems. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2021-08-06ppc: Drop t4qds and b4860qds referencesSimon Glass
These boards have been removed. Drop the config file and other references. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-08-04CI: Update to LLVM-12Tom Rini
The current stable release of LLVM is 12, update to that. While at it, fix that we had not correctly upgraded to LLVM 11 previously. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-07-27AzureCI: Move i.MX8 builds to their own jobTom Rini
The aarch64 catch-all job is starting to get close to or exceed the time limit for jobs. Move the i.MX8 boards to their own job to fix this. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-07-08Azure: Remove "spear" jobsTom Rini
With the spear family of platforms gone, remove references to them from the build jobs. Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-07-07ppc: Remove sbc8641d boardTom Rini
This board has not been converted to CONFIG_DM_PCI by the deadline and is also missing conversion to CONFIG_DM. Remove it. This is also the last of the ARCH_MPC8641/MPC8610 platforms, so remove that support as well. Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-07-07Azure/GitLab: Move to gcc-11.1.0 and LLVM-11Tom Rini
- Move to gcc-11.1.0 builds from kernel.org for supported platforms and LLVM-11 for those tests. - As Heinrich has noted, the RISC-V platform specification has a profile OS-A for running rich operating systems like Linux and BSD. This profile requires 64bit and UEFI conforming to the EBBR. Only the 'embedded' profile may use 32bit. Given this, drop grub for 32bit RISC-V as it no longer compiles with gcc-11.1 and upstream is unlikely to fix it: https://www.mail-archive.com/grub-devel@gnu.org/msg30736.html - Update to grub-2.06 release to address other issues of building with gcc-11.1. - Update to newer Xtensa (gcc-9.2.0) and ARC (gcc-10.2) toolchains Cc: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Rick Chen <rick@andestech.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2021-07-05Docker/CI: Update to "focal" and latest buildTom Rini
Move us up to being based on Ubuntu 20.04 "focal" and the latest tag from Ubuntu for this release. For this, we make sure that "python" is now python3 but still include python2.7 for the rx51 qemu build as that is very old and does not support python3. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-07-05Azure: Add loop devices and CAP_SYS_ADMIN for sandbox test.py testsAlper Nebi Yasak
The filesystem test setup needs to prepare disk images for its tests, with either guestmount or loop mounts. The former requires access to the host fuse device (added in a previous patch), the latter requires access to host loop devices. Both mounts also need additional privileges since docker's default configuration prevents the containers from mounting filesystems (for host security). Add any available loop devices to the container and try to add as few privileges as possible to run these tests, which narrow down to adding SYS_ADMIN capability and disabling apparmor confinement. However, this much still seems to be insecure enough to let malicious container processes escape as root on the host system [1]. [1] https://blog.trailofbits.com/2019/07/19/understanding-docker-container-escapes/ Since the mentioned tests are marked to run only on the sandbox board, add these additional devices and privileges only when testing with that. An alternative to using mounts is modifying the filesystem tests to use virt-make-fs (like some EFI tests do), but it fails to generate a partitionless FAT filesystem image on Debian systems. Other more feasible alternatives are using guestfish or directly using libguestfs Python bindings to create and populate the images, but switching the test setups to these is nontrivial and is left as future work. Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
2021-07-05Azure: Add fuse device for test.py testsAlper Nebi Yasak
The EFI secure boot and capsule test setups need to prepare disk images for their tests using virt-make-fs, which requires access to the host fuse device. This is not exposed to the docker container by default and has to be added explicitly. Add it. Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
2021-06-22azure: Use msys2 20210604 installer for Windows buildBin Meng
MSYS2 Windows build started to fail since yesterday (Jun 21): checking keyring... checking package integrity... error: gcc-libs: signature from "David Macek <david.macek.0@gmail.com>" is unknown trust :: File /var/cache/pacman/pkg/gcc-libs-10.2.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)). error: gcc: signature from "David Macek <david.macek.0@gmail.com>" is unknown trust :: File /var/cache/pacman/pkg/gcc-10.2.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)). error: failed to commit transaction (invalid or corrupted package) Errors occurred, no packages were upgraded. Switching to the latest installer (version 20210604) seems to fix it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Tom Rini <trini@konsulko.com>
2021-05-25MIPS: remove deprecated qemu_mips boardDaniel Schwierzeck
Remove qemu_mips boards because DM migration doesn't make sense. The board support for qemu_mips is already marked as deprecated in Qemu in favour of the Malta board. Also qemu_mips support has been removed from Linux a long time ago. The official replacement is the Malta board. The same Malta U-Boot image can be used with Qemu and on physical hardware. All combinations of Big Endian and Little Endian as well as 32 bit and 64 bit are supported. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2021-04-29Azure/GitLab: Ensure we use requirements.txt for testsuitesTom Rini
Given that test/py/requirements.txt has all required test modules, make use of that rather than a manual pip install list before running our assorted tool testsuites. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2021-04-10arm: Remove vexpress_ca15_tc2 boardTom Rini
This board has not been converted to CONFIG_DM_MMC by the deadline. Remove it. Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-04-07Azure/GitLab: bump OpenSBI version to 0.9Heinrich Schuchardt
Version 0.9 of OpenSBI provides the system reset extension which allows us to reset and power off boards without board specific code. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2021-04-07Azure: Rework SH / Renesas jobTom Rini
Now that there is a single SuperH platform, rework the Azure job slightly. Azure build time limits mean that we need to split the world build up still. Make a single build job for the single Renesas SuperH platform as well as all of the ARM platforms from Renesas. Cc: Marek Vasut <marek.vasut+renesas@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-03-29Merge tag 'v2021.04-rc5' into nextTom Rini
Prepare v2021.04-rc5
2021-03-27Azure: Use "pacman -Sy" to install the toolchainTom Rini
We now see an error such as: warning: database file for 'ucrt64' does not exist (use '-Sy' to download) error: failed to prepare transaction (could not find database) So use -Sy as suggested. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2021-03-26azure/gitlab: Add tests for sandbox_noinstSimon Glass
Add this new board to the test plans. Travis-CI is left out, since it is being removed soon due to lack of capacity. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2021-03-22azure: Use --board flag with sandbox_splSimon Glass
At present there is only one board which uses sandbox SPL. But with sandbox_noinst being added, this is no longer true. Add a --board flag so that we just build one board on azure, as is done in gitlab. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2021-03-04Azure/GitLab: Use buildman -T0 for binman, etc, testTom Rini
There are times where buildman seems to get stuck in this job when in CI. Forcing single-threaded here allows us to complete and move on. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-02-28uboot-test-hooks: Switch to our GitLab instanceTom Rini
As Stephen is no longer actively maintaining the uboot-test-hooks repository, switch to using the instance on our GitLab. Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-02-01azure: Add -E back for the world build scriptBin Meng
Commit dd5c954e917b ("travis/gitlab/azure: Use -W to avoid warnings check") added -W to avoid warnings check, but it mistakenly dropped -E for the world build script in the azure pipelines. This caused builds on the azure pipelines fail to report warnings. Let's add it back. Fixes: dd5c954e917b ("travis/gitlab/azure: Use -W to avoid warnings check") Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-27.gitlab-ci: install doc/sphinx/requirements.txtHeinrich Schuchardt
Install all requirements according to doc/sphinx/requirements.txt in the virtual environment used for testing 'make htmldocs'. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-11-05azure/gitLab/travis: Add pygit2 as a dependency for testsSimon Glass
This lets patman run all of its tests, rather than skipping quite a few. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-10-29Azure/GitLab/Travis: Add SPL unit testsSimon Glass
Run SPL unit tests in all test environments. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-09-15Azure/GitLab/Travis: Add SH4 r2dplus machine with various PCI ethernet optionsMarek Vasut
Add SH4 R2Dplus machine configured to test various U-Boot PCI ethernet options -- RTL8139, EEPRO100, AMD PCnet, DEC Tulip. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-09-02Azure/GitLab: Update to latest Docker containerTom Rini
- New base snapshot - Fix for high UID/GID numbers on a toolchain Signed-off-by: Tom Rini <trini@konsulko.com>
2020-08-05Azure/Travis: Update to latest Docker imageTom Rini
- New bionic snapshot - Updated sbsigntool - Include SH4 in qemu Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28azure: Switch to use the MSYS2 official installer as the CI baseBin Meng
Recent CI failures were seen [1] when building MSYS2 Windows host tools. The error messages are something like: downloading mingw32.db... downloading mingw32.db.sig... error: mingw32: key "4A6129F4E4B84AE46ED7F635628F528CF3053E04" is unknown error: mingw32: signature from "David Macek <david.macek.0@gmail.com>" is unknown trust error: failed to update mingw32 (invalid or corrupted database (PGP signature)) Per the MSYS2 official news [2], this was caused by a packager switch and several solutions were suggested, e.g.: a new package of msys2-keyring and a new msys2 installer that includes them are released. However right now we have been using the MSYS2 github CI base repo [3] for the MSYS2 build in U-Boot, but per the project information on the github webpage, it says: "This repository is unused/deprecated and will be remove after 2021-01-01". Since it is unmaintained it's unlikely the new PGP keys will be included in the git repo, and the only choice is to switch to use the MSYS2 official installer as the CI base instead. [1] https://dev.azure.com/u-boot/u-boot/_build/results?buildId=975 [2] https://www.msys2.org/news/#2020-06-29-new-packagers [3] https://github.com/msys2/msys2-ci-base Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-07-28azure: Add the missing build dependency for MSYS2 buildBin Meng
Package 'flex' is needed when building the U-Boot host tool, but is currently missing in the build dependency in the CI pipeline. This is to prepare switching to an installer based CI build. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-07-28azure: Drop 32-bit MSYS2 buildBin Meng
As of 2020-05-17, 32-bit MSYS2 is no longer actively supported by the upstream [1]. Let's drop the 32-bit Windows host tool build. [1] https://www.msys2.org/news/#2020-05-17-32-bit-msys2-no-longer-actively-supported Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-07-28azure: Use a login shell everywhere for MSYS2 buildBin Meng
This simplifies things a bit to just use a login shell everywhere. This keeps in sync with MSYS2 upstream commit: 9d11b7f0aa93 ("azure-pipelines: simplify things a bit"). Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-07-24patman: Add a 'test' subcommandSimon Glass
At present we use --test to indicate that tests should be run. It is better to use a subcommand for list, like binman. Change it and adjust the existing code to fit under a 'send' subcommand, the default. Give this subcommand the same default arguments as the others. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-07-24Merge https://gitlab.denx.de/u-boot/custodians/u-boot-riscvTom Rini
- Fix SiFive HiFive Unleashed board booting failure problem. - Enable SiFive fu540 PWM driver. - Support SiFive fu540: SPI boot. - Update OpenSBI used for RISC-V CI testing. - Revert "riscv: Allow use of reset drivers". - Revert "Revert "riscv: sifive: fu540: Add gpio-restart support"". - sysreset: syscon: - Don't assume default value for offset and mask property. - Support value property. - qemu: Add syscon reboot and poweroff support. - Fix SIFIVE debug serial dependency. - Fix linking error when building u-boot-spl with no SMP support. - AE350 use fdtdec_get_addr_size_auto_noparent to parse smc reg. - Make memory node available to SPL in hifive-unleashed-a00-u-boot.dtsi - SiFive fu540 avoid using hardcoded ram base and size.
