As Stephen is no longer actively maintaining the uboot-test-hooks
repository, switch to using the instance on our GitLab.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
(cherry picked from commit 85ae52b9593894fa31d80d83d76bdb3b6432c4be)
- Add guestfstools, efitools
- Latest Ubuntu/bionic snapshot
Add building the 'tools-only' target on macOS X 'Catalina'. Hopefully
this will catch changes to host tools that are incompatible on BSD style
environments.
This patch contains test/nokia_rx51_test.sh script which automatically
download and compile all needed tools in local temporary directory to
generate a simple MTD images for booting Maemo kernel image by U-Boot from
RAM, eMMC and OneNAND. MTD images are then run in virtual n900 machine
provided by qemu-linaro project.
This script does not need any special privileges, so it can be run as
non-root nobody user.
It can be used to check that U-Boot for Nokia N900 is not broken and can be
successfully booted in emulator.
Script is registered to .azure-pipelines.yml, .gitlab-ci.yml and
.travis.yml so it would be automatically run on those CI services.
Signed-off-by: Pali Rohár <pali@kernel.org>
At this point LLVM-7 is rather old. Switch over to LLVM-10 to enable
some amount of CI coverage with newer compilers.
This provides a newer ARC toolchain along with being based on a newer
Ubuntu bionic tag.
This takes ages to run single-threaded. Adjust it to use all available
processors.
It does not seem to be necessary to run buildman again to show errors,
since any errors can be shown by the first invocation and there is only
a single board being built. Update this to simplify the code, using the
-e flag to make sure errors are shown.
It seems unnecessary to read the exit code and then check it again. Drop
this and just let the test.py provide the exit code directly.
Ensure that this SPL test runs on gitlab.
We can use the -W flag to tell buildman to ignore warnings. Since we also
have -E defined, compiler warnings are promoted to errors, so they will
still cause a failure. But migration warnings of the form:
===================== WARNING ======================
This board does not use CONFIG_DM. CONFIG_DM will be
compulsory starting with the v2020.01 release.
Failure to update may result in board removal.
See doc/driver-model/migration.rst for more info.
will now be ignored.
Fixes: 329f5ef51d2 (travis.yml: run buildman with option -E)
Bash allows for variables to expand only if non-empty:
$ var=test
$ echo ${var:+"$var"}
test
$ echo ${var:+"-k $var"}
-k test
$ var=
Use this feature to avoid the workaround.
Avoid needing to know about the internal .bm-work directory, by passing
the -w flag to buildman.
This is not needed on travis since the -w flag is already used (from a
previous patch).
Drop the -P flag since this has no effect if -w is used.
Since TEST_PY_BD is always defined we can drop this check.
This does not affect travis since it has a single, unified script.
This has no effect since -S is not given also. Drop it.
This is not needed in the test.py part of the config, now since we use the
same name as the pytests.
Drop BUILDMAN, retaining it only for the 'build' parts of the config, i.e.
where we build multiple boards and don't run any tests.
The current method of selecting the board to build with test.py is a bit
error-prone, e.g. with "^sandbox$" it actually builds 5 boards (all of
those in the sandbox architecture).
Use the (newish) --board flag instead, to get the same result.
This does not affect travis since the previous commit already used the -w
flag.
This adds QEMU RISC-V 32/64 SPL testing. Unlike QEMU RISC-V 32/64,
we test SPL running in M-mode and U-Boot proper running in S-mode,
with a 4-core SMP configuration.
This adds the qemu-riscv32_defconfig test configuration.
- Based on newer 'bionic' snapshot
- GCC 9.0
- RISCV GRUB binaries
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2020.07
common:
- Align ENV_FAT_INTERFACE
- Fix MAC address source print log
- Improve based autodetection code
xilinx:
- Enable netconsole
Microblaze:
- Setup default ENV_OFFSET/ENV_SECT_SIZE
Zynq:
- Multiple DT updates/fixes
- Use DEVICE_TREE environment variable for DTB selection
- Switch to single zynq configuration
- Enable NOR flash via DM
- Minor SPL print removal
- Enable i2c mux driver
ZynqMP:
- Print multiboot register
- Enable cache commands in mini mtest
- Fix firmware probing when driver is not enabled
- Specify 3rd backup RAM boot mode in SPL
- Add SPL support for zcu102 v1.1 and zcu111 revA
- Redesign debug uart enabling and psu_init delay
- Enable full u-boot run from EL3
- Enable u-boot.itb generation without ATF with U-Boot in EL3
Versal:
- Enable distro default
- Enable others SPI flashes
- Enable systems without DDR
Drivers:
- Gem:
- Flush memory after freeing
- Handle mdio bus separately
- Watchdog:
- Get rid of unused global data pointer
- Enable window watchdog timer
- Serial:
- Change reinitialization logic in zynq serial driver
There are a lot of zynq configurations which can be merged together and use
only one for all. The similar change has been done for ZynqMP by commit
be1b6c32d940 ("arm64: zynqmp: Use zynqmp_virt platform")
Build SPL with u-boot.img for zc706 like this.
export DEVICE_TREE=zynq-zc706 && make xilinx_zynq_virt_defconfig && make -j8
u-boot.img is generic for all boards.
Tested on Zybo, zc702, zc706, zc770-xm011-x16, cc108 and microzed.
The Kconfig language provides a unit test that can be run. As these
require pytest to be installed and run very quickly, bundle them in to
an existing CI job.
We keep both of these jobs in sync as much as possible even when the
primary motivation is to keep Travis from exceeding the build time limit
there. With that in mind:
- Use "rk" not "rockchip" to get all Rockchip SoC platforms in one job,
rather than just all Rockchip vendor platforms.
- The NXP LX216* SoCs have their own job, exclude them from the AArch64
generic job.
- SoCFPGA SoCs have their own job, exclude them from the AArch64 generic
job.
Several patches delivered incorrect restructured text as documentation. We
should be able to discover this in Azure CI.
Provide a build step for 'make htmldocs'.
Bring in a newer Docker image to build on that has everything required
for running 'make htmldocs'.
When running our tests there are some cases where as part of the Python
2.7 to Python 3.6 migration we didn't force Python 3.6 to be used as
everything wasn't yet migrated. Now that everything is, make sure to
tell virtualenv to use python3. In the case of Travis this is best done
by making the tools test happen after the main tests so that it will
already have been run in all cases, TEST_PY_TOOLS is a subset of
TEST_PY_BD.
Update to a newer Docker image that contains SDL2 libraries as required
by recent Sandbox changes.
Use the same logic from 24df1b14f3ab to use our own GRUB binaries in
Azure pipelines as well.
Azure is moving to remove the vs2015-win2012r2 platform build host. The
two suggested new platforms to use are vs2017-win2016 and windows-2019.
For now, move up to vs2017-win2016.
Cc: Bin Meng <bmeng.cn@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
- Based on bionic-20200112 tag from Ubuntu
- Add graphviz (Heinrich)
- Updated base snapshot
- QEMU v4.2.0
remove from NXP arm32 all layerscape boards and
build them instead in already existing layerscape
jobs (which now not only build aarch64 boards)
Now that we have again fixed the problems that building with clang
exposes, enable these tests on Azure and GitLab-CI as well.
Similar to 90d3d78a1c68 ("gitlab-ci: Prepend to PATH rather than replace
it") we need to prepend the PATH with our additional binaries and not
replace the value fully as doing so breaks virtualenv.
Similar to the rework for GitLab-CI and Travis-CI, rework the Azure
Pipeline to use python3 and requirements.txt to install the necessary
modules.
This expands current Azure Pipelines Windows host tools build
testing to cover all the CI testing in gitlab and travis CI.
Note for some unknown reason, the 'container' cannot be used for
any jobs that have buildman, for buildman does not exit properly
and hangs the job forever. As a workaround, we manually call
docker to run the image to perform the CI tasks.
A complete run on Azure Pipelines takes about 2 hours and 10
minutes.
Microsoft Azure Pipelines [1] provides unlimited CI/CD minutes and
10 parallel jobs to every open source project for free.
This adds a configuration file for Azure Pipelines to utilize the
free Windows VM hosted by Microsoft to ensure no build broken in
building U-Boot host tools for Windows.
[1] https://azure.microsoft.com/en-us/blog/announcing-azure-pipelines-with-unlimited-ci-cd-minutes-for-open-source/
