Bump SRCREV hashes as used in build of Fri 20 Oct 2023 09:11:30 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 423
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/423
Signed-off-by: ci.toradex <cicd@toradex.com>
(cherry picked from commit 55e8a0ac45a54450ef1cc7c5d6c4e9d45d58bc56)
Bump SRCREV hashes as used in build of Wed 04 Oct 2023 11:08:30 AM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 405
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/405
(cherry picked from commit 704141cace404fcb84f0e5d86fc2658ef2225763)
Bump SRCREV hashes as used in build of Wed 30 Aug 2023 09:36:28 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 375
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/375
Use the new class toradex-kernel-deploy-config to deploy the used
kernel config.
Related-to: ELB-5149
LOCALVERSION is already handled in the inherited class
toradex-kernel-localversion.bbclass. The delete line used to be a
duplicate of what was already done in the class, however with recent
changes in openembedded-core it now is even harmful.
Related-to: ELB-5330
Bump SRCREV hashes as used in build of Wed 02 Aug 2023 09:09:58 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 350
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/350
Related-to: ELB-5238
- Update to the toradex_ti-linux-6.1.y branch, based on the
ti-linux-6.1.y branch.
- Change to use the in tree defconfig 'toradex_defconfig'
- Drop redepends on tifs-lpm-stub
This follows meta-ti's commit c23cd182 ("ti-sci-fw: Include the TIFS
LPM stub with the rest of SYSFW").
The package no longer exists, the FW is handled in a different way.
Bump SRCREV hashes as used in build of Fri 23 Jun 2023 10:48:08 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 319
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/319
Drop this, it was used only for the initial layer creation.
Related-to: ELB-5190
Bump SRCREV hashes as used in build of Thu 01 Jun 2023 09:49:56 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 299
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/299
Enable DSI bridge driver used on the Verdin Carrier Boards: Lontium
LT8912B and TI SN65DSI83.
Refresh also to the latest to TI Linux 08.06.00.007 release, with the
main change being the explicit enable of the PWM, since it is no longer
implied.
Related-to: ELB-5026
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
Bump SRCREV hashes as used in build of Sun 30 Apr 2023 08:30:48 AM UTC
Matrix Build: image-torizoncore-kirkstone-6.x.y-nightly-matrix 257
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-nightly-matrix/257
Bump SRCREV hashes as used in build of Mon 24 Apr 2023 10:04:33 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 268
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/268
Switch to the branch which matches the device trees from
the toradex_ti-linux-5.10.y_bringup kernel and update the
SRCREV to latest.
Related-to: ELB-5018
Bump SRCREV hashes as used in build of Tue 28 Feb 2023 10:05:55 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 214
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/214
Our 1GB RAM size doesn't allow 512MB of CMA. Without CMA graphics
is not started.
Related-to: ELB-5041
We have these in the separate bootfs partition.
Also only build the Image, Image.gz binaries, not additionally
vmlinux.gz and fitImage as set in the k3.inc file.
Deploy currently Image, as U-Boot loadaddr and kernel_addr_r are
not yet ready to cope with the decompression.
Related-to: ELB-5012
Refresh our defconfig with changes from the kernel update.
The needed includes and inherits are moved into the recipe itself.
Related-to: ELB-4978
Rather than pinning to 08.05.00.21 uprev to d9ca44672caed which
includes commit ("778fa2337f04 drm: tidss: Fix pixel format definition")
This prevents a weston 10 runtime assert which would otherwise
require a patch to weston.
Currently a copy of the one used for NXP boards.
