Address the following warnings:
WARNING: QA Issue: nvsamples rdepends on libice, but it isn't a build dependency? [build-deps]
WARNING: QA Issue: nvsamples rdepends on libsm, but it isn't a build dependency? [build-deps]
With the Linux 4.4 kernel a new DRM driver for the Display Controller Unit
(DCU) is available. To make direct use of the DRM driver use the Xorg
modesetting driver instead of the fbdev driver. This also allows to use
xrandr.
As we inject binary only drivers drop the DEPENDS and skip the checks
if all referenced shared objects have been built as a dependency.
meta-openembedded provides a recipe for joe, use that one.
OpenMAX-IL implementation library aka libgstomx, evaluation version
with fix to validate input frame rate.
This fixes:
WARNING: QA Issue: tegrastats-gtk requires libpangocairo-1.0.so.0, libpango-1.0.so.0,
libcairo.so.2, libpangoft2-1.0.so.0, libgtk-x11-2.0.so.0, libgdk-x11-2.0.so.0,
but no providers in its RDEPENDS [file-rdeps]
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
build-deps: add the following to DEPENDS which are referenced by the binaries:
libxv gstreamer libpcre alsa-lib gst-plugins-base
Don't check for file-rdeps
Use the exact base types as X11 defines them. Newer compilers
through errors when mixing unsigned with unsigned long and
the likes.
Integrate L4T R16.5 for T20 currently exclusively distributed via
NVIDIA's partner portal. Should supposedly fix some memory leaks in
gstreamer resp. its OpenMAX wrapper thereof.
Integrate L4T R16.5 currently exclusively distributed via NVIDIA's
partner portal and for T30 only. Should supposedly fix some memory
leaks in gstreamer resp. its OpenMAX wrapper thereof.
While at it:
- Unpack OpenMAX IL headers with overwrite option
- Cleanup recipe and delete unused files
Qt5 uses tokens which would be renamed through defines in the X11 headers.
So don't inject these defines into Qt5 sources through eglplatform.h.
gcc 4.8 is more strict on type mismatch in assignments, so use correct
variable type for the EGLNativeDisplayType pointer.
On a fast server nvsamples rarly failed due to missing references.
Don't use parallel make and use a symlink instead of a copy
operation to move the related lib to its deployment place.
Change to new way of inhibiting warning
from INHIBIT_PACKAGE_DEBUG_SPLIT = "1"
to INSANE_SKIP_${PN} = "already-stripped"
For qt5 khronos headers needs more definitions.
Fix comments in xorg.conf files for the Tegras.
Provide the tarball locally rather than download it as
the tarball is regularly changed and thus breaking the recipe.
- update binary userspace drivers to R16.4
- remove old versions
- use the SOC Family tegra2 / tegra3 for file paths
Add sections for both monitor outputs, add example configuration to
disable an output as well as select prefered mode.
- also add the relevant configuration files
while at it
add PROVIDES for EGL, GLES 1.1, 2.0
use SOC FAMILY to simplify recipe
With the propriatry GPU driver, some text is not rendered.
e.g. like in this report
http://slopjong.de/2012/11/19/problem-with-font-rendering/
-> remvert the relevant patch
- xserver driver api now at version 13
- conflicting wpasupplicant.conf renamed
- move debug info into the dbg package
khronos_headers.tgz has been updated with newer stuff from the khronos registry.
As the file download is not version controlled a download will fail due to
changed checksums.
- 32bpp framebuffers use a lot of memorybandwidth, 16bpp is a better default
- nvgstplayer must be called in a terminal window
- added mp3, wav, au audio mimetypes
