Latest additions:
- 0024-apalis_t30-enable-broken-hpi-on-emmc.patch
Avoid a rare soft lockup upon installing an image from within Tezi.
- 0025-tegra_defconfig-disable-sound-in-tezi-configuration.patch
Avoid keyboard/mouse being unresponsive for 10-15 Seconds.
- 0026-apalis_t30-fix-mmc1-cmd-pull-up.patch
Avoid issues with higher speed SD cards.
- 0027-apalis_t30-pull-up-sd-card-detect-pins.patch
Avoid floating SD card detect pins.
- 0028-Revert-mmc-tegra-Disable-UHS-I-modes-for-Tegra124.patch
Allow for UHS-I modes on TK1.
- 0029-mmc-tegra-fix-eMMC-DDR-mode.patch
Fix eMMC DDR mode.
- 0030-apalis-tk1-enable-ddr52-mode-on-emmc.patch
Enable eMMC DDR mode.
- 0031-apalis-tk1-force-fixed-ids-for-sdmmc-controllers.patch
Avoid re-ordering of SDMMC controller instances.
- 0032-apalis-tk1-fix-pcie-reset-for-reliable-gigabit-ether.patch
Fix PCIe gigabit bring-up issue on Apalis TK1.
Drop commit c35b518f9ba0 ("clk: tegra: Fix pll_u rate configuration")
which meanwhile got merged into stable.
(cherry picked from commit 9026b9397dcb2e7fb150fcc7976c344d73392ab8)
Add the following patches:
- apalis-t30/tk1-mainline: igb: avoid nvm checksum failure
- apalis_t30: fix can2
- mfd: as3722: disable auto power on when AC OK
(cherry picked from commit 8987b7e1754cbafc8e39682f093c8136a79a606b)
(cherry picked from commit 104809f8ead8327d69b142c521e7105ebe7fd4ce)
Move the USB device aka gadget fix from Tezi to here.
Add patches to force fixed IDs for SDMMC controllers.
Add patch to fix for PLL_U rate configuration (T30).
Add Apalis T30 specific patch for PCIe fix hacks.
(cherry picked from commit 7da6da579b7d90b7ca6560c880bd3f58ecb73df2)
(cherry picked from commit 4b2804c9fbbe84ecc997a292f95136d4e2140317)
Some patches meanwhile got accepted mainline. Backport those
patches.
(cherry picked from commit 2510fffc782e8097639d082bc04d50c3021dda80)
Integrate Thierry's fbdev mmap fix allowing legacy applications that use
the mmap() syscall on the fbdev device to map framebuffer memory without
causing a hang. Useful e.g. for Tezi.
While at it also update to 4.14.30.
(cherry picked from commit 83d29c9dde04d0c8f2460831a6b22bce6579a72e)
Update to latest Linux LTS 4.14.
(cherry picked from commit 7bcd5eac4e92b1f372835e9f44066f6dd337bd61)
Update to NVIDIA's latest Linux for Tegra aka L4T R21.6:
https://developer.nvidia.com/linux-tegra-r216
The following libraries got updated:
c0067724f7ea174ac845bcf3262916f4cdc68fee */usr/lib/xorg/modules/extensions/libglx.so
7fdf08dac2661c78aa13d72caa205660435a0591 */usr/lib/xorg/modules/drivers/nvidia_drv.so
61fe4c3e02eee124a0b50e0d2f616701c3093da8 */usr/lib/arm-linux-gnueabihf/tegra/libnvomx.so
c0067724f7ea174ac845bcf3262916f4cdc68fee */usr/lib/arm-linux-gnueabihf/tegra/libglx.so
06ff56f0001e07b9e5271e5d1c8ee78a0ddd299d */usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_video.so
abdccb24f89f1f0e482524569f9b6364c1fff0a9 */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_imager.so
3e9b93e4e3bf24980d025917d694e1f23147837f */usr/lib/arm-linux-gnueabihf/tegra/libnvmm_camera_v3.so
1ee7838597bd9a351b4e241ba947b55d8b4419db */usr/lib/arm-linux-gnueabihf/tegra/libnvparser.so
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
greatest.
in local.conf:
DDC/EDID detection was failing on Apalis TK1 V1.2A on Ixora.
Update to latest Linux LTS 4.9.52, add V1.2 hardware support and prepare
for optional CI top of linux-stable 4.9.y branch builds.
Prepare for snapd integration.
Use the d.*Var variant instead.
pushd and popd are not posix compliant.
Instead of patching every app, let's patch mesa to pretend
that we have a normal GPU.
based on: github.com/Gnurou/mesa/commits/renderonly
While at it consistently use a lower case 'v' as with U-Boot and kernel
in meta-toradex-nxp.
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
The regular implementation works.
linux-toradex.inc's functionality is provided with linux-dtb.inc for current
device tree enabled kernels. So don't include both include files.
Prevents
ERROR: QA Issue: kernel-devicetree is listed in PACKAGES multiple times, this leads to packaging errors. [packages-list]
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
