path: root/recipes-kernel/linux/linux-toradex-mainline-4.14/0018-apalis-t30-mainline-force-fixed-ids-for-sdmmc-contro.patch
2018-07-27apalis-t30/tk1-mainline: update patchsetMarcel Ziswiler
Latest additions: - 0024-apalis_t30-enable-broken-hpi-on-emmc.patch Avoid a rare soft lockup upon installing an image from within Tezi. - 0025-tegra_defconfig-disable-sound-in-tezi-configuration.patch Avoid keyboard/mouse being unresponsive for 10-15 Seconds. - 0026-apalis_t30-fix-mmc1-cmd-pull-up.patch Avoid issues with higher speed SD cards. - 0027-apalis_t30-pull-up-sd-card-detect-pins.patch Avoid floating SD card detect pins. - 0028-Revert-mmc-tegra-Disable-UHS-I-modes-for-Tegra124.patch Allow for UHS-I modes on TK1. - 0029-mmc-tegra-fix-eMMC-DDR-mode.patch Fix eMMC DDR mode. - 0030-apalis-tk1-enable-ddr52-mode-on-emmc.patch Enable eMMC DDR mode. - 0031-apalis-tk1-force-fixed-ids-for-sdmmc-controllers.patch Avoid re-ordering of SDMMC controller instances. - 0032-apalis-tk1-fix-pcie-reset-for-reliable-gigabit-ether.patch Fix PCIe gigabit bring-up issue on Apalis TK1. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-06-18linux-toradex-mainline: more patches also for apalis t30Marcel Ziswiler
Move the USB device aka gadget fix from Tezi to here. Add patches to force fixed IDs for SDMMC controllers. Add patch to fix for PLL_U rate configuration (T30). Add Apalis T30 specific patch for PCIe fix hacks. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
