Update linux-toradex-mainline to 4.14.109.
Now with 10.1 inch displays soon being available make those settings the
default. Note that one still needs to set vidargs properly e.g. from
within U-Boot as follows:
Apalis T30 # setenv vidargs 'video=tegrafb0:1280x800-16@60 fbcon=map:1'
Update linux-toradex-mainline to 4.14.90.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Add a script to the lvds-ctrl recipe for setting the correct mode for
10.1" display
Update linux-toradex-mainline to 4.14.72.
While at it drop obsolete linux-toradex-mainline 4.9 recipe.
Enforcing to build 32-bit binaries for native and portions thereof
using -m32 in EXTRA_OEMAKE_class-native may lead to building errors.
Also, it seems it's time to move on from 32-bit compatibility.
Affected repositories:
meta-toradex-demos
meta-toradex-nxp
meta-toradex-tegra
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Generate cbootimage already during build as required for Toradex Easy
Installer BSP package.
The eMMC unlocking was missing which lead to the following error
message:
Write error on /dev/mmcblk0boot0: Operation not permitted
Error: can't write fw_env to flash
Include u-boot-toradex-env.inc will generate a uEnv.txt text
file containing the default environment of the U-Boot binary.
As this recipe adds only binary drivers it does not need any DEPENDS
to build.
However adding depends prevents QA warnings which test the binaries
for dependencies and, more importantly other recipe will get needed
dependencies installed in their sysroot.
e.g. lxqt-panel would fail because libdamage is not installed in its recipe
specific sysroot.
While at it use -p with mkdir to not fail even if the directory already exists
from a previous (failed) run of bitbake.
While at it move the libpcre* symlinks to the nv-gstapps packages where they
are used and RDEPEND on the real libpcre* libraries.
New EGL code uses EGL_PLATFORM_X11_KHR (for example glmark2) and the
value is the same, so we can provide an alias for it instead of
patching every code using it.
(Adapted from meta-freescale, commit e1d249bb067aa6c472367cff1e77ba2ddbc8303f)
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
No functional change intended.
The U-Boot Makefile has a unusual way of compiling the user space tools which
results in the wrong toolchain (native vs. target) being used.
Drop our downstream fix in favour of how openembedded-core does this now.
Move UBOOT_BINARY, UBOOT_IMAGE and UBOOT_SYMLINK definitions to machine
configuration re-used by the Toradex Easy Installer U-Boot recipe.
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
Fix the include path.
Reported-by: Andreas Holzammer, kdab.com
The binary drivers in tdx-nv-binaries have dependencies on gstreamer
et. al.
Add them to DEPENDS, so that they are available during do_rootfs.
Addresses:
| Collected errors:
| * calculate_dependencies_for: Cannot satisfy the following dependencies for packagegroup-basic:
| * gstreamer (>= 0.10.36) * libgstaudio-0.10-0 (>= 0.10.36) * libgstinterfaces-0.10-0 (>= 0.10.36) * libgstvideo-0.10-0 (>= 0.10.36) * libxv1 (>= 1.0.10) *
| * opkg_solver_install: Cannot install package packagegroup-basic.
| * calculate_dependencies_for: Cannot satisfy the following dependencies for tdx-nv-binaries-nv-gstapps:
| * gstreamer (>= 0.10.36) * libgstinterfaces-0.10-0 (>= 0.10.36) *
| * opkg_solver_install: Cannot install package tdx-nv-binaries-nv-gstapps.
- adapt to the changes introduced with recipe specific sysroots
- tegrarcm can now also be built for a target
- tegrarcm can now also be built for nativesdk
While at it also update the comment in recipes-graphics/mesa/mesa_%.bbappend.
While at it also rename it from trdx-k20-fw to tdx-k20-fw.
Use INSANE_SKIP_<package> in place of the unusual WARN_QA_remove.
Use the new version variables plus the git hash. Inspired by
meta-freescale/classes/fsl-u-boot-localversion.bbclass.
The 'rdepending' packages are picked up automatically by the
buildsystem.
This reverts commit 5b5356a28d06ccb8806310b4133b345fae178aba.
The commit duplicated the bbappend which now lives in
jetson-tk1/recipes-bsp/binary-drivers. Thus remove the duplicated
file.
