Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
While at it append -tk1 to PN to have a name different from the u-boot recipe
name for our NXP based SoM and set the prefered provider accordingly.
Assign the systemd service in the package providing them.
Prevents the following do_rootfs error if linux-driver-package is installed
but linux-driver-package-*boot is not:
| WARNING: linux-driver-package.postinst returned 1, marking as unpacked only, configuration required on target.
| ERROR: Postinstall scriptlets of ['linux-driver-package'] have failed. If the intention is to defer them to first boot,
| then please place them into pkg_postinst_ontarget_${PN} ().
This is caused by sytemctl trying to enable the not existing services nv.service and nvfb.service.
Update linux-toradex-mainline to 4.14.109.
(cherry picked from commit d4511e4a45392799ae157c6632f3944981787c02)
recipes-kernel/linux/linux-toradex_git.bb
(cherry picked from commit 0f59e154bfebd18f4f9eb11a31912ad5cb7e0c93)
Variables from tdx_version.conf are now provided by the distro.
Add defaults in case someone doesn't use our distro.
All of meta-jetson-tk1 has been moved into meta-toradex-tegra as updates
were needed. Drop meta-jetson-tk1.
Remove comment which was obsoleted by commit
b34fa66b4159cb6b0952a6821e73fdb93ae7714f
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply too high. Keep using the rocko based 2.8 BSP for these machines.
prevents warning:
| Applying patch 0001-configure.ac-link-crypotpp-as-a-static-library.patch
| patching file configure.ac
| Hunk #1 succeeded at 20 with fuzz 1.
cc1: error: -mfloat-abi=hard: selected processor lacks an FPU
...recipe-sysroot-native/usr/include/libfdt_env.h:70:30: error: conflicting types for 'fdt64_t'
typedef uint64_t FDT_BITWISE fdt64_t;
In file included from <command-line>:0:0:
...git/include/libfdt_env.h:19:16: note: previous declaration of 'fdt64_t' was here
typedef __be64 fdt64_t;
This reverts commit 8f9fb0502e052276bdb4d349af5e652e193543ff.
Now with 10.1 inch displays soon being available make those settings the
default. Note that one still needs to set vidargs properly e.g. from
within U-Boot as follows:
Apalis T30 # setenv vidargs 'video=tegrafb0:1280x800-16@60 fbcon=map:1'
Update linux-toradex-mainline to 4.14.90.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Add a script to the lvds-ctrl recipe for setting the correct mode for
10.1" display
Update linux-toradex-mainline to 4.14.72.
While at it drop obsolete linux-toradex-mainline 4.9 recipe.
Enforcing to build 32-bit binaries for native and portions thereof
using -m32 in EXTRA_OEMAKE_class-native may lead to building errors.
Also, it seems it's time to move on from 32-bit compatibility.
Affected repositories:
meta-toradex-demos
meta-toradex-nxp
meta-toradex-tegra
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Generate cbootimage already during build as required for Toradex Easy
Installer BSP package.
The eMMC unlocking was missing which lead to the following error
message:
Write error on /dev/mmcblk0boot0: Operation not permitted
Error: can't write fw_env to flash
Include u-boot-toradex-env.inc will generate a uEnv.txt text
file containing the default environment of the U-Boot binary.
As this recipe adds only binary drivers it does not need any DEPENDS
to build.
However adding depends prevents QA warnings which test the binaries
for dependencies and, more importantly other recipe will get needed
dependencies installed in their sysroot.
e.g. lxqt-panel would fail because libdamage is not installed in its recipe
specific sysroot.
While at it use -p with mkdir to not fail even if the directory already exists
from a previous (failed) run of bitbake.
While at it move the libpcre* symlinks to the nv-gstapps packages where they
are used and RDEPEND on the real libpcre* libraries.
New EGL code uses EGL_PLATFORM_X11_KHR (for example glmark2) and the
value is the same, so we can provide an alias for it instead of
patching every code using it.
(Adapted from meta-freescale, commit e1d249bb067aa6c472367cff1e77ba2ddbc8303f)
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
No functional change intended.
The U-Boot Makefile has a unusual way of compiling the user space tools which
results in the wrong toolchain (native vs. target) being used.
Drop our downstream fix in favour of how openembedded-core does this now.
Move UBOOT_BINARY, UBOOT_IMAGE and UBOOT_SYMLINK definitions to machine
configuration re-used by the Toradex Easy Installer U-Boot recipe.
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
Fix the include path.
Reported-by: Andreas Holzammer, kdab.com
The binary drivers in tdx-nv-binaries have dependencies on gstreamer
et. al.
Add them to DEPENDS, so that they are available during do_rootfs.
Addresses:
| Collected errors:
| * calculate_dependencies_for: Cannot satisfy the following dependencies for packagegroup-basic:
| * gstreamer (>= 0.10.36) * libgstaudio-0.10-0 (>= 0.10.36) * libgstinterfaces-0.10-0 (>= 0.10.36) * libgstvideo-0.10-0 (>= 0.10.36) * libxv1 (>= 1.0.10) *
| * opkg_solver_install: Cannot install package packagegroup-basic.
| * calculate_dependencies_for: Cannot satisfy the following dependencies for tdx-nv-binaries-nv-gstapps:
| * gstreamer (>= 0.10.36) * libgstinterfaces-0.10-0 (>= 0.10.36) *
| * opkg_solver_install: Cannot install package tdx-nv-binaries-nv-gstapps.
