While at it also rename it from trdx-k20-fw to tdx-k20-fw.
Use INSANE_SKIP_<package> in place of the unusual WARN_QA_remove.
Use the new version variables plus the git hash. Inspired by
meta-freescale/classes/fsl-u-boot-localversion.bbclass.
The 'rdepending' packages are picked up automatically by the
buildsystem.
This reverts commit 5b5356a28d06ccb8806310b4133b345fae178aba.
The commit duplicated the bbappend which now lives in
jetson-tk1/recipes-bsp/binary-drivers. Thus remove the duplicated
file.
When no resistive touch panel is connected spurious events
were generated.
Turns out our build was using the library from the build machine which
at least on Fedora 23 seems broken.
Update to latest from git in order to have support for
--usb-timeout= parameter.
The OpenMAX_IL headers archive has been updated resulting in a
changed checksum.
While at it consistently use a lower case 'v' as with U-Boot and kernel
in meta-toradex-nxp.
This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
TK1 silence warning for hash-style not gnu
Allow debug package, as for TK1 we have an unstripped binary
Add to RDEPENDS for tegrastats-gtk
WARNING: tegrastats-1.0-r3 ...tegrastats-gtk contained in package tegrastats-gtk requires libatk-1.0.so.0... [file-rdeps]
WARNING: tegrastats-1.0-r3 ...tegrastats: Files/directories were installed but not shipped in any package:
WARNING: tegrastats-1.0-r3 ...No GNU_HASH in the elf binary: '...packages-split/tegrastats/usr/bin/tegrastats' [ldflags]
WARNING: tegrastats-1.0-r3 ...tegrastats-gtk contained in package tegrastats-gtk requires libpangocairo-1.0.so.0... [file-rdeps]
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
fix errors due to missing uint* types.
Move to u-boot git.
While at it move the bbappend and xorg.conf under jetson-tk1 so that
one only needs meta-jetson-tk1 when one builds for tk1.
Disabling LVDS output by default has issue with pcmanfm consuming 100% CPU if
HDMI is inactive. So to make sure HDMI is set as primiary display and to address
the issue with pcmanfm, configure LVDS in extended mode by default so that if
HDMI is not active LVDS will be on atleast.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
With the split of meta-toradex we removed the binary blobs of the
Tegra driver- and codec packages.
This changes the recipe to download the files.
Do not use the function keyword, then the script works fine with
with Busybox' shell implementation.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
Disable LVDS output in favour of primary HDMI one on Apalis TK1.
Fix pkg_postrm by renaming from previous erroneous pkg_postremove and
remove /${bindir}/ which would need escaping.
And while at it replace Apalis-T30 in summary with Apalis T30 and get
rid of PR and empty do_compile.
Note: Currently only compiles -native but fails compiling for target!
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
