Update linux-toradex-mainline to 4.14.109.
Update linux-toradex-mainline to 4.14.90.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Update linux-toradex-mainline to 4.14.72.
While at it drop obsolete linux-toradex-mainline 4.9 recipe.
Generate cbootimage already during build as required for Toradex Easy
Installer BSP package.
Include u-boot-toradex-env.inc will generate a uEnv.txt text
file containing the default environment of the U-Boot binary.
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
Move UBOOT_BINARY, UBOOT_IMAGE and UBOOT_SYMLINK definitions to machine
configuration re-used by the Toradex Easy Installer U-Boot recipe.
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
Use the new version variables plus the git hash. Inspired by
meta-freescale/classes/fsl-u-boot-localversion.bbclass.
While at it consistently use a lower case 'v' as with U-Boot and kernel
in meta-toradex-nxp.
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
Introduce SRCBRANCH notation for easier switching to our -next branch.
And use 2015.04-toradex branch
While at it remove warning about stripped fw_printenv binary
when building u-boot-toradex-fsl-fw-utils.
Use latest U-Boot from git.
Migrate to using cbootimage and tegrarcm.
u-boot.inc no longer builds the standalone examples by default so
do patch to not do so is no longer needed.
The source tree will no longer be marked as git dirty.
With the change to our own u-boot recipes the bbappend to
the common u-boot-fw-utils recipe is no longer a sane solution.
While at it cleanup COMPATIBLE_MACHINE style.
