Update linux-toradex-mainline to 4.14.109.
Update linux-toradex-mainline to 4.14.90.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Update linux-toradex-mainline to 4.14.72.
While at it drop obsolete linux-toradex-mainline 4.9 recipe.
The eMMC unlocking was missing which lead to the following error
message:
Write error on /dev/mmcblk0boot0: Operation not permitted
Error: can't write fw_env to flash
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
No functional change intended.
The U-Boot Makefile has a unusual way of compiling the user space tools which
results in the wrong toolchain (native vs. target) being used.
Drop our downstream fix in favour of how openembedded-core does this now.
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
Use the new version variables plus the git hash. Inspired by
meta-freescale/classes/fsl-u-boot-localversion.bbclass.
While at it consistently use a lower case 'v' as with U-Boot and kernel
in meta-toradex-nxp.
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
fix errors due to missing uint* types.
Move to u-boot git.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
Introduce/update postinst code to dynamically adjust fw_env.config and
fw_unlock_mmc.sh shell profile extension script to cope with our new
unified eMMC layout:
boot area partition 1 aka primary eMMC boot sector:
with U-Boot boot loader and the U-Boot environment before the
configblock at the end of that boot area partition
Introduce SRCBRANCH notation for easier switching to our -next branch.
The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
And use 2015.04-toradex branch
While at it remove warning about stripped fw_printenv binary
when building u-boot-toradex-fsl-fw-utils.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
With dizzy we got compiler errors when compiling with the new 4.9 gcc.
