2014-06-25 | machine tegra: prefer egl gles from toradex-nv-binaries | raul | |
2014-06-12 | apalis-imx6: remove unneeded variable | Max Krummenacher | |
2014-06-11 | virtual/kernel: set preferred unconditionaly | Max Krummenacher | |
Be consistent with the other machine recipes Help the autobuilder setup | |||
2014-04-04 | Revert "cortex-a5.inc: backport from openembedded-core dora branch" | Max Krummenacher | |
File now provided by openembedded-core This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419. | |||
2014-04-01 | machines: add colibri-vf, apalis-imx6 | Max Krummenacher | |
2014-04-01 | machines: Add PREFERRED_PROVIDER for mesa to be mesa-gl | Max Krummenacher | |
EGL, OpenGL ES1.1 and OpenGL ES2.0 provided in binary form. | |||
2014-04-01 | machines: Add PREFERRED_PROVIDER for virtual/bootloader | Max Krummenacher | |
virtual/bootloader is a commonly used target. This patch adds it for meta-fsl-arm machines. Other BSP layers have this provider and when using a mutli-machine distro setup bitbake virtual/bootloader builds a wrong u-boot for fsl machines The patch was imported from the meta-arm-fsl git server (https://github.com/Freescale/meta-fsl-arm/commit/93b3d7dd7cdbbc0a49394cc32d335fb85fd2da74) and adapted to our machines. | |||
2014-04-01 | colibri-vf: use meta-fsl* layer for BSP files | Max Krummenacher | |
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra | |||
2013-11-21 | Machine: remove Colibri VF50, now unified with VF61 | Max Krummenacher | |
2013-11-21 | Vybrid: add 'vf' to SOC_FAMILY | Max Krummenacher | |
2013-10-16 | machines: T30 and VF50 consitstently use NEON and hard float | Max Krummenacher | |
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30) | |||
2013-10-14 | vybrid: backport from meta-fsl-arm master-next | Max Krummenacher | |
remove when moving to dora branch | |||
2013-10-14 | cortex-a5.inc: backport from openembedded-core dora branch | Max Krummenacher | |
revert when moving to dora | |||
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-07 | xserver: upgrade Colibri T30 to V14 | Max Krummenacher | |
2013-09-22 | machine: define SOC-FAMILY, fix ARCH name | Max Krummenacher | |
2013-09-22 | xserver: upgrade Colibri T20 and Apalis T30 to V14 | Max Krummenacher | |
2013-09-22 | machine: force x-server version 1.13.1 | Max Krummenacher | |
- the binary only x-server driver only supports API for 1.13 at the moment - remove a backup file | |||
2013-09-22 | colibri-t20.conf: cleanup | Max Krummenacher | |
2013-06-07 | apalis_t30: use the apalis specific u-boot configuration | Max Krummenacher | |
2013-01-29 | Machine: add apalis-t30 for the Apalis-T30 module | Max Krummenacher | |
2013-01-29 | kernel: use the unified recipe | Max Krummenacher | |
2012-11-19 | colibri-t30.conf: | Max Krummenacher | |
- change to hard-float - u-boot entry point set to l4t R16 requirements - cleanup and harmonized with colibri-t20.conf | |||
2012-10-18 | removed *~ backup files from git repo | Max Krummenacher | |
2012-10-18 | define the vfp variant to be used | Max Krummenacher | |
2012-10-18 | update to L4T R16, use abi hard float instead of soft float | Max Krummenacher | |
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-07-21 | removed unneeded apmd from machine features | Max Krummenacher | |
2012-06-03 | Initial commit | Max Krummenacher | |
