This reverts commit 7dd6b7d55b9ca9e5c666e58fafc36b21b45f7a1e
xinput-calibrator runs twice:
- as an X-session script (/etc/X11/Xsession.d/30xinput_calibrate.sh)
- as autorunned desktop item (/etc/xdg/autostart/xinput_calibrator.desktop)
Sometimes it breaks displaying other auto-run desktop applications.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
0026-apalis_t30-fix-mmc1-cmd-pull-up.patch is now applied upstream
Signed-off-by: Ming Liu <ming.liu@toradex.com>
This file is conflicting with another include file with same name in
meta-toradex-bsp-common layer, and no recipe is actually including this
file, so drop it.
There is not a generic license called
"FREESCALE_SEMICONDUCTOR_SOFTWARE_LICENSE_AGREEMENT", drop it, use
"CLOSED" instead, this fixes a following QA warning:
| tdx-k20-fw: No generic license file exists for: FREESCALE_SEMICONDUCTOR_SOFTWARE_LICENSE_AGREEMENT in any provider
Also remove a relative path reference in LIC_FILES_CHKSUM.
For the recipes listed in EXTRA_IMAGEDEPENDS, bitbake would create a
dependency as:
| image_pn:do_image_complete -> imagedepends_pn:do_populate_sysroot
but we actually need a image task depend on the deploy tasks of
EXTRA_IMAGEDEPENDS recipes, setting EXTRA_IMAGEDEPENDS would not help
with that, so drop it, use WKS_FILE_DEPENDS instead.
We also need drop "IMAGE_BOOT_FILES +=", that would override
"WKS_FILE_DEPENDS ?=".
This depends on and deploys the distro boot script provided
by u-boot-distro-boot.
commit 8691ba636cb2 allowed to also use SysV init. However, if only systemd
is configured in DISTRO_FEATURES the content of /etc/init.d is deleted
after the install step. This results in the scripts nv and nvfb not being
present.
Fix this by installing them additionally in /usr/bin so that the systemd
service can call them.
The bmap file allows to use the bmap tools to flash the wic image.
Using bmap is faster than using dd.
bmaptool copy --bmap <image>.wic.bmap <image>.wic.gz /dev/sdX
In the thud setups modules no longer load because they seem to be compiled
with pic by default.
E.g. at runtime:
[ 9.302483] apalis_tk1_k20: Unknown symbol _GLOBAL_OFFSET_TABLE_ (err 0)
Adding -fno-pic makes them load again.
This allows to use u-boot-fw-utils in image recipes.
Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
While at it append -tk1 to PN to have a name different from the u-boot recipe
name for our NXP based SoM and set the prefered provider accordingly.
Provide the MACHINE_NAME variable which can be e.g. used as part of the
image name.
linux-driver-package* contains more than just X11 components.
Assign the systemd service in the package providing them.
Prevents the following do_rootfs error if linux-driver-package is installed
but linux-driver-package-*boot is not:
| WARNING: linux-driver-package.postinst returned 1, marking as unpacked only, configuration required on target.
| ERROR: Postinstall scriptlets of ['linux-driver-package'] have failed. If the intention is to defer them to first boot,
| then please place them into pkg_postinst_ontarget_${PN} ().
This is caused by sytemctl trying to enable the not existing services nv.service and nvfb.service.
Maintaining the current bbappend for weston 1.x versions generates an annoying
warning in OE (new in thud), since we do not have any recipe for weston 1.x.
Given that the current version of weston is 6.0, it doesn't make much sense to
keep these patches.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
(cherry picked from commit c10c7168712fa47e50440a7b7b012118939a3371)
Update linux-toradex-mainline to 4.14.109.
(cherry picked from commit d4511e4a45392799ae157c6632f3944981787c02)
recipes-kernel/linux/linux-toradex_git.bb
Fix commit 0f59e154bfeb ("alsa: apalis-tk1-mainline: add initial
asound.state and asound.conf").
(cherry picked from commit 26cbb6fd9019f28141f8fef42521c82246fa3d03)
(cherry picked from commit 0f59e154bfebd18f4f9eb11a31912ad5cb7e0c93)
The patches included in the weston bbappend are only compatible with 1.x
versions of weston. Rename the file so that it only applies to such versions.
NOTE: how these patches should be ported (if at all) to modern versions of
weston is out of the scope of this commit. Additional patching could be needed
when building weston >= 2.0 with drm backend.
Variables from tdx_version.conf are now provided by the distro.
Add defaults in case someone doesn't use our distro.
As we dropped meta-angstrom, do not prefer psplash-angstrom anymore.
All of meta-jetson-tk1 has been moved into meta-toradex-tegra as updates
were needed. Drop meta-jetson-tk1.
SERIAL_CONSOLE has been deprecated for a while now
fixes:
| ERROR: libgstnvegl-21.5.0-r0 do_package_qa: QA Issue: libgstnvegl: The compile log indicates that host include and/or library paths were used.
Please check the log '/build/krm/oe-core_3.0/build/tmp/work/cortexa15hf-neon-poky-linux-gnueabi/libgstnvegl/21.5.0-r0/temp/log.do_compile' for more information. [compile-host-path]
| ERROR: libgstnvegl-21.5.0-r0 do_package_qa: QA run found fatal errors. Please consider fixing them.
| ERROR: libgstnvegl-21.5.0-r0 do_package_qa: Function failed: do_package_qa
| ERROR: Logfile of failure stored in: /build/krm/oe-core_3.0/build/tmp/work/cortexa15hf-neon-poky-linux-gnueabi/libgstnvegl/21.5.0-r0/temp/log.do_package_qa.15826
| ERROR: Task (/build/krm/oe-core_3.0/build/../layers/meta-toradex-tegra/recipes-multimedia/libgstnvegl/libgstnvegl_21.5.0.bb:do_package_qa) failed with exit code '1'
With the stricter OE rules the 0001-Check-for-libegl-using-pkg-config.patch
from openembedded-core does no longer apply to the newer git hash set in
the bbappend.
prevents the following build error:
| ERROR: qt5-x11-image-3.0b1-r0 do_populate_sdk: Postinstall scriptlets of
| ['linux-driver-package-firstboot', 'linux-driver-package-boot'] have
| Deferring to first boot via 'exit 1' is no longer supported.
tegra124m now depends on nouveau and tegra to be configured.
Heed --sysroot setting.
fixes:
| ERROR: QA Issue: perf: The compile log indicates that host include and/or library paths were used.
| Please check the log '/build/krm/oe-core_3.0/build/tmp/work/apalis_tk1-poky-linux-gnueabi/perf/1.0-r9/temp/log.do_compile' for more information. [compile-host-path]
| cc1: warning: include location "/usr/include/slang" is unsafe for cross-compilation [-Wpoison-system-directories]
Remove comment which was obsoleted by commit
b34fa66b4159cb6b0952a6821e73fdb93ae7714f
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply too high. Keep using the rocko based 2.8 BSP for these machines.
prevents warning:
| Applying patch macro_tweak.patch
| patching file xorg-server.m4
| Hunk #1 succeeded at 28 with fuzz 2.
prevents warning:
| Applying patch 0001-configure.ac-link-crypotpp-as-a-static-library.patch
| patching file configure.ac
| Hunk #1 succeeded at 20 with fuzz 1.
