This patch adds mainline linux based Apalis TK1 machine.
It includes compatible recipes for libdrm, mesa, Xorg, and weston.
Unsetting KEEPUIMAGE requests that vmlinux is built and later manually
packed into a uImage.
The resulting uImage in morty now packeges a gz compressed kernel in favour of
the uImage compression. Our U-Boot is not configured to boot such a uImage.
So keep the default setting for KEEPUIMAGE.
With only systemd in DISTRO_FEATURES those sysmlinks no longer are created
with the update_rc bbclass.
TK1 silence warning for hash-style not gnu
Allow debug package, as for TK1 we have an unstripped binary
Add to RDEPENDS for tegrastats-gtk
WARNING: tegrastats-1.0-r3 ...tegrastats-gtk contained in package tegrastats-gtk requires libatk-1.0.so.0... [file-rdeps]
WARNING: tegrastats-1.0-r3 ...tegrastats: Files/directories were installed but not shipped in any package:
WARNING: tegrastats-1.0-r3 ...No GNU_HASH in the elf binary: '...packages-split/tegrastats/usr/bin/tegrastats' [ldflags]
WARNING: tegrastats-1.0-r3 ...tegrastats-gtk contained in package tegrastats-gtk requires libpangocairo-1.0.so.0... [file-rdeps]
Moving from patching the "*.pc" files to patching there "*.pc.in" files
should hopefully make the patch more independent of the mesa version.
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
The regular implementation works.
However the deploy logic for device tree-files can not cope with this
and prefixes the device-tree files with vmlinux and not uImage as expected.
The 1.17 Xserver does not (yet) support a packageconfig set as default in
xserver-xorg.inc.
Recipe has been removed in meta-openembedded in favour of freeglut.
fix errors due to missing uint* types.
Move to u-boot git.
Make the 1.17.2 only used for tk1 machines.
With the update xserver-xorg update to 1.18 and 'xf86-input-evdev:
Upgrade 2.9.2 -> 2.10.0' this file is provided by the evdev recipe.
So when using an older xserver-xorg don't deploy the file.
With the update 'xf86-input-evdev: Upgrade 2.9.2 -> 2.10.0' this file is
The patch fixes the following compilation error:
../../gstomx1_src/gst-omx1/omx/gstomxvideoenc.c:2443:7: note: in
expansion of macro 'NVX_INDEX_CONFIG_VIDEO_ENCODE_TEMPORALTRADEOFF'
NVX_INDEX_CONFIG_VIDEO_ENCODE_TEMPORALTRADEOFF, &eIndex);
In file included from ../../gstomx1_src/gst-omx1/omx/gstomxvideoenc.h:29:0,
from ../../gstomx1_src/gst-omx1/omx/gstomxvideoenc.c:30:
../../gstomx1_src/gst-omx1/omx/gstomx.h:384:15: note: expected
'gpointer {aka void *}' but argument is of type 'const char *'
0001-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch taken from
oe-core, gstreamer recipe.
The gstreamer based package rdepend on gstreamer components so add
the relevant RDEPEND for these packages.
Silence warnings which can not be avoided with the binary distibuted files.
The Vybrid xorg.conf should not be part of the Tegra BSP.
While at it move the bbappend and xorg.conf under jetson-tk1 so that
one only needs meta-jetson-tk1 when one builds for tk1.
Disabling LVDS output by default has issue with pcmanfm consuming 100% CPU if
HDMI is inactive. So to make sure HDMI is set as primiary display and to address
the issue with pcmanfm, configure LVDS in extended mode by default so that if
HDMI is not active LVDS will be on atleast.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
The base_contains function is deprecated and we ought to use
bb.utils.contains instead.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
With the split of meta-toradex we removed the binary blobs of the
Tegra driver- and codec packages.
This changes the recipe to download the files.
