Upstream has already fixed the GCC 5 problem, so use the patch from upstream.
Signed-off-by: Ross Burton <ross.burton@intel.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Backport a patch from fedora details are in patch header
Change-Id: I6b8dfaae3b751071bf8b0d88b15a4f95c19877f6
Signed-off-by: Khem Raj <raj.khem@gmail.com>
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Update to latest revision which fixes Colibri iMX6D not powerering off but
creating a stacktrace.
Update to latest revision.
While at it remove the module specific override of SRCREV and PR and set
the git branch with its own variable.
While at it use 4 spaces to indent code as customary in recipes.
We have this recipe in meta-fsl-arm-extra.
Convert it to a bbappend and only keep the changes to the bb files.
Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
Add LOCALVERSION and generate a scmversion file to annotate the
Kernel with the Toradex release and a git hash.
Since we use USB Gadget ConfigFS now use libusbg to load the
USB Gadget configuration automatically.
Change DEFAULTTUNE in machine configurations to Thumb-2.
Systemd startup script for NVIDIA T30 CPU hot-plug configuration.
meta-openembedded provides a recipe for joe, use that one.
Introduce/update postinst code to dynamically adjust fw_env.config and
fw_unlock_mmc.sh shell profile extension script to cope with our new
unified eMMC layout:
boot area partition 1 aka primary eMMC boot sector:
with U-Boot boot loader and the U-Boot environment before the
configblock at the end of that boot area partition
Introduce SRCBRANCH notation for easier switching to our -next branch.
The evdev version provided by oe-core is in the meantime newer than
this backport, hence we can safely remove it.
Update defconfig and kernel version to latest version from git. This
also configures the USB Gadget ConfigFS as a module. Add the ConfigFS
module to the list of autoloaded modules.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
This reverts commit bd2d32bf3a8460c87849e75ad01e11450d8cda10.
Remove the backport, is part of fido.
gpu-viv-bin-mx6q -> imx-gpu-viv
with a bunch of subpackages.
Include the NVIDIA binaries as soon as X11 is in distribution
features. This allows to use the hardware accelerated X11 DDX
driver "tegra" even when OpenGL is not selected by the image.
Consolidate Tegra specific machine configuration in a common
tegra-base.inc file.
Since the boot loader requires a kernel-image in /boot, add the
kernel-image to MACHINE_ESSENTIAL_EXTRA_RDEPENDS. This allows to
boot images which do not select packagegroup-boot by default such
as the Poky reference distribution images.
The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
SCSI lock device disk support is required for USB mass storage to
work. Also enable asynchronous SCSI scanning by default.
Use a fixed revision of the MCC kernel module which makes sure it
builds with the corresponding Vybrid Linux kernel, which also uses
a fixed git hash.
