Corrects reset and irq pins for capacitive touch for Aster carrier board.
Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>aödf
Update linux-toradex-mainline to 4.14.72.
While at it drop obsolete linux-toradex-mainline 4.9 recipe.
Unfortunately, perf fails building in rocko since this oe-core commit:
commit 6f9117c0bceeedbfce08647825edf86966457bfc
Author: Hongxu Jia <hongxu.jia@windriver.com>
Date: Tue Apr 24 11:33:47 2018 +0800
perf: make a copy of kernel source to perf workdir
Unfortunately perf in such obsolete kernels is not yet as nicely
separated therefore just copy over some more stuff for it to compile
again.
Currently only imx and vybrid automatically generate wic images. This
functionality is useful e.g. for booting from SD cards. Add wic image
generation in tegra modules.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Latest additions:
- 0024-apalis_t30-enable-broken-hpi-on-emmc.patch
Avoid a rare soft lockup upon installing an image from within Tezi.
- 0025-tegra_defconfig-disable-sound-in-tezi-configuration.patch
Avoid keyboard/mouse being unresponsive for 10-15 Seconds.
- 0026-apalis_t30-fix-mmc1-cmd-pull-up.patch
Avoid issues with higher speed SD cards.
- 0027-apalis_t30-pull-up-sd-card-detect-pins.patch
Avoid floating SD card detect pins.
- 0028-Revert-mmc-tegra-Disable-UHS-I-modes-for-Tegra124.patch
Allow for UHS-I modes on TK1.
- 0029-mmc-tegra-fix-eMMC-DDR-mode.patch
Fix eMMC DDR mode.
- 0030-apalis-tk1-enable-ddr52-mode-on-emmc.patch
Enable eMMC DDR mode.
- 0031-apalis-tk1-force-fixed-ids-for-sdmmc-controllers.patch
Avoid re-ordering of SDMMC controller instances.
- 0032-apalis-tk1-fix-pcie-reset-for-reliable-gigabit-ether.patch
Fix PCIe gigabit bring-up issue on Apalis TK1.
Enforcing to build 32-bit binaries for native and portions thereof
using -m32 in EXTRA_OEMAKE_class-native may lead to building errors.
Also, it seems it's time to move on from 32-bit compatibility.
Affected repositories:
meta-toradex-demos
meta-toradex-nxp
meta-toradex-tegra
Drop commit c35b518f9ba0 ("clk: tegra: Fix pll_u rate configuration")
which meanwhile got merged into stable.
Add the following patches:
- apalis-t30/tk1-mainline: igb: avoid nvm checksum failure
- apalis_t30: fix can2
- mfd: as3722: disable auto power on when AC OK
Introduced with commit cd14ac8b9157 ("linux-driver-package: create
libGL.so symlink were libGL.so.1 is").
Update to NVIDIA's latest Linux for Tegra aka L4T R21.7:
https://developer.nvidia.com/linux-tegra-r217
The following libraries got updated:
4094b811241593224a89a5020e0bef7a08914dea */usr/lib/arm-linux-gnueabihf/tegra/libglx.so
157e8271ba925d1dc7405c4ebaad1b8b8b3f1312 */usr/lib/xorg/modules/drivers/nvidia_drv.so
c1d9de2b619110534437850335c06408648e263b */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_imager.so
2a712cc736f0cfc694e1ae44603bb1c95fc0873e */usr/lib/arm-linux-gnueabihf/tegra/libnvmmlite_video.so
25514ded098387ac0260586392308144d6e659fa */usr/lib/arm-linux-gnueabihf/tegra/libnvmm_camera_v3.so
4c2528fa906e1ff8702a9e1cad2b63d261bd2c16 */usr/lib/arm-linux-gnueabihf/tegra/libnvodm_query.so
28ace2c204408e58444497f7fc32a7f6852f98a9 */usr/lib/arm-linux-gnueabihf/tegra/libnvomx.so
4094b811241593224a89a5020e0bef7a08914dea */usr/lib/xorg/modules/extensions/libglx.so
As libpng12 is required for opencv4tegra re-add the recipe from latest
one available at meta/recipes-lsb4/libpng/libpng12_1.2.57.bb on morty
branch of openembedded-core.
This is basically a revert of commit 839af0eafc39
("libpng12: remove the recipe").
Add Toradex Easy Installer image class and the image type with all
required variables to the Apalis T30 machine config.
Generate cbootimage already during build as required for Toradex Easy
Installer BSP package.
The eMMC unlocking was missing which lead to the following error
message:
Write error on /dev/mmcblk0boot0: Operation not permitted
Error: can't write fw_env to flash
Move the USB device aka gadget fix from Tezi to here.
Add patches to force fixed IDs for SDMMC controllers.
Add patch to fix for PLL_U rate configuration (T30).
Add Apalis T30 specific patch for PCIe fix hacks.
Some patches meanwhile got accepted mainline. Backport those
patches.
Integrate Thierry's fbdev mmap fix allowing legacy applications that use
the mmap() syscall on the fbdev device to map framebuffer memory without
causing a hang. Useful e.g. for Tezi.
While at it also update to 4.14.30.
This reverts commit deec4d3c6702cddd23b572790f8b1728761ff6a2.
Include u-boot-toradex-env.inc will generate a uEnv.txt text
file containing the default environment of the U-Boot binary.
As this recipe adds only binary drivers it does not need any DEPENDS
to build.
However adding depends prevents QA warnings which test the binaries
for dependencies and, more importantly other recipe will get needed
dependencies installed in their sysroot.
e.g. lxqt-panel would fail because libdamage is not installed in its recipe
specific sysroot.
While at it use -p with mkdir to not fail even if the directory already exists
from a previous (failed) run of bitbake.
While at it move the libpcre* symlinks to the nv-gstapps packages where they
are used and RDEPEND on the real libpcre* libraries.
While at it also update to 4.14.29.
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
New EGL code uses EGL_PLATFORM_X11_KHR (for example glmark2) and the
value is the same, so we can provide an alias for it instead of
patching every code using it.
(Adapted from meta-freescale, commit e1d249bb067aa6c472367cff1e77ba2ddbc8303f)
Based on 1.17.2 from meta-jetson-tk1. Dropped patch no longer applicable.
Also make sure that 1.17.2 is not choosen for any machine due to the
higher layer priority of meta-jetson-tk1.
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
The Device Tree support is now handled by the kernel class. This patch
removes the inclusion of linux-dtb.inc from the kernel recipes in this
layer.
No functional change intended.
The U-Boot Makefile has a unusual way of compiling the user space tools which
results in the wrong toolchain (native vs. target) being used.
Drop our downstream fix in favour of how openembedded-core does this now.
Use '${COMMON_LICENSE_DIR} for license files
fix the warning:
| WARNING: packagegroup-xfce-base-1.0-r5 do_populate_lic:
| ${COREBASE}/LICENSE is not a valid license file, please use
|'${COMMON_LICENSE_DIR}/MIT' for a MIT License file in LIC_FILES_CHKSUM.
|This will become an error in the future
